Author Topic: Genovation 630 Teardown/Review  (Read 3317 times)
Offline MGH
« on: Wed, 14 January 2015, 20:24:50 »
I recently purchased two Genovation 630 numpads from http://www.ebay.com/itm/Genovation-MicroPad-630-21-USB-10-Key-/181639637292?
They arrived today via Priority mail. I paid $21 shipped for both numberpads.
2 screws
Ver 1.1 ;D
Plate mount blacks
All opened up
PCB
Note that the switches are plate mount but the PCB supports PCB mounted switches but not stabs.
A more formal review will be edited in once I spend some more time with it. ;)
Offline Battou62
Re: Genovation 630 Teardown/Review
« Reply #1 on: Thu, 15 January 2015, 14:26:50 »
Might have to pick one of these up :o Is it only the 630 that is mechanical?
« Last Edit: Thu, 15 January 2015, 14:30:06 by Battou62 »
Offline Hak Foo
  • Make America Clicky Again!
« Reply #2 on: Thu, 15 January 2015, 20:06:11 »
There is also a 632 which has ALPS swtches in some revisions.
Overton130, Box Pale Blues.
Offline RickyJ
« Reply #3 on: Thu, 15 January 2015, 22:52:09 »
Proper tenkey layout (with useful keys on top row), very nice.  How does it feel?  My Adesso numpad is a featherlight, feels like a toy.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #4 on: Thu, 15 January 2015, 23:19:37 »
i would have so gotten one of these if i was in the US....  Thanks for the tear down!
GON NerD TKL DTA Edition
Offline MGH
« Reply #5 on: Fri, 16 January 2015, 19:57:52 »
After using it for two days, I don't really like it.
The bottoming out feels really mushy, the switches themselves feel like the unclipped stabilizers. It has a plate, but I think that the combination of thin plate and flimsy plastic case make it feel like ****. When I apply a lot of force on the keys, the whole PCB+Plate combo moves up and down inside of the case.
The cable placement is also a tragedy, it juts out of the top of the right side, making it interfere with the mousepad if you put it on the right and with the keyboard (if its TKL-Fullsize) if you put it on the left.
But for $11, its a nice little numpad for quick usage, and a nice object for taking pictures with ;D
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #6 on: Fri, 16 January 2015, 20:52:15 »
Sounds like you need to send me one to mod =D
Thanks for the update/review
Offline crazystu
« Reply #7 on: Wed, 21 January 2015, 01:14:12 »
The bottoming out feels really mushy, the switches themselves feel like the unclipped stabilizers. It has a plate, but I think that the combination of thin plate and flimsy plastic case make it feel like ****. When I apply a lot of force on the keys, the whole PCB+Plate combo moves up and down inside of the case.0
You can easily open the num-pad up and change the cable to come out of the left side of the num-pad. There are holes on both sides of the case, doesn't require any modification (you just move the rubber plug to the other side).
Offline MGH
« Reply #8 on: Tue, 03 February 2015, 11:31:33 »
Ohhhhh.....thanks for the info :thumb:
Offline drewba
« Reply #9 on: Tue, 03 February 2015, 12:16:19 »
The cable orientation has bothered since I received the numpad, thanks for the heads up.
MGH - thanks for bumping :)
