Author Topic: Are there any all white full sized keyboards?  (Read 2639 times)
Offline jeff1k1
« on: Wed, 31 December 2014, 17:53:03 »
Are there any completely white keyboards? Are there any keyboards similar to this one - https://www.massdrop.com/buy/varmilo-mechanical-keyboard - with a full size white body? And a non related question; how much would my battlefield 4 razer blackwidow sell for?
Offline Tactile
Re: Are there any all white full sized keyboards?
« Reply #1 on: Wed, 31 December 2014, 18:16:48 »
Keycool has one: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=405
But you're right that there aren't very many and most white ones are for macs.
REΛLFORCE
Offline LechnerDE
« Reply #2 on: Wed, 31 December 2014, 18:19:36 »
Rosewill also has white cases e.g.
http://www.newegg.com/Product/Product.aspx?Item=N82E16823201052&cm_re=rosewill-_-23-201-052-_-Product
But the quality of Rosewill Keyboards is controversial...
Offline Xonar
  • Cathode Ray Tubes
    • Winnebago
« Reply #3 on: Wed, 31 December 2014, 18:59:45 »
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=970
Also can't forget this, but it's probably not what you're looking for: http://matias.ca/tactilepro4/
IBM Model M SSK Industrial (Mopar) | Ellipse Model F77 (Industrial) | IBM Model F XT 5291 Bigfoot x2 | Unicomp UN4KPHA JP Spacesaver M | IBM Model M 3270 APL 122-Key | SHARP X68000 | Silicon Graphics AT-101 |  Samsung TH-5539 FAME Blue Alps | IBM Japanese Pingmaster | IBM Model M 1392595, 6/4/1990 | IBM Model M 1391401, 2/2/1988 | Lexmark-branded 1398601 Model M, 8/18/1995 | Apple Extended Keyboard II | Unicomp UB40T5A 122-Key, 5/20/2011 | Sun Type 4 | Sun Type 5c | DEC LK-401AA
Offline jeff1k1
« Reply #4 on: Wed, 31 December 2014, 19:25:47 »
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1064 Is this keyboard any good? Sorry I'm kinda new to mech keyboards.
Offline Valen
« Reply #6 on: Wed, 31 December 2014, 23:30:50 »
Filco Majestouch 2 come in all white.
« Reply #7 on: Thu, 01 January 2015, 00:06:25 »
That is a sort of slightly off white, IIRC.
Offline jalaj
« Reply #8 on: Thu, 01 January 2015, 03:59:50 »
there are all white Leopold FC750R keyboards on eBay with PBT keycaps
Offline Candyflip
« Reply #9 on: Thu, 01 January 2015, 05:57:57 »
OP wants a full sized board.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #10 on: Thu, 01 January 2015, 10:35:13 »
I believe you can order the Unicomp Classic white with brilliant white keycaps.  (I don't know if that qualifies)
Offline Flyersfan1
  • Hi!
« Reply #11 on: Thu, 01 January 2015, 10:43:37 »
Quote from: Photekq
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #12 on: Thu, 01 January 2015, 14:23:44 »
Yeah I think the Ducky ones are the only ones that have been really 'pure' white done a few times in limited editions of one sort or other. Most others are more cream colored or a very light cold grey in reality. If that is fine then it opens the options up a little more.
« Reply #13 on: Thu, 01 January 2015, 17:18:13 »
My older KeyCool 87 is whiter than white, including its PBT keycaps.
I believed they were available in full size too.
Not sure about the newer Kailh-based KeyCools.
Offline Snowdog993
« Reply #14 on: Fri, 02 January 2015, 08:19:19 »
I think the original poster said full size kb?
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #15 on: Fri, 02 January 2015, 08:40:22 »
Noppoo makes a full sized white capacitive keyboard.
https://geekhack.org/index.php?topic=62895.0
