Author Topic: Keycaps for Novatouch  (Read 9052 times)
Offline Neowess
  • Release The Kraken!
« on: Thu, 08 January 2015, 21:09:04 »
I managed to score a brand new CM Novatouch through a trade and I'm thinking of a side printed keycaps set for it. I did some research and figured that I need an MX compatible ANSI set that's OEM profile. Is that correct? Suggestions are welcome since I'm just starting with all this keyboard science :)
Offline billnye
  • ability man
Re: Keycaps for Novatouch
« Reply #1 on: Thu, 08 January 2015, 21:13:10 »
If you got a normal US layout board, ANSI will be the caps you need. It isn't necessary to have OEM profile. There are many great profiles to try like Cherry, SA and DSA.
Check out the classified and group buy section of the forum to find some nice cap sets! There are a few new group buys starting soon for some pretty sweet sets ^-^
Welcome to geekhack!
« Reply #2 on: Thu, 08 January 2015, 21:13:45 »
You can use whatever profile you prefer.
There are some nice thick pbt black side print cherry profile caps on ebay sold by widebasket.
Offline Neowess
« Reply #3 on: Thu, 08 January 2015, 21:29:37 »
Do you have a link for the eBay listing please?
Found it lol... Time for bed I guess  ;D
« Last Edit: Thu, 08 January 2015, 21:31:20 by Neowess »
Offline crazystu
« Reply #4 on: Thu, 08 January 2015, 22:18:10 »
OEM profile is best for the Novatouch as the key-caps should be tall enough to clear the plate when you bottom out.
If you get a Cherry/Low profile set, you may need to use the included o-rings to increase the key height (these will do nothing to dampen the sound, nor will they reduce travel).
My Vortex PBT Cherry profile set clacks against the bottom of the plate on some rows, which sounds and feels bad (I have not yet tried it with o-rings, but I've heard they will help).
Offline Neowess
« Reply #5 on: Thu, 08 January 2015, 23:17:48 »
That's good to know. Thanks a lot! I have to do some homework to find the best online stores / people who sell keycap sets lol. I really want a stelth look with side-printed keycaps, which will help me learn to touch-type before I switch to blanks  :p
Offline Oobly
« Reply #6 on: Fri, 09 January 2015, 04:31:02 »
Read this post: https://geekhack.org/index.php?topic=65821.msg1542628#msg1542628
With the Novatouch it's not so much about the profile height as it is about the skirt and crossbar heights compared to the length of the keycap stem.
From what I can tell, DCS profile should fit without impacting, but I don't have a Novatouch, so I can't be certain.
tldr; Any ANSI Cherry MX compatible keycap set will fit, but for some you may need to use orings to raise the whole keycap so it doesn't impact the plate or switch casing. These will not affect the key travel or feel.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline crazystu
« Reply #7 on: Fri, 09 January 2015, 18:39:45 »
Ah you're correct. That's a great post explaining when to use o-rings on the Novatouch, and what they're for.
Offline Neowess
« Reply #8 on: Fri, 09 January 2015, 21:53:07 »
Thanks guys! Now let the hunt for a keycaps set begin lol
Offline Volvicsoda
  • Want some soda?
« Reply #9 on: Sun, 18 January 2015, 05:22:28 »
i've tried the novatouch with several keycaps that I own at the moment.
GMK doubleshots and SA profile keycaps, along with side-printed leopold pbt keycaps are my favorite.
One thing in common for these keycaps are probably the thickness, which feels and sounds better with more *thock* than those SP DCS and TH thin doubleshots.
FC660C, Realforce 104UK-HiPro, Novatouch TKL, NMB RT101+, NMB 8755C+, BTC-5339 Cyrilic, IBM 1390131, IBM SSK,G86-52400, G80-8113,  MX-MINI, G81-3077, Skidata, Filco Camo, 3000SAG, 1724SPF, GMK C. Orange, GMK Dolch, GMK WoB, GMK TA, Filco SA...
Offline Dihedral
  • Mostly Harmless
« Reply #10 on: Wed, 21 January 2015, 12:15:30 »
Go for the Vortex Sets on Massdrop right now - really good value for good PBT. I've seen these IRL and they look really good.
Offline XMIT
  • formerly jsoltren
« Reply #11 on: Wed, 28 January 2015, 10:46:53 »
I agree that the Vortex sets work well on the Novatouch. It changes the sound and feel of the keyboard entirely. The ones I had on my Novatouch (Vortex PBT doubleshot) fit just fine.
Offline jabbon
« Reply #12 on: Wed, 28 January 2015, 23:43:02 »
FC660C or Novatouch with thick caps?
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #13 on: Thu, 29 January 2015, 11:26:20 »
Do the Vortex play well with the stabilized keys on the Novatouch ? I tried some SP DCS and they feel very harsh and sound terrible.
Offline XMIT
  • formerly jsoltren
« Reply #14 on: Thu, 29 January 2015, 16:43:31 »
The Vortex thick PBT keycaps worked well with the Novatouch stabilizers in my experience.
Offline Ngt
« Reply #15 on: Thu, 29 January 2015, 16:55:46 »
Does the SA profile fit nice on the Novatouch?
Offline sdiearly
« Reply #16 on: Fri, 30 January 2015, 00:20:13 »
I have done key cap compatibility test on Novatouch.
http://www.ptt.cc/bbs/Key_Mou_Pad/M.1412526550.A.50B.html
My favorite 60%:  TEX-Beetle
                 80%:  KBtalKing Race
                100%: Cherry G80-3494, Zowie Celeritas
Offline Ngt
« Reply #17 on: Fri, 30 January 2015, 02:27:21 »
Offline Hypersphere
« Reply #18 on: Sat, 03 October 2015, 14:38:28 »
I've mostly completed my testing of different keycap sets on the Novatouch.
Best all-around: Ducky dye-sub PBT OEM profile. These caps are high quality, and the OEM profile is high enough to avoid bottoming-out noise from the keycap hitting the switch housing or plate.
Unfortunately, other high quality keycap sets that I have tried in Leopold or Cherry profile result in bottoming-out noise.
Offline XMIT
  • formerly jsoltren
« Reply #19 on: Mon, 05 October 2015, 08:30:07 »
I don't get any bottoming out noise with Signature Plastics DSA profile key caps either.
