Author Topic: Quick question for the Poker 2 owners  (Read 2164 times)
Offline Rainman
« on: Tue, 30 December 2014, 17:00:29 »
Hi guys, I'm looking to get my hands on my first Poker 2, but nowhere am I able to find a black poker 2 with blue switches. Now, I traced a white cased which I'm kinda going to put a custom set of keycaps and a aluminum casing. The only problem is that white plate below the keycaps which I'm afraid is going to be visible and I don't want the white to "shine" below black caps. It visible when the caps are on the board? If yes, can this plate at least be covered or removed? Hope I didn't complicate things too much and you get what I'm trying to ask :)
Rocking Poker 2 with vintage MX Blacks
Offline Hypersphere
Offline Rainman
Re: Quick question for the Poker 2 owners
« Reply #2 on: Tue, 30 December 2014, 17:05:07 »
I don't want to have this
Since I can't edit my previous post (probably because the lack of permissions) I have to type it this way ;)
Offline Ngt
« Reply #3 on: Tue, 30 December 2014, 17:07:45 »
I got mine from amazon.co.uk but since I'm on my phone ATM I don't know where you are from.
Offline Rainman
« Reply #4 on: Tue, 30 December 2014, 17:08:30 »
Try qtan. Here is a link to Poker 2 on his store:
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-br/kbc-poker-2-61keys-mechanical-/lid=35050923
Thanks, I already checked his Ebay store  (http://stores.ebay.com/esportsgamingequipments/) and I don't think the black cased with mx blues is available. Maybe his store @ Vendio are different entities.    :-\
« Reply #5 on: Tue, 30 December 2014, 17:10:02 »
They're exactly the same. They don't update together though, so sometimes the vendio will have more stuff than ebay.
Offline Rainman
« Reply #6 on: Tue, 30 December 2014, 17:27:51 »
Thanks, found the backlit poker 2 but the thing is... Amazon doesn't ship to my Bosnia and Herzegovina. :(
I emailed qtan (found contact at his vendio store) two days ago about the stock status, unfortunaltey he does not reply. I'm a  bit hesitant about buying outside of ebay to be honest. Hope its safe to buy from his store directly...?
« Last Edit: Tue, 30 December 2014, 17:33:36 by Rainman »
Offline Hypersphere
« Reply #7 on: Tue, 30 December 2014, 17:49:38 »
I have bought several items from qtan. In fact, I am typing on my Poker II that I bought from the qtan store recently -- it just arrived yesterday, in fact. It takes a while for things to be shipped from China, but it arrived before I expected. You can pay via PayPal, which has always worked for me without any issues.
