Author Topic: [GB]Simply 60 – ft. Gold Plated Stabilizers!  (Read 285149 times)
Offline Dreamre
    • kbdlife
Re: [GB]Simply 60 – ft. Gold Plated Stabilizers!
« Reply #50 on: Wed, 14 January 2015, 17:45:22 »
How does Sprit's PCB compare with GONS?
Offline howthegodschill
« Reply #51 on: Wed, 14 January 2015, 22:06:24 »
I shipped out 4 GB orders yesterday (some are already delivered/on the vehicle for delivery), and am in the process of packing more today. Counting the stabs/packing & bubble wrapping everything in generous layers is taking lots of time. I should have everything done and shipped by tomorrow. Thanks for your patience!
A lot of people are frustrated right now with the Sprit case delay, so know that your transparency with this is appreciated.
Offline rpeterclark
  • RPTR ❌
« Reply #52 on: Thu, 15 January 2015, 05:29:52 »
Order received! It was packed wonderfully and the gold plated stabs look super nice. I'll be working on this over the weekend. :-)
Thanks Zeal!
Offline FreeChemicals
« Reply #53 on: Thu, 15 January 2015, 06:48:34 »
I've also received the set today & would like to thank you again!
ps. The cable (and everything else) looks amazing!
/edit
Might as well add a picture:
« Last Edit: Thu, 15 January 2015, 12:01:04 by FreeChemicals »
Offline Zeal
    • Zeal Generation Inc.
« Reply #54 on: Thu, 15 January 2015, 14:05:06 »
I can't really speak for GON as I don't have one of his PCBs, but SPRiT's PCB has 13 standoff holes (if you make a custom case and decide to screw all 13 in for a super rigid feel or use the Model 3 case). The acrylic plate allows for 12 of the 13 standoff supports to be screwed in. SPRiT PCB also comes factory pre-soldered with diodes and resistors, whereas normal NERD60 PCBs come only w/ the controller & other small parts soldered. Both are 1.6mm thick, SPRiT's comes ready in black and white (not sure about NERD60). Mini USB for SPRiT 60 is through hole soldered, whereas GON's is surface mounted.
That's probably the only differences I can think of off the top of my head, hardware wise.
Understandable. He's working hard on emailing each user & confirming address prior to shipping. People are getting their cases, but they may not be the vocal ones (I know since he's showed me pictures of boxed up orders ready to ship). Boxing up individual orders takes a lot more time when compared to preparing a bulk shipment. This GB however is completely separate from SPRiT's GB, as I'm fulfilling all shipments.
Thanks Zeal!
:D Be sure to post pics of the worklog!
/edit
Thanks for sharing! Not everything is pictured in there right? I'm sure I included the m.2x5 screws and lube. Also yay for fast shipping :)
Note to self: Need to buy more tape.
« Last Edit: Thu, 15 January 2015, 14:22:24 by Zeal »
Offline Dreamre
    • kbdlife
« Reply #55 on: Thu, 15 January 2015, 15:33:12 »
Thanks for the response Zeal. In terms of the re-programming of the board, how is the program that does that? I'm guessing this is also fully backlit too right?
Offline Zeal
« Reply #56 on: Thu, 15 January 2015, 16:07:06 »
SPRiT PCBs can be programmed here: http://boot.winkeyless.kr/bootMapper/
All macros / key mapping can be set with the online bootmapper. Yes, the board is fully backlit and has different lighting settings / modes (caps lock LED is off by default, as it's used as an indicator). You can also create your own custom lighting effects if you know how.
infiniti has also written a pretty nice guide explaining how to flash & program the PCB.
« Reply #57 on: Thu, 15 January 2015, 16:44:53 »
/edit
You're absolutely right, I'm not sure why I haven't included those when I took the picture! I kind of enjoyed f5'ing the DHL page to see how fast it was being shipped .. ;D
Offline Ouro
  • Laughable
« Reply #58 on: Thu, 15 January 2015, 18:22:55 »
I'm a noob but I want to build my own keyboard and this seems like a really well priced kit.
If I were to purchase this all I would need are switches to solder onto the PCB and a controller like teensy, yes?
