Author Topic: in search of another keyboard  (Read 3241 times)
Offline PythoN
« on: Thu, 25 December 2014, 21:04:23 »
I currently own a Das Proffesional quiet with mx reds, in the past I've owned a CM quickfire pro with browns that I ended up selling and a CM quickfire stealth with blues which has a malfunctioning P and backspace key. my budget is in the 100-150 range.
does anybody have suggestions for good boards that I can find in Toronto, or that I can order online without having to pay an arm and a leg for shipping? I'm open minded but would prefer browns/blues and perhaps a tenkeyless model to slap my WASD keycaps on. thanks!
Offline Fragil1ty
  • Abre los ojos.
Re: in search of another keyboard
« Reply #1 on: Fri, 26 December 2014, 03:01:14 »
KUL ES-87.
/thread.
你搞砸了
Offline azhdar
  • Praise the AZERTY god
« Reply #2 on: Fri, 26 December 2014, 03:38:56 »
KUL ES-87.
/thread.
this
unless you want backlit .
Azerty Propagandiste
Offline PythoN
« Reply #3 on: Fri, 26 December 2014, 14:07:02 »
Is there any place I can find one with free shipping? they're out of stock on amazon and on elitekeyboards.com it's like 30-40 dollars :/
Offline Hellcatz
« Reply #4 on: Fri, 26 December 2014, 14:23:45 »
I got a thermal take Poseidon tkl with browns that I'm selling for $40 cad
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #5 on: Fri, 26 December 2014, 14:29:30 »
KUL ES-87.
/thread.
+1
Offline RoflCopter4
« Reply #6 on: Fri, 26 December 2014, 19:19:39 »
If you're feeling adventurous I'd say go vintage and look for an AEK or something, but if you're not then what the others suggested would probably do fine.
Acer KB-101A with Blue Alps | HHKB Pro 2 | '85 122 Key IBM Model F | '86 1390131 "Silver Label" Model M | AEK M0115 with Orange Alps | Focus FK-2001 White Alps | Chicony 5181 with SMK "Monterey Blue" Switches | Dell AT101W | Unicomp "Ultra Classic" | Razer Blackwidow 2013
« Reply #7 on: Fri, 26 December 2014, 19:26:10 »
KUL ES-87.
/thread.
+1
Offline sorijealut
    • steam
« Reply #8 on: Fri, 26 December 2014, 20:12:11 »
KUL ES-87.
/thread.
+1
+1 It may look like the thread has a bit of KUL ES-87 bias, but in truth they've just beaten me to it.
Dead solid board that has up-to-date features and very few gripes (that being ABS keycaps).
I went from Filco to KUL and I'm very pleased with my decision.
« Last Edit: Fri, 26 December 2014, 20:13:51 by sorijealut »
Offline PythoN
« Reply #9 on: Fri, 26 December 2014, 20:18:41 »
thanks for your suggestions, I'm sold on the fact that it's a good board, I just need to find a way to get one within my budget. it looks really nice though, the minimalistic design is exactly what I was looking for
Offline sorijealut
    • steam
« Reply #10 on: Fri, 26 December 2014, 20:28:34 »
I'd say it's well within your budget if you're in the US, with $130 + about $10 shipping (?) as was for me.
http://elitekeyboards.com/products.php?sub=keyed_up_labs,tenkeyless&pid=es87u_cg_sss_al
edit: read Toronto, feel dumb.
Offline dante
« Reply #11 on: Fri, 26 December 2014, 21:59:53 »
CptBadAss has a naked (capless) Leopold FC700R w/ Blues in the classifieds.  Then you can hop on ebay and buy a set of thick PBT's from widebasket in Korea.
That might run you around $150 total ..
Offline PythoN
« Reply #12 on: Fri, 26 December 2014, 22:23:09 »
thanks a lot! this is perfect for what I was looking for
Offline sorijealut
    • steam
« Reply #13 on: Fri, 26 December 2014, 22:25:01 »
Great recommendation :)
Having a great set of PBT with your board is the best value for $150.
edit: and from a great seller, too! You should know about the unusual spacing of the space bar on there though! Should work fine with Leopold caps, ofc lol.
CptBadAss is kind enough to include some Bluetack in there for you if you might need it in the future.
« Last Edit: Fri, 26 December 2014, 22:33:09 by sorijealut »
Offline dante
« Reply #14 on: Fri, 26 December 2014, 23:01:52 »
Yes the space bar stem is weird on the FC700R - but the ones off ebay are nice and thick.  1.5mm vs. 1.3mm (the original FC700R spec.)
