Author Topic: [Ebay] 11 ibm/unicomp m 122 key  (Read 2352 times)
Offline Touch_It
« on: Fri, 02 January 2015, 22:41:34 »
Currently at $209 with free shipping.  Assuming you get it around that price, I would say it is a decent deal.
Edit: forgot link
http://pages.ebay.com/link/?nav=item.view&alt=web&id=301462956836
Edit 2. If I'm not mistaken is the one with the square metal logo a first gen?
Edit 3. It also appears one might be a standard model m.  The one on the right third from bottom
« Last Edit: Fri, 02 January 2015, 22:45:49 by Touch_It »
Offline ezrahilyer
Re: [Ebay] 11 ibm/unicomp m 122 key
« Reply #1 on: Fri, 02 January 2015, 22:45:29 »
I thought about bidding. It was a buy-it now I think he must have converted it to an auction.
I could use some more M122s to build.
Offline Touch_It
« Reply #2 on: Fri, 02 January 2015, 22:53:17 »
You should!  Means I'm not tempted to bid on stuff I don't need and I get to see more of your work!
« Reply #3 on: Sat, 03 January 2015, 08:07:11 »
Square metal badge on right does not mean first generation, although it would probably be an easier mod for an F-122 replacement than the later iterations.
Look for the large button on the side of the case and large 2-stage legs.
- D Trump 2026-10-24
Offline Touch_It
« Reply #4 on: Sat, 03 January 2015, 09:03:22 »
Ahh got it.  Felt like I shoulda known that already.  Nothing better than humble pie, lol.
Offline ezrahilyer
« Reply #5 on: Sat, 03 January 2015, 09:48:14 »
I did end up getting this lot, so expect some more M122s coming from me over the next month or so.
PM if you want any custom jobs done, I can do ISO to ANSI and hybrid ANSI/ISO
I can split keys and turn the num-pad into a matrix layout, or make it more standard (2u + button)
-ezra
Offline berserkfan
« Reply #6 on: Sat, 03 January 2015, 11:01:02 »
Wow, Ezra, good for you and good for us!
I'm not buying Ms anymore, but your low cost basis will really make Ms affordable to many more people.
Offline Touch_It
« Reply #7 on: Sat, 03 January 2015, 11:46:45 »
As always I'll definitely be temped.  Maybe for my birthday in April :).
« Reply #8 on: Sat, 03 January 2015, 22:24:01 »
There even exist square metal badge 122-key model Ms with the "small" feet like the 1391401 has, so you have to be really careful without a picture of the back if you are looking for one to replace the top cover of your 122-key model F with.
edit: clarification (see below)
« Last Edit: Sun, 04 January 2015, 23:45:25 by dorkvader »
« Reply #9 on: Sun, 04 January 2015, 09:25:59 »
There even exist square metal badge model Ms with the "small" feet like the 1391401 has
I thought that this was strictly about the 122-key models.
Yes, the 1390131 is my favorite variant and is just like the early 1391401 except for square metal badge on right instead of oval plastic label left.