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #59 on: Thu, 15 January 2015, 18:29:08 »
The controller is already on-board, all you'd need is a case and solder the switches and LED's if you choose.
GON NerD TKL DTA Edition
Offline Zeal
« Reply #60 on: Thu, 15 January 2015, 18:31:21 »
I offer the common 4 Cherry switches on my product page as well. The other less common switches can be arranged if I have stock. (All except for Clear & White).
Controller is already soldered onto the PCB. It uses the ps2avr, not a teensy (those are usually for hand wiring).
The only thing you'll need is a case & mini USB cable. :)
« Reply #61 on: Thu, 15 January 2015, 19:20:39 »
Three different confirmed shipping emails have got me foaming at the mouth with anticipation. So glad I get off of work early tomorrow.
Offline exitfire401
  • The Force is Re/\l
« Reply #62 on: Thu, 15 January 2015, 19:26:42 »
Alright, finally placed my order. Decided I couldn't resist doing an all clear and gold (already have springs and gold sip sockets are on the way) themed board. I'll have to figure out what to do about LEDs though. I really wanted those color shifting ones =( Once again though, thanks for the awesome GB dude.
Offline Zeal
« Reply #63 on: Thu, 15 January 2015, 20:11:36 »
It's like Amazon prime shipping, but faster! :eek:
You picked white matte plate, but mentioned doing an all clear & gold build. Will PM for confirmation & some other info.
Btw, those 2x3x4 rgb leds are really cool. Haven't been able to find any other ones in that form factor...
Offline exitfire401
« Reply #64 on: Thu, 15 January 2015, 20:14:02 »
White matte was correct. I misspoke in the post haha. I'm looking for the matte look.
Offline exitfire401
« Reply #65 on: Fri, 16 January 2015, 21:56:07 »
Wow...DHL doesn't **** around. My package is already in Ohio.
Offline Zeal
« Reply #66 on: Fri, 16 January 2015, 22:05:25 »
Not yet..That's just sending the customs info to their main sorting hub in Ohio ahead of time so it clears customs within 30mins. It'll prob arrive in Ohio around 3am EST and camp there for a while during the weekends til midnight Monday and start moving again. :D If you had ordered earlier, I prob could have packed your order before the same day cut-off time on Thursday. :P
Offline exitfire401
« Reply #67 on: Fri, 16 January 2015, 22:10:36 »
No problem haha. I was just surprised to see anything that close in the shipping info. I'm in no rush anyways. Won't have the case or switches for the board until March anyways.
Offline rand77
« Reply #68 on: Sat, 24 January 2015, 21:02:28 »
Just started assembling everything today.  Unfortunately ran into a few issues.  A few keys are completely non-functional ("e" , "backspace" and "left-alt").  Also there seems to be other random issues where keys sometimes continually registered (e.g. "eeeeeeeeeeeeee") and random delay when pressing other keys.
Checked the diodes for the non-functional keys, and the they seem ok (~0.65V forward voltage drop).  The switches are mx blacks with Sprit 50g springs.  Below are the pics of my soldering job, it doesn't looked like I shorted anything :)
http://i57.tinypic.com/534dqw.jpg
Does anyone know anything I can try?
« Last Edit: Sat, 24 January 2015, 21:28:09 by rand77 »
Offline Zeal
« Reply #69 on: Sat, 24 January 2015, 21:17:29 »
Hmm, could you provide a picture of the solder joints?
Offline rand77
« Reply #70 on: Sat, 24 January 2015, 21:23:38 »
Having issues with imgur (I don't think it accepts a 36 MP image).  Here it is on dropbox:
https://www.dropbox.com/s/raltnw7x6i1zoy2/DSC00137.JPG?dl=0
Offline Zeal
« Reply #71 on: Sat, 24 January 2015, 21:56:22 »
Hard to tell with the lighting, but some joints could use some reflowing. Solder joints should look like nice shiny "volcanos". Some are a bit too low, and some look like the PCB wasn't heated along with the pin.
Could you try reflowing some of the affected keys and provide some closer up shots of them?
Plugging in the keyboard into a USB hub could also sometimes cause problems.
Offline rand77
« Reply #72 on: Sat, 24 January 2015, 22:07:16 »
Thanks, I'll definitely re-do some of the solder joints tomorrow and see what happens.  Hopefully it fixes the issues.
