Author Topic: How to darken white ABS caps?  (Read 2346 times)
Offline Geroximo
« on: Tue, 16 December 2014, 11:21:38 »
Hey guys,
I got a white spacebar and a light grey capslock from WASD Keyboards. Sadly, they are too bright and don't fit the used Cherry PBT Dye-subs.
Do you know how I can slightly darken them? Make them somehow look older, so they fit the old cherry caps?
Re: How to darken white ABS caps?
« Reply #1 on: Tue, 16 December 2014, 15:22:17 »
They'll wear with use. There's no real easy way to do it.
Offline Mandolin
  • Crystal Connoisseur
« Reply #2 on: Tue, 16 December 2014, 15:26:40 »
You could artificially yellow it. Under direct sunlight, checking it doesn't deform because of heat, or get a UV lamp like the ones used in nail salons and throw it in (protect your skin and eyes, don't overexpose to them) or buy a led lamp like the ones used in dentistry.
http://en.wikipedia.org/wiki/UV_degradation
« Last Edit: Tue, 16 December 2014, 18:38:59 by Mandolin »
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
« Reply #3 on: Tue, 16 December 2014, 15:31:44 »
ABS will just melt under heat, not warp.
Offline Mandolin
« Reply #4 on: Tue, 16 December 2014, 15:33:30 »
Good to know  :)
« Last Edit: Tue, 16 December 2014, 15:39:41 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #5 on: Tue, 16 December 2014, 15:34:12 »
I suppose you could dye it, though it might be hard to find a dye in that light of a beige/grey
But letting it yellow in the sun would probably be better
« Last Edit: Tue, 16 December 2014, 15:37:53 by hwood34 »
Offline Sygaldry
  • Edema Ruh
« Reply #6 on: Tue, 16 December 2014, 15:34:32 »
Leave it directly in the sun. ABS yellows with extended exposure to UV.
null
