Author Topic: I may have boobooed  (Read 3024 times)
Offline xxghostxx
I may have boobooed
« on: Fri, 16 January 2015, 17:30:05 »
Ok so i had a bad day at work wed ,and came home an start to relax with a drink or twelve. i got to relaxed an spilt an screw driver on my ducky shine 2. i managed to salvage the boards it still works just the space and shift stabilizers are sticking.any suggestions how to fix this issue?
Ducky shine 2(9008)-orange back lit ,MX Cherry brown
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: I may have boobooed
« Reply #1 on: Fri, 16 January 2015, 17:34:55 »
are you currently intoxicated? the best time to solder/repair boards is when you're super-hammered.
« Reply #2 on: Fri, 16 January 2015, 17:38:57 »
get even drunker and try to fix it. it's the only way.
Offline xxghostxx
« Reply #3 on: Fri, 16 January 2015, 17:42:25 »
Lol sadly im sobber you know spilling booze on 140$ keyboard does that... any ideas how to fix it?
Offline intelli78
« Reply #4 on: Fri, 16 January 2015, 17:43:38 »
Dump a pot of coffee into it and put it in jail for a night, tomorrow it'll be fine.
Offline digi
  • elite af tbh
« Reply #5 on: Fri, 16 January 2015, 17:46:09 »
Depends on the proof of the liquor, if it has a higher alcohol content it should dry pretty quickly. Do any keys work? Download the EK Switch Hitter tool https://elitekeyboards.com/switchhitter.php once it's dry and find out which keys might be having issues. Be sure to take a couple good-luck whiskey shots before you start. =)
Intelli has an excellent point, I left out the coffee dumping method.
« Last Edit: Fri, 16 January 2015, 17:48:22 by digi »
Offline xxghostxx
« Reply #6 on: Fri, 16 January 2015, 17:48:57 »
The board works just the sabilizers on the space and shift keys stick hard.its dry this happened wed.
« Reply #7 on: Fri, 16 January 2015, 17:50:00 »
If that is all that is wrong with it, you can remove the stabilized keycaps, and then use some lube (SuperLube or white lithium grease) to lube the stabilizers.
In other news, we need a drunk posting topic. That should be entertaining. :)
« Last Edit: Fri, 16 January 2015, 17:51:46 by jdcarpe »
Offline Defect
« Reply #8 on: Fri, 16 January 2015, 17:55:08 »
Disconnect your board, grab a q-tip and some isopropyl alcohol.  Clean the stabs, then wait for it to try.
Lube them with some silicone grease after.
Offline xxghostxx
« Reply #9 on: Fri, 16 January 2015, 18:04:39 »
Kool any clue how to get to them? the bar goes under the plate or is it the black fake switch on top i need to lube?(newb here)  that
plates the only reason it lived. i dont think ill ever buy one with out it being plate mounted now.
Offline Huxley2500
« Reply #10 on: Fri, 16 January 2015, 18:31:40 »
I heard a dishwasher works well for spills.
« Reply #11 on: Fri, 16 January 2015, 18:36:39 »
If you look under the plate at where the stabilizer wire connect to the insert (the black "fake switch" part), you should just be able to see where the wire contacts the plastic. That's the bit you need to lube.
Offline eth0s
  • Peace & Love
« Reply #12 on: Fri, 16 January 2015, 18:39:16 »
wow, okay, you guys are d!cks.  Like you never got totally hammered at the computer and spilled your OJ and vodka on the keyboard.
Here's how you fix that problem.  You've basically got a variation on the Pepsi Syndrome.  You clean up the sticky residue with a little soapy water.  On a paper towel.  And you wipe.  But be careful . . . Wait, did you say it was a Ducky?  lol.  That's easy to fix.  Put it in the rubbish bin and let the local Sanitation Department take it away forever.
Offline Macsmasher
« Reply #13 on: Fri, 16 January 2015, 18:48:05 »
I was going to suggest urinating on the keyboard and claim that the ammonia would dissolve the OJ. But since I don't want to be a d!ck, I won't say that.
Glad I could help out on this thread.
Offline xxghostxx
« Reply #14 on: Fri, 16 January 2015, 19:01:57 »
Thank you jdcarpe and to the rest of you guys you did make me laugh.
Offline mouse.the.lucky.dog
« Reply #15 on: Fri, 16 January 2015, 21:39:54 »
I would remove all the keycaps and open the board. You really do want to get out all those sticky deposits, they may be fine now but cause problems later.
If the only thing that is a problem are sticky stabilizers, then remove the stabilizer and wash it and the area around it replace.
Sorry, I don't remember whether Ducky uses costar or cherry stabilizers but in either case there are youtube videos showing how to remove and replace them.
So just search there.
