Author Topic: Advice on re-cabling Filco Majestouch 2 TKL  (Read 2542 times)
Offline Ciemnika
« on: Fri, 16 January 2015, 20:22:31 »
« Last Edit: Mon, 06 October 2025, 12:44:12 by Ciemnika »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Advice on re-cabling Filco Majestouch 2 TKL
« Reply #1 on: Fri, 16 January 2015, 20:29:17 »
2) Any good resources for coiled braided USB cables? Searching isn't really providing me much useful info.
There are two big places to buy them from here: Zeal and Pexon. I've dealt with Zeal on more than one occasion and highly recommend him, though people also speak highly of Pexon, though he is UK based
Offline cephelix
  • to buy or not to buy?
« Reply #2 on: Sat, 17 January 2015, 17:52:03 »
On my end, I've just recently dealt with Pexon. Very fast replies to any questions I have and prices seem reasonable. Depending on where your're located, you can't go wrong with either Zeal or pexon. Both are highly recommended.
This is what I ordered.
http://pexonpcs.co.uk/products/filco-keyboard-mods > this is the quick disconnect, connectors are one for the PCB and the other end is a female USB A
http://pexonpcs.co.uk/products/usb-cables > this has both ends with a USB A male connectors that connect from the modded cable to the pc.
He also sells coiled cables. Really there are many options to choose from. If you have any questions, just pm pexon. He usually replies in a day or two
ALi
Filco MJ2 TKL MX Browns | KC60 Gateron Browns
« Reply #3 on: Sat, 17 January 2015, 17:55:32 »
BRUH.
MIMIC CABLES FTW
