Author Topic: [IC] CF-LX Ultra-light Carbon Fiber 60% Case  (Read 63106 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: [IC] CF-LX Ultra-light Carbon Fiber 60% Case
« Reply #150 on: Sun, 12 April 2015, 23:20:10 »
Perfect. I just bought a HHKB so this would look awesome with it :D Will definitely buy.
Oh no, sorry, this would only work with MX, it's just in the HHKB layout
Offline ccarlitos2
« Reply #151 on: Sun, 12 April 2015, 23:24:46 »
ohhhhh.. welp. Still gonna buy one for my poker ii :D
Offline FrostyToast
  • Litshoard
« Reply #152 on: Thu, 16 April 2015, 10:47:34 »
Also is anyone here interested in an all-acrylic vergo? Like one of these just slightly edited
Just so no one gets their balls busted when it happens, I am planning to do a full cnc Vergo buy once some things are finalized.
It will however be quite a while until anything gets started for my buy. Even GB organizers have to play the waiting game.
« Last Edit: Thu, 16 April 2015, 10:56:35 by FrostyToast »
Quote from: elton5354
« Reply #153 on: Thu, 16 April 2015, 12:32:04 »
Just looked this up, depending on my money situation when it happens I'll probably be in.
Offline Melanic
« Reply #154 on: Sat, 18 April 2015, 09:23:35 »
Just wondering if there's any update with this. Been quite quiet the last week.
Offline cmadrid
« Reply #155 on: Sat, 18 April 2015, 18:12:00 »
I'd like something like this but not split in half.. which I guess is the point of the thing >_<
Offline FrostyToast
  • Litshoard
« Reply #156 on: Sat, 18 April 2015, 18:16:40 »
Well one of the features of this is that you can put the two halves together like a normal board.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #157 on: Sat, 18 April 2015, 18:17:26 »
well you can fit the two halves back together ;)
Offline cmadrid
« Reply #158 on: Sat, 18 April 2015, 20:20:46 »
Yeah, and my 6 year old can make off with the cable or half the keyboard :o
Plus, I don't like the whole extra cable thing.. but I do like the look of the board while the two halves are pushed together!
Offline Giorgio
« Reply #159 on: Sat, 25 April 2015, 04:43:21 »
I would also an option that allows the use of an aluminium plate. Your kit would be then made of a rectangular frame to be put on the top of the aluminium plate), mid layer, bottom layer.
« Reply #160 on: Sat, 25 April 2015, 13:31:13 »
What?
You are describing an entirely different case, if you want this case in Al just order it from Big Blue Saw in Al.
Offline Giorgio
« Reply #161 on: Sat, 25 April 2015, 13:37:47 »
I was suggesting an alternative, design, only the top plate would be in al, eventually with a carbon fibre bezel, everything else could be identical. Anyway I think that big blue saw charges $70 for a plate.
Offline Melanic
« Reply #162 on: Tue, 28 April 2015, 12:46:41 »
Just wanted to ask if there has been and progress on this project.
« Reply #163 on: Tue, 28 April 2015, 12:57:57 »
AFAIK it's ready to go. Hwood just needs to launch the GB page.
Offline ccarlitos2
« Reply #164 on: Tue, 28 April 2015, 13:08:22 »
Can't wait!
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #165 on: Tue, 28 April 2015, 21:28:51 »
Well I still need to get pricing on the mid piece in carbon fiber and the happy layout plate. The big blue saw guy was usually really quick to respond but it's been like 10 days, I've emailed him twice, I'll give it another day or so before I try and speak with someone else
Offline Ngt
« Reply #166 on: Wed, 29 April 2015, 01:20:56 »
How long do you want the GB to last?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #167 on: Wed, 29 April 2015, 06:05:26 »
I'll probably leave it up for 2-3 weeks
Offline Ngt
« Reply #168 on: Wed, 29 April 2015, 06:10:03 »
Alright thanks for the info.
Offline azhdar
  • Praise the AZERTY god
« Reply #169 on: Wed, 29 April 2015, 07:14:05 »
I'm having a hard time figuring out based on this pictures but would it supports both winkey  and winkeyless bottom row ?
Azerty Propagandiste
Offline FrostyToast
  • Litshoard
« Reply #170 on: Wed, 29 April 2015, 07:21:31 »
Yes.
That is why the cutouts at the bottom are wider.
Offline azhdar
« Reply #171 on: Wed, 29 April 2015, 07:28:09 »
Yes.
Thanks.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #172 on: Wed, 29 April 2015, 09:34:17 »
Yup
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #173 on: Wed, 29 April 2015, 20:47:19 »
Alright, we're all set to go with the GB. Here's the final pricing:
Standard case (including standoffs and screws): $78
Acrylic mid piece: $22
Happy plate: $65
A carbon fiber mid piece ended up being something like $125, so that's a no go unfortunately. I'm thinking to at least match the color somewhat I'll do a grey acrylic.
Gotta do work and stuff right now, I won't be able to work on a thread tonight. If anyone wants to work on a pretty one for me though ;)
« Last Edit: Wed, 29 April 2015, 20:51:13 by hwood34 »
Offline exitfire401
  • The Force is Re/\l
« Reply #174 on: Wed, 29 April 2015, 20:52:32 »
Happy plate: $65
Awesome! Still well within my price range.
Offline Melanic
« Reply #175 on: Thu, 30 April 2015, 12:01:37 »
Happy plate: $65
Dang, that carbon fiber mid piece costs a lot more than I thought it would have.
Is that HHKB plate price for just the top?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #176 on: Thu, 30 April 2015, 12:02:35 »
Happy plate: $65
Yep. The plate accounts for most of the cost, the bottom is really just the cost of material
« Reply #177 on: Fri, 01 May 2015, 00:57:45 »
The plate supports every layout listed here. https://geekhack.org/index.php?topic=41464.msg828888#msg828888
Happy plate: $65
I can get a render sorted after I move all my crap back into my room.
Offline Ngt
« Reply #178 on: Sun, 03 May 2015, 07:17:51 »
Is it possible to paint a CF case?
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #179 on: Sun, 03 May 2015, 10:13:14 »
Yes, people paint carbon fiber cart parts all the time but unless you're going for a lightweight case, I don't see the point in choosing a carbon fiber case to paint rather than a steel/aluminum one.
GON NerD TKL DTA Edition
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #180 on: Sun, 03 May 2015, 10:15:49 »
Offline Ngt
« Reply #181 on: Sun, 03 May 2015, 11:13:20 »
I hesitate with a Nerd NS 60 but this one is cheaper and I heard as well that Gon is quite busy atm and most orders are delayed by a lot. That's why I asked for the color.
