Author Topic: RedScarf III (USA ONLY!)  (Read 90812 times)
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: RedScarf III (USA ONLY!)
« Reply #250 on: Fri, 15 May 2015, 11:42:51 »
Sorry I didn't notice that. If it were me... I would probably just go to work on it with a file to fix it.
ALSO:
I found a pair of feet under the sofa while I was cleaning up. I only assume it fell out of a box while I was packing it up. So... I have no idea who those would belong to so please let me know.
« Last Edit: Fri, 15 May 2015, 11:44:22 by IvanIvanovich »
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #251 on: Fri, 15 May 2015, 11:50:52 »
Selling/Transferring my order, pm if interested:
8mm bezel (Gray)
Plate (Red)
Feet (Gray)
$174.72 USD (CONUS ONLY)
SOLD
Yo Ivan... I picked up this order and didn't get gray feet...
So if they're grey I would guess they belong to me  :p
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #252 on: Fri, 15 May 2015, 11:57:47 »
ALSO:
Ivan I PM'd you about this GB. Please reply back to me thank you. :thumb:
« Reply #253 on: Fri, 15 May 2015, 12:21:58 »
8mm bezel (Gray)
Plate (Red)
Feet (Gray)
SOLD
OK then, mystery solved. I will post them out tomorrow.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #254 on: Fri, 15 May 2015, 13:40:07 »
8mm bezel (Gray)
Plate (Red)
Feet (Gray)
SOLD
DOH, I lied... just checked and they are on it...  :-[
Those belong to someone else!!!
Offline Jixr
« Reply #255 on: Fri, 15 May 2015, 14:06:25 »
they are not mine, i got my feet.
( process of elimination yo )
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #256 on: Fri, 15 May 2015, 14:32:06 »
soldering while on conference calls with client's like a boss, multi-tasking ftw, quickest keyboard build ever. made sure all switches are level
forget the plate, i aint got the time to file that **** down, hell no,
now its time to program this thing, pop some switches caps on it and use the thing
« Last Edit: Fri, 15 May 2015, 14:58:41 by Glod »
Offline Glod
    • YouTube Channel
« Reply #257 on: Fri, 15 May 2015, 14:37:59 »
i found a tmk fork for this
https://github.com/kairyu/tmk_keyboard_custom/tree/master/keyboard/RedScarfIII
all i need is for someone to tell me how to get this to go into program mode bootloader, i dont see a button on it.
edit: it doesnt look like the button was soldered on LOL, looks like i have to bridge it with a wire.
« Last Edit: Fri, 15 May 2015, 14:44:55 by Glod »
Offline blighty
« Reply #258 on: Fri, 15 May 2015, 14:46:16 »
now its time to program this thing, pop some switches on it and use the thing
Looking good!  It was a blessing in disguise with your wonky plate.  You would of had clearance issues with the bent spacebar wire.  At least I had issues when I tried to use a 6.25u wire from a Cherry board.  Luckily, I did a test fit before I put it together/soldering and noticed it hitting.
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline Glod
    • YouTube Channel
« Reply #259 on: Fri, 15 May 2015, 14:55:59 »
Yeah this 6.25 wire was already made i had in my stab pile, i think it came from a poker, i could have made a new wire if there was clearance issues, i have some hobby wire i've used to make 7x wires, but I have very little spare time anymore and if i rush making a stab wire I could lose an eye, its a violent process to hand make them.
Offline Spopepro
« Reply #260 on: Fri, 15 May 2015, 15:08:28 »
Glod:
There has been some awesome work done on documentation and translation in the thread here: https://geekhack.org/index.php?topic=69282.0
Including a PDF on flashing.
Offline Glod
    • YouTube Channel
« Reply #261 on: Fri, 15 May 2015, 15:27:18 »
cool, I will give it a try
edit: this actually looks more complicated than just doing it the normal TMK process, maybe i am wrong....it just seems like it
« Last Edit: Fri, 15 May 2015, 15:29:28 by Glod »
Offline Jixr
« Reply #262 on: Fri, 15 May 2015, 16:31:16 »
Its not that hard, i'm pretty new to programming keyboards but figured it out.
The only thing i've not been able to do is figure out how to control backlighting via FN keys. I know its possible, ( stock firmware does it ) i just cant get it to work for me
Also, you'll probably want to put something under your pcb, mine ( plateless ) has a lot of flex it in.
Offline Glod
    • YouTube Channel
« Reply #263 on: Fri, 15 May 2015, 17:59:08 »
GOT IT, PROGRAMMED!
« Last Edit: Fri, 15 May 2015, 20:23:36 by Glod »
« Reply #264 on: Fri, 15 May 2015, 19:33:46 »
HEhehe... Yeah I put on the feet on all the orders (except those who wanted none), but a few people ordered more than one set of feet, I guess for a different look? Either I missed getting a set in somewhere or I was sent too many?
Making choices to how I want to build it is so hard! I can't decide what switch type I want to put on (Cherry MX or Gateron?), or in which layout I want to build it. I kind of want to build it in modified ISO... but then I will be pretty much stuck with which cap sets I can use.
Offline Glod
    • YouTube Channel
« Reply #265 on: Fri, 15 May 2015, 20:24:31 »
edit: btw Jixr i took your advice and put something behind the pcb, placed stick-on rubber feet, the perfect height on the floor of the case all over, squishy to conform, no bend at all in pcb :)
« Last Edit: Fri, 15 May 2015, 20:40:25 by Glod »
Offline Jixr
« Reply #266 on: Sat, 16 May 2015, 11:42:10 »
yeah i did the same thing, not quite as solid as i'd like, but it cuts the flex by a good bit. Though I do have a plate coming for this eventually, hopefully that will beefen it up.
Offline Glod
    • YouTube Channel
« Reply #267 on: Sat, 16 May 2015, 16:26:28 »
i put like 12 of them in there, without being squished they are slightly taller than the standoffs, this keyboard is the most solid PCB mount board i have ever used, I've had plate mount boards flex more than this one and you really have to press down hard for it to flex
And the gateron blacks feel fantastic with GMK. very smooth switches. this is one of my favorite boards out of 20 or so i own (lol), even with the cheaper quality from china (racist?). thanks ivan
Offline Spopepro
« Reply #268 on: Mon, 18 May 2015, 11:25:55 »
Finally got mine built.
PCB could be thicker... but otherwise has some nice, thoughtful touches.  Acrylic case is really nice--I like it a lot.  Bezel is bad, and I'll be thinking about making something to replace it.
The software is awesome.  The keymap generator with the TMK and the LUFA print-loader is brilliant.  It compelled me to do some firmware customization of my own... so now I have a broken keyboard.  Oh well... time to see if I can fix this.
