Author Topic: Double tap on I?  (Read 2241 times)
Offline HardCelery
Double tap on I?
« on: Sun, 14 December 2014, 17:17:20 »
Starting today, whenever I use my I key quiite often it will place two I's(Like in quiite lol)
Anyone know what's probably wrong or how to fix it?
On a Poker II by the way.
Re: Double tap on I?
« Reply #1 on: Sun, 14 December 2014, 20:52:00 »
So with one tap of "I" it sometimes types "II", yes?
This is called "chattering" and is usually only fixable by replacing the switch. There is a program you can use to test for chattering, though I seem to have forgotten its name.
Soldering in a new switch is fairly easy. I've done it myself, and I didn't break anything. If you're worried about breaking something, there are plenty of users you could send your board to to have fixed.
Find that program now that you know what the issue is, test your board, and proceed from there.
Seriously, Test if before you take it apart.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2 on: Sun, 14 December 2014, 21:02:02 »
https://elitekeyboards.com/switchhitter.php
« Reply #3 on: Sun, 14 December 2014, 21:05:17 »
That's the one, thanks hwood.
Offline Fragil1ty
  • Abre los ojos.
« Reply #4 on: Sun, 14 December 2014, 21:40:17 »
Try this, but I'm not sure on how effective this actually is, if at-all, but worth a shot I suppose.
http://sourceforge.net/projects/keyboardchatteringfix/
gl.
« Last Edit: Sun, 14 December 2014, 21:42:18 by Fragil1ty »
你搞砸了
Offline HardCelery
« Reply #5 on: Sun, 14 December 2014, 23:17:10 »
Exactly, like the time I typed quiite twice and this time, I only hit I once.
