Author Topic: Reinforce cherry MLs with plate?  (Read 1356 times)
Offline ianxblog
  • no
« on: Thu, 08 January 2015, 15:23:58 »
I have a Cherry g84-4100
I know Cherry MLs doesnt support plate mounting, but could you add a thin aluminum plate beneath the pcb to reinforce, or some kind of steel, obviously covering it with some aislant to prevent short-circuits.
You can find pics of the kb disassembled here http://deskthority.net/wiki/Cherry_G84-4100 and a video here https://www.youtube.com/watch?v=d5nScpSnec4
Re: Reinforce cherry MLs with plate?
« Reply #1 on: Thu, 08 January 2015, 15:26:04 »
You might find this interesting
https://geekhack.org/index.php?topic=67343.0
« Reply #2 on: Thu, 08 January 2015, 15:38:51 »
You could do it but it'd would have to be custom designed.
Offline FrostyToast
  • Litshoard
« Reply #3 on: Thu, 08 January 2015, 15:40:56 »
I'm guessing you could either add something very thin underneath, although I don't know how thin it would have to be to not interfere.
Or alternatively, you could have a possibly thicker plate that goes around the switches.
Quote from: elton5354
Offline SuperBobKing
« Reply #4 on: Thu, 08 January 2015, 15:55:07 »
You could just cut/fold some paper to the right size and stick it between the case and pcb. It is really cheap and shouldn't take too long. Cutting multiple layers would probably be best, if you fold it it would take less time but I don't think it would be solid enough. Your cuts don't need to be precise. Plus it isn't conductive so no shorts to worry about.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #5 on: Thu, 08 January 2015, 17:09:17 »
You could try something like shelf liner