Offline rand77
« Reply #73 on: Sun, 25 January 2015, 20:24:52 »
I re-soldered some of the faulty joints today, and re-flowed any solder joint that did not look good.  It turns that one pin on the "e" key wasn't soldered correctly.  The other keys were fixed by flashing the correct keymap [keymain_NKRO.hex and keymap_part(thumb)(face)(XTen).hex].
However, sometimes I still get repeated key presses, almost as if the key is stuck (e.g. "eeeeeeeeeeeeee").   This seems to be occurring on many different keys, and doesn't appear to be specific to any one key . Curiously, these problems ONLY occur over USB, PS2 is working just fine.   Also, I noticed that the key repeat rate is incredibly fast when holding down a key using both  ps2 and usb.
Pictures of the soldering job and complete build are here:
http://imgur.com/a/B76dT
Could it be a switch debouncing issue?
Offline Zeal
« Reply #74 on: Sun, 25 January 2015, 20:35:58 »
That's odd. Sounds like you have the setting where Ducky keyboards can force a faster repeat rate/delay. Have you checked your keyboard repeat delay / repeat rate under CP?
I don't think it's a debouncing issue. You can double check with EK switch hitter though: https://elitekeyboards.com/switchhitter.php
Offline rand77
« Reply #75 on: Sun, 25 January 2015, 21:04:29 »
Just tested with EK switch hitter, it seems to be OK for the most part.  I've only seen it detect one instance of chatter, and I cannot seem to repeat any more instances.
I've played around with a few lower levels for repeat delay / repeat rate.  Lowering the repeat rate certainly has made the keyboard appear much more "normal".
The repeated key presses still occur, but slower.  Whenever this occurs it locks out all other keys, and you need to repress the repeating key for it to stop.
Offline rand77
« Reply #76 on: Mon, 26 January 2015, 10:55:55 »
Good news!  It seems the key repeat issue is only a problem when using my USB 3.0 ports.  It seems there might be an incompatibility with the USB 3.0 controller on my motherboard.   I will try to update the drivers for the USB controller.
If I plug the keyboard into a USB 2.0 port it works fine.   They keyboard is working perfectly now.
Offline Zeal
« Reply #77 on: Mon, 26 January 2015, 11:17:06 »
That's great to hear! Strange that your USB 3 ports are causing issues. I plugged in my board into one and didn't notice any problems.
Offline Defect
« Reply #78 on: Sun, 01 February 2015, 08:08:41 »
10/10 would buy from Zeal again.
Offline Ouro
  • Laughable
« Reply #79 on: Thu, 05 February 2015, 07:41:04 »
Does this pcb support leds on the pcb like nerd?
Offline Zeal
« Reply #80 on: Thu, 05 February 2015, 10:09:56 »
Do you mean surface mount LEDs between the switch rows? If so, no it doesn't.
The PCB does support in-switch LEDs however.
Offline impreziv
« Reply #81 on: Wed, 25 February 2015, 12:15:46 »
Any chance you'll do another run of this? I'd really like to get my hands on a white PCB and clear plate, but it seems that they've both sold out. I feel like that setup would work best with my blue Tex case  ;D
Offline Zeal
« Reply #82 on: Wed, 25 February 2015, 12:41:39 »
What's remaining is all that's left. I do have plans to run a similar GB or a full set w/ another PCB later on though.
Offline bazh
« Reply #83 on: Wed, 25 February 2015, 13:48:02 »
dammit can I get some gold plate stab only? :'( my 3 pcb have been on hold just because I hadn't found some of these :(
HHKB Pro2 white
Newbie again
Offline Alastoris
« Reply #84 on: Fri, 06 March 2015, 13:53:51 »
I look forward to your next run!
Offline random_rockets
« Reply #85 on: Wed, 11 March 2015, 18:43:58 »
Just got my board today with some japanese kit kats :D 10/10 customer service and shipping was quick
Offline wlhlm
« Reply #86 on: Sun, 12 April 2015, 04:26:48 »
Not sure if that's the right place here, but I'm looking for a white matte 5mm plate. Are there any leftovers? Or is there another place I can look for them?
