Author Topic: switches sampler  (Read 9666 times)
Offline Giorgio
switches sampler
« on: Fri, 02 January 2015, 16:18:02 »
I'm looking for a cherry switch sampler, but they all seem really overpriced, and none of them include the cherry compatibles switches.
This is particularly annoying considering that one of the users of this forum was selling a kit with at least 30 switches for 25 eur....
Can you please suggest me a tester that is not a ripoff?
thanks
http://www.cmstore.eu/cm-storm/keyboards/mechanical-key-switch-tester/
https://www.maxkeyboard.com/cart
http://www.wasdkeyboards.com/index.php/wasd-sampler-kit.html
Offline drewba
Re: switches sampler
« Reply #1 on: Fri, 02 January 2015, 16:37:04 »
The coolermaster tester can be refunded IF you purchase a coolermaster keyboard. No opinion on the WASD tester except I believe the switches are all loose (no base).
I have the maxkey switch tester which is nice to put the switches in whichever configuration you prefer as you can place each different switch where you like in the base. Some assembly required :p
I wish they were a bit cheaper but I still don't regret buying mine, it's very beneficial to compare all MX  switches side by side.
Offline tbc
« Reply #2 on: Fri, 02 January 2015, 16:40:18 »
switch testers are always going to be expensive.
which cherry compatible ones are you looking for?  massdrop has a tester with gateron, but not kalih.
i would suggest you buy any one and then resell.  except for wasd, they don't have a plate, just the loose switches
Offline Giorgio
« Reply #3 on: Fri, 02 January 2015, 17:18:25 »
I'm not looking for a particular alternative to cherry, I'm just curious to se what the other brands can do.
I see some money earning potential for any member of geekhack who can put together a sampler at a decent price....
« Reply #4 on: Fri, 02 January 2015, 18:18:03 »
Welcome to Geekhack!
http://www.ebay.com.au/itm/Mechanical-Keyboard-Switch-Tester-Sampler-number-keypad-Cherry-MX-Razer-Gateron-/291337983177?pt=AU_Input_Peripherals&hash=item43d518d4c9
Or make your own - you can get mechanical keypads (I have a 4x4 one) from eBay, and one of each switch you want to test.
Offline Liar
« Reply #5 on: Fri, 02 January 2015, 19:47:09 »
One on MD for 25$ + S
https://www.massdrop.com/buy/varmilo-switch-tester
Can also choose a Gateron version
Offline shut up
« Reply #6 on: Fri, 02 January 2015, 21:13:56 »
None of them are especially cheap it seems, I've looked out for a cheap one also. It is good to get a feel for keyboard before buying though.
IBM Model M 42h1292 (Bolt mod, but still broken Yaaaayyyy) | Adesso Mkb-125b MX blues | Alienware Tactx (D0me5.)
Offline MGH
« Reply #7 on: Fri, 02 January 2015, 21:17:45 »
The Gateron one on massdrop is good for you then
Offline Lu_e
« Reply #8 on: Fri, 02 January 2015, 23:13:34 »
The Varmilo Cherry MX tester is pretty cool. You get all the rare Cherry switches like Greens, Clears, Tactile AND Linear Greys...
Tempted to get one
Just say NO to ABS keycaps
Offline Giorgio
« Reply #9 on: Sat, 03 January 2015, 04:15:05 »
That tester is nice, I wonder why he didn't include some orings....
Also, maybe that an aluminum plate is not the best way to understand the sound of a switch...
Offline tbc
« Reply #10 on: Sat, 03 January 2015, 04:42:58 »
most keyboards have a metal plate.
are you bothered brcause it's aluminum?
Offline spiritistz
  • Daily Driver: RF 87U 55g
    • http://bgm.tv/
« Reply #11 on: Sat, 03 January 2015, 04:54:31 »
As far as I know, there isn't any company still making linear grey switch keyboard are they?
Filco NINJA Brown Switch for sale.
Offline Dihedral
  • Mostly Harmless
« Reply #12 on: Sat, 03 January 2015, 05:06:09 »
WHy not? AFAIK a lot of boards use alu plates.
Offline davkol
  •  Post Editing Timeout
« Reply #13 on: Sat, 03 January 2015, 07:24:54 »
There has never been one AFAIK, except some limited editions, custom orders or whatever. Greys (and greens) are originally *spacebar* switches.
In regards to the OP, I don't see the point. Typing is a different experience from pressing individual switches, especially if you have to hold stabilized modifiers from time to time, and both feel and sound are affected not only by mounting, but keycaps and the user (mood, time, setting/environment) as well. Moreover, different kinds of keys usually require some getting used to. Get a PCB-mounted keyboard and some harvested switches/stems&springs and keycaps instead, and play with that a bit.
Offline Liar
« Reply #14 on: Sat, 03 January 2015, 10:06:57 »
The Varmillo keyboards on MD are offered with Linear or Tactile Greys
Offline 0100010
  • Not Sure
« Reply #15 on: Sat, 03 January 2015, 10:48:59 »
I built my MX tester for $35.
$8 for the plate - http://www.ebay.com/itm/140380863344
$17 for the switches - http://mechanicalkeyboards.com
$10 for caps : http://xkeys.com/accessories/Keycaps.php
Offline Giorgio
« Reply #16 on: Sat, 03 January 2015, 11:48:25 »
That is a wonderful solution, too bad that the switches are sold in packs of five, of the same type.
Offline Giorgio
« Reply #17 on: Sat, 03 January 2015, 14:15:52 »
Well, now I know one more thing :-) ...
Offline 0100010
  • Not Sure
« Reply #18 on: Sat, 03 January 2015, 15:51:38 »
Not if you ask.  :thumb:
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #19 on: Sat, 03 January 2015, 16:41:58 »
try asking in the free stuff thread, there are plenty of people willing to send a switch or two for the cost of shippjng
Offline Giorgio
« Reply #20 on: Sun, 04 January 2015, 05:20:11 »
Thank you LIAR and LU_E, I purchased the massdrop tester
I liked very much the solution of 0100010 but the delivery cost were killing me, since I live in Italy
I will also purchase some additional switches from aliexpress.com, it seems to be the cheapest place for that kind of purchases, since the cost is about 1$/piece including the delivery.
You are such a wonderful community!  :cool:
Offline davkol
« Reply #21 on: Sun, 04 January 2015, 05:22:28 »
Isn't 7bit cheaper at €0.65 per switch?
Offline Giorgio
« Reply #22 on: Sun, 04 January 2015, 09:19:45 »
What is the address of the 7bit website?
Offline davkol
« Reply #23 on: Sun, 04 January 2015, 09:25:18 »
Deskthority Marketplace
