Author Topic: Question about the Novatouch  (Read 1847 times)
Offline Harms
« on: Sat, 10 January 2015, 18:29:01 »
Hi everyone, I have a question regarding the Novatouch. However, I heard about this issue about loose keycaps on the stem. Is this true for most mx keycaps? Are they loose on the novatouch? I heard about this when it was first released and stuff. Or does it happen only to certain keycaps? Thank you for the help.
Offline BucklingSpring
Re: Question about the Novatouch
« Reply #1 on: Sat, 10 January 2015, 19:37:48 »
I have a Novatouch as a daily driver at the office. Caps are no better or worst in term of looseness compared to either MX's or Topre's.
Boards I own, click ->
Offline spiceBar
    • ChessTiger.com
« Reply #2 on: Sat, 10 January 2015, 20:28:44 »
On most keys, whatever keycaps you put on will fit tightly. You need a keycap removing to to safely pull them out, as with any Cherry MX keyboard.
On some keys the keycaps are a little bit lose, to the point that I have been able to remove some of them with my bare hands. I think it has to do with the kind of plastic they use for the sliders, which has a very low friction coefficient (which is excellent for the feel of the switch).
If you ever have a problem with a keycap that is a little bit too lose, it can be fixed very easily by inserting a small piece of thin paper between the slider and the keycap, as you would do as usual on a Cherry MX keyboard. I did not have to do that on my Novatouch.
So to sum it up: no issue here.
« Reply #3 on: Sat, 10 January 2015, 21:56:37 »
On Cherry MX keyboards, I can sometimes pull off the Esc key with my bare hands. Not so on the NovaTouch.
Offline slickmamba
« Reply #4 on: Sat, 10 January 2015, 22:05:37 »
Never had that issue on either of mine.
Hi :)
Offline Harms
« Reply #5 on: Sat, 10 January 2015, 23:39:49 »
awesome guys thank you :D I have another question. I heard some stabilized keys rattle excessively. Are there defects to the stabs. Or do they make little noise like every mech KB does? Thank you guys.  A little noise is understandable.
« Reply #6 on: Sun, 11 January 2015, 01:28:25 »
Typing on the NovaTouch now, I don't hear any rattling in the stabilised keys.
The only key that is a bit louder than the others is the Space Bar. It has a louder "Thock" when you bottom it out and on the rebound if you release it quickly. It is definitely louder than the Space Bar on my Realforce.
Offline spiceBar
    • ChessTiger.com
« Reply #7 on: Sun, 11 January 2015, 04:18:39 »
In this post of mine, you can hear an audio sample of an unmodified Novatouch. At the end of the recording, I insist on the stabilized keys on purpose, so you can judge by yourself:
  https://geekhack.org/index.php?topic=65853.msg1540901#msg1540901
