Author Topic: Annoying: Ctrl-Shift-Esc not working (FC660M)  (Read 3478 times)
Offline JackMills
« on: Tue, 16 December 2014, 04:58:10 »
I have a Leopold FC660M and I am using the standard layout, but switched the CapsLock and LCtrl with a dipswitch.
Today I found something very annoying, Ctrl-Shift-Esc is not working because Shift-Esc is mapped to the tilde ~.  The moment I activate Shift-Esc scancode SC0029 is sent which should be tilde ~.
Nothing really incorrect in the behaviour, just very annoying, because I liked the Ctrl-Shift-Esc on Windows to open the Task Manager.
Would there be a way (AHK probably) to have a distinction in action between LShift-Esc and RShift-Esc?
And another thing, the LED on the insert doesn't work anymore after taking the cap off and placing it back. Probably damaged something during that action.
Offline daerid
    • Rossipedia
Re: Annoying: Ctrl-Shift-Esc not working (FC660M)
« Reply #1 on: Tue, 16 December 2014, 11:07:47 »
Yeah, that was one of the issues that I really didn't like about my FC660Cs. You should be able to use AHK like that, check the docs.
