Author Topic: PTFE Keys?  (Read 4799 times)
Offline timw4mail
    • https://timshomepage.net
PTFE Keys?
« on: Sun, 09 August 2009, 10:43:15 »
So I've been randomly looking around at different plastics...and I came across
Polytetrafluoroethylene (PTFE)
As described here PTFE has a high resistance to all know solvents, acids, and oxidizing agents, and is highly resistant to UV weakening.
It would seem that PTFE would be the perfect plastic for keyboard keys, if you overcame it's one weakness for this application: It has one of the lowest know friction coefficients, its very slippery.
While I don't know how well it accepts dye, its high melting point would guarantee no melted keys.
Do you think PTFE has ever been used for keycaps?
Edit:
PTFE is also known as Teflon.
« Last Edit: Sun, 09 August 2009, 10:55:49 by timw4mail »
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline molto
    • http://www.friv.gs
PTFE Keys?
« Reply #1 on: Sun, 09 August 2009, 10:51:17 »
PTFE is also very soft, so the keys would be highly susceptible to scratching. It is further relatively heavy and expensive, feels like wax and is self-lubricating.
I don't understand why PTFE has caught your eye because there are many plastics with high chemical resistance.
« Last Edit: Sun, 09 August 2009, 11:28:02 by molto »
y8 | Miniclip | y3 | friv | ben10 | y8 | kizi | y8 | y3  | y8 | pogo
Offline timw4mail
PTFE Keys?
« Reply #2 on: Sun, 09 August 2009, 10:58:58 »
Quote from: molto;108400
PTFE is also very soft, so the keys would be highly susceptible to scratches. It is also relatively heavy and expensive.
But none to the degree of PTFE. I never claimed it was practical, just was kind of contemplating it.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
PTFE Keys?
« Reply #3 on: Sun, 09 August 2009, 11:08:04 »
Teflon is used for mouse feet just because it has very low friction. You'd have a hard time trying to make it stick on keyswitch stems. And yes, it is pretty soft, which is why teflon coated pans (another application exploting the low friction) don't last forever.
Offline huha
PTFE Keys?
« Reply #4 on: Sun, 09 August 2009, 14:32:42 »
PTFE is relatively expensive. Also, what good is chemical and UV resistance for keycaps? The only property you'll want for keycaps is durability, i.e. some resistance to acids to resist being dissolved by sweat (but most plastics happen to have this property anyway) and very hard material so it's not ablated by constant and repeated movement.
Better plastics are POM and PBT; they're quite hard and therefore not very prone to becoming shiny and losing texture.
Incidentally, Cherry use them for their keycaps.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
