Author Topic: Windows 95 supports PC/XT keyboards  (Read 4391 times)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« on: Fri, 31 July 2009, 07:59:42 »
When I was playing around on one of my older computers (This one had Windows 95), I made an interesting discovery. It appears that Windows 95 has a driver for PC/XT 83 key keyboards. This means that they should be compatible with modern PC's to at least some extent.
I took a screenshot of the keyboards window. I'm sure you can see that Windows 95 is compatible with many more keyboards than just an AT.
If someone has an XT keyboard and a Windows 95 computer, would they be able to try this?
« Last Edit: Fri, 31 July 2009, 08:09:33 by microsoft windows »
Offline timw4mail
    • https://timshomepage.net
« Reply #1 on: Fri, 31 July 2009, 08:01:00 »
Quote from: microsoft windows;105742
I think the big issue with this was that the XT is wired differently than the AT, not the driver, but I could be wrong.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
« Reply #2 on: Fri, 31 July 2009, 08:04:44 »
They must at least work with Windows 95 then. If I ever get one, I might try extracting the driver from Windows 95 and putting it on XP.
Offline skriefal
« Reply #3 on: Fri, 31 July 2009, 08:56:33 »
I expect that they'll work, but only if the hardware (motherboard) has support for the XT keyboard protocol.  The driver must likely does nothing more than tell the O/S which keys are available on the board.
Offline JBert
« Reply #4 on: Fri, 31 July 2009, 12:11:16 »
Quote from: timw4mail;105743
The connectors are completely compatible, the only change was that the AT protocol used the 5th pin for a reset signal. For XT's, it was simply unconnected.
The protocol is different though: different timings, different sync bits, uni- vs. bi-directional, command modes and an extreme difference in scancodes.
Quote from: skriefal;105757
I fear the same. Unless your PS2 controller is driven by software, it won't understand the XT protocol.
Seeing how the BIOS mostly initialises the PS/2 bus, I think it is implemented in hardware, hence this driver may not work.
Finally, you will need to test it with windows 95 or windows 98; Windows 9x drivers were built on the VxD architecture from Windows 3.1 whereas Windows 2000 and upwards only works with the newer WDM architecture.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline Manyak
« Reply #5 on: Fri, 31 July 2009, 13:26:15 »
Quote from: JBert;105862
Windows NT and upwards you mean, not 2000.
Currently Owned:
Filco FKBN104MC/EB - Model M 1390131 \'86 - Model M 1391401 NIB - Unicomp Endurapro NIB - iRocks KR-6230 - Compaq MX-11800 - Cherry G80-8113HRBUS-2 - Cherry ML-4100 - Cherry MY-8000-something - Dell AT101W (Black) - ABS M1 - Siig Minitouch - Chicony KB-5181 w/ SMK Montereys - Chicony KB-5181 w/ SMK Montereys NIB - Cherry G80-3494LYCUS-2 - Deck Legend
Offline JBert
« Reply #6 on: Fri, 31 July 2009, 15:55:05 »
Quote from: Manyak;105873
I was talking about operating systems you'd have available for a home PC. I don't know anyone who installs NT 4 for fun...
You are right that NT can't use VxD's though, although to my defense the WDM architecture was only introduced in Windows 2000.
The storage list:
[/SIZE]
Offline itlnstln
« Reply #7 on: Fri, 31 July 2009, 16:04:26 »
Quote from: JBert;105916
I had NT 3.51 for awhile.  Not fun.
Offline ch_123
« Reply #8 on: Fri, 31 July 2009, 17:15:40 »
Both incorrect, although the rest of what Jbert says is right. The two had exactly the same pin out - see kbdbabel for diagrams, they only used four pins - this is why on Model M PS/2 cables, you only see four of the pins used. The difference is that they use different protocols (the AT protocol was bi-directional, so the reset signals would have been sent over the data line) and different scancodes. It has to be implemented at the low end, and in theory you could design a motherboard that dealt with both. In reality, this was never really done, the AT protocol was more desirable, and people didn't have much love for the layout on original PC/XT keyboards so there wasn't a great desire for backwards compatibility. Alot of those Windows drivers are leftovers from the earlier versions of Windows that actually could run on an XT.
I was just thinking though, could you have a simple XT to USB adaptor, and do all the scancode/protocol conversion with a custom software driver? And I think the 1390120 Model M was compatible with both XTs and ATs.
« Last Edit: Fri, 31 July 2009, 17:27:20 by ch_123 »
Offline JBert
« Reply #9 on: Sat, 01 August 2009, 05:00:08 »
Translating the scancodes in software seems unnecessary - it would take about the same electronics to send the XT scancodes as it would take to build a true keyboard converter which would seamlessly with any HID driver.
The only thing which could thus be simplified is the micro-controller code.
The storage list:
[/SIZE]
