Author Topic: What is the most tactile switch among mx switches ?  (Read 3724 times)
Offline dalakada
« on: Mon, 12 January 2015, 19:55:01 »
Hi guys,
I just wonder your opinions.
What do you think ?
Thanks.
Re: What is the most tactile switch among mx switches ?
« Reply #1 on: Mon, 12 January 2015, 19:56:34 »
tactile greys
Offline Huxley2500
« Reply #2 on: Mon, 12 January 2015, 20:05:42 »
Cherry MX Green.
Offline Jersern
  • Australian Keyboard Modding and Repair Service
« Reply #3 on: Mon, 12 January 2015, 20:16:40 »
I personally think clears are the most tactile and they're possible to find in consumer keyboards unlike tactile greys.
Offline jacobolus
« Reply #4 on: Mon, 12 January 2015, 20:25:00 »
Depends on your definition of 'tactile'. MX clear has a larger drop in force at its tactile point, but it isn’t quite as “crisp” as MX blue IMO. The sound also makes a big difference to perceived switch feel.
The most tactile feel you can get with MX is probably an MX clear stem and the lightest spring you can tolerate, and then a solenoid or buzzer for extra audio feedback at actuation.
When you get down to it, none of the MX switches are really all that 'tactile', compared to many other types of switches.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #5 on: Mon, 12 January 2015, 20:26:09 »
Well from what I read. 55g clears have a huge tactile bump. Again.. From what I read :(
« Reply #6 on: Mon, 12 January 2015, 20:27:14 »
tactile greys
No more tactile than Clears.  In fact, I'd say they probably feel less tactile since the heavier spring hides some of the tactility.
« Reply #7 on: Mon, 12 January 2015, 20:28:03 »
tactile greys
Actually they are less tactile than stock clears, most tactile would be ergo-clears.
« Reply #8 on: Mon, 12 January 2015, 20:28:38 »
tactile greys
tactile greys
I guess I'll have to revisit them then, it's been a while.
Offline dalakada
« Reply #9 on: Mon, 12 January 2015, 23:20:56 »
Thanks for all replies guys, It helped me a lot !
Offline Defect
« Reply #10 on: Tue, 13 January 2015, 01:17:55 »
Anything with a clear stem (which is same as grey).  Lighter spring with no lube is very "tactile."
Offline Oobly
« Reply #11 on: Tue, 13 January 2015, 01:42:06 »
ErgoClears for sure.
Greens and Blues are not as tactile as most people seem to think:
tac·tile
ˈtaktl,ˈtakˌtīl/
adjective
adjective: tactile
    of or connected with the sense of touch.
If you hide the sound of the clicky switches, you'll discover they're not particularly tactile. In fact the bump is the same size as on Browns and the drop in force at actuation is around the same or even LESS.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
