Author Topic: abs m1  (Read 1925 times)
Offline sivart
abs m1
« on: Mon, 10 August 2009, 15:55:30 »
I have had my m1 for about 3 weeks now, and recently the space bar decided to not work.
 I've tried taking it off looking around seeing if something was wrong that I could potentially get an easy fix off of, but to no avail.
 I wanted to know if any of you have had similar problems or know a fix to mine.
 ( new to mechanical keyboards & I really like the keyboard i'm just in over my head I think (: )
Offline erricrice
abs m1
« Reply #1 on: Mon, 10 August 2009, 16:09:08 »
I dunno if there is a quick solution to the problem, but I know someone who had the same problem with his with the spacebar and he just RMAd it.  If you can't fix it(the guys here will know what to do lol) then you can RMA it and get a replacement no problem.
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline itlnstln
abs m1
« Reply #2 on: Mon, 10 August 2009, 16:12:27 »
If you take the cap off and press the stem of the switch, does it work?  If not, you can switch the internals of the switch with something like pause/break and try that (you can find instructions for Alps switches, in general, in the mods section).  If swapping internals doesn't work, then you might want to try RMAing it since there could be any number of reasons why it might not work.
Offline sivart
abs m1
« Reply #3 on: Mon, 10 August 2009, 16:15:58 »
Alright, gonna try swapping them out in a minute & ill let you know how it works.
