Author Topic: Keyboard of the month January nomination thread!  (Read 40913 times)
Offline katushkin
  • Too Keycool for School
  • * Moderator
  • Just the guy
« on: Mon, 19 January 2015, 08:10:06 »
A little late, but here it is. This is the nomination thread for KOTM for January. Please post in this thread the link to, and prefereably a picture of, the board(s) you would like to nominate for the Keyboard of the Month vote for January, which will start on February 1st.
The winner of December's vote was Lastpilot's GON
Find threads for January here:
Below are the rules as set out in last month's nomination thread, and please remember to limit your nominations to boards that have been posted on the forums since January the first.
1.   A nomination thread will go up for the last two weeks of every month. You can nominate anybody you like, (even yourself) and any person can have any number of nominations every month. This is going to be the nomination thread for December.
a.   These boards should be ones you are drawn to, ones that stand out for one reason or another. Keysets, modifications, whatever you fancy. I don’t want to have to post guidelines or restrictions on the boards, but I may change this depending on the types of submissions we get over the first few months. Please also say a little bit about each board you nominate, as to the reasons why you think it deserves to be up for KOTM.
b.   The board must have been posted to the forums since the start of the calendar month. It can have been posted before then, but you must provide a link to the images that were posted after the first day of the calendar month.
c.   Keyboards may be resubmitted in subsequent months, but they must have had a picture or progress posted within the calendar month that they are nominated for.
d.   NO THEMES RIGHT NOW. These may or may not follow in the coming months. This also may or may not tie in with the calendar that may or may not happen at the end of next year.
2.   However, after the initial two week period of nominations, a user will only have ONE board get through to the final public voting process. The final three nominees will be selected by myself from the most nominated and praised board in the nomination thread. E.G. If one board is posted and has the most +1s, quotes or references  by other users in said thread, that will be chosen as one of the final three. Essentially, there is a crowd unofficial voting before the public voting. The final three are not up to me, they are up to you.
3.   PLEASE post some good quality photos of the board you are nominating. I’m not looking for Macro lenses and DSLRs, but maybe more than one, top down, blurry shot would be nice. I realise if it isn’t your board there isn’t much you can do about it, but just pick a couple that aren’t terrible from an album or post.
4.   On the 1st of every month, a poll thread will go up. This will consist of three finalists. Again, a user will only have one of their boards get through to this stage during any particular month. You can of course be nominated on another month. There will be one vote per person, and the results will remain anonymous until the voting closes.
5.   After a period of one week, the voting will be closed and a winner will be announced. The winner will be posted both on that month's voting thread, and the following month's nominations thread. I’m not sure if there will be a prize every month, but if there is then I will sort it out and backdate it if I come up with one in a few months time.
6.   The winner of each monthly process will go through to the ANNUAL KEYBOARD OF THE YEAR process, and the winner of the will DEFINITELY win a prize which I will work out in a year’s time.
You can post any feedback (good or bad) in the feedback thread on the off topic board, found here - https://geekhack.org/index.php?topic=66797.0
Nominations will last until January 31st at probably around midnight GMT ish, Then voting will last from the 1st of February (maybe, depending on the Super Bowl) but it will last for 7 days.
« Last Edit: Thu, 22 January 2015, 08:18:55 by katushkin »
Re: Keyboard of the month January nomination thread!
« Reply #1 on: Mon, 19 January 2015, 09:37:55 »
Can I nominate myself?
https://geekhack.org/index.php?topic=66137.msg1598106#msg1598106
It's a Poker II, white plate, white backlighting, with MX Clears in a white treble318 alu case, with Cherry Replica Set orange polycarb legends on white ABS base keycaps (white mods).
« Last Edit: Mon, 19 January 2015, 09:40:11 by jdcarpe »
Offline Dihedral
  • Mostly Harmless
« Reply #2 on: Mon, 19 January 2015, 10:13:51 »
I would have no chance at this but it's great to see all your boards :)
Offline abjr
    • abjr.org
CM QFR | magicforce 68 (Gateron) | magicforce 68 (Outemu) | Acros 6311-K
Offline monotagary
  • Keycaps > Rent
« Reply #4 on: Mon, 19 January 2015, 10:38:21 »
+1 for this. Gorgeous board jd!  :thumb:
Offline katushkin
  • * Moderator
  • Just the guy
« Reply #5 on: Mon, 19 January 2015, 12:28:57 »
You can indeed! I'm very jealous of that backspace, I never knew they did one of those!
« Reply #6 on: Wed, 21 January 2015, 03:43:24 »
« Reply #7 on: Wed, 21 January 2015, 15:02:05 »
There's a few boards that I think should be nominated:
bpiphany's serial protocol board called Blue Pill
Oobly's take on the Hemmingwrite
kurplop's Alumaplop
Shoutouts to twiddle for his custom board but unfortunately it missed the cutoff date.
« Last Edit: Wed, 21 January 2015, 15:16:40 by CPTBadAss »
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #9 on: Wed, 21 January 2015, 16:08:57 »
kurplop's Alumaplop
+1
I love the insanity of that case.
Milling down a block of aluminum to what looks like a pressed plate of stainless steel. Also the use of Cherry ML switches is rare in itself on this forum.
|||My other keyboards :
x
Offline Oobly
« Reply #10 on: Thu, 22 January 2015, 02:55:51 »
Thank you kindly, CPT!
I agree with the nomination of kurplop's Alumaplop. The design and engineering work on that is inspiring!
I'm loving jdcarpe's Poker II also (and it makes me wish I had the white modifiers for my own Cherry Legends set), but I appreciate the original work that's gone into the Alumaplop more.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #11 on: Thu, 22 January 2015, 03:12:30 »
That Alumaplop...holy...
+1
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #12 on: Thu, 22 January 2015, 06:25:32 »
Thanks everyone. :)  I'm flattered by your comments but I think you should hold your nomination of the Alumaplop until its completion. Things don't always turn out for the better.  After all, people use to say that I was a cute little boy. :-[
Offline katushkin
  • * Moderator
  • Just the guy
« Reply #13 on: Thu, 22 January 2015, 08:16:07 »
Offline katushkin
  • * Moderator
  • Just the guy
« Reply #14 on: Thu, 22 January 2015, 08:48:31 »
My nomination for this month is bianco's Lightsaver.
Erm. Again.
This time with GMK Dolch, two Hellboys and two Bros. Nice.
https://geekhack.org/index.php?topic=33130.msg1600548#msg1600548
Holy **** why didn't I buy a Lightsaver when they were available...
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #15 on: Thu, 22 January 2015, 09:02:39 »
Just wondering but what is the deal with the cut off date?  I ask because I might have a keyboard to nominate next month.
Erm. Again.
That is one sexy keyboard, in terms of caps, case, layout, and artisans.
Offline katushkin
  • * Moderator
  • Just the guy
« Reply #16 on: Thu, 22 January 2015, 09:10:20 »
The nominations last to the end of the month, just so we can include every board that has been posted in the month of January. So at midnight on the 31st, nominations will close, then voting will open for a week.
« Last Edit: Thu, 22 January 2015, 09:38:06 by katushkin »
« Reply #17 on: Thu, 22 January 2015, 09:13:01 »
It's still amazing and if nothing else, hopefully a few other people check out your thread now :). Really looking forward to it's completion.
Offline Melvang
« Reply #18 on: Thu, 22 January 2015, 09:23:47 »
I guess my question is stemmed from why is twiddles custom board not eligible?
« Reply #19 on: Thu, 22 January 2015, 09:27:09 »
In the OP, katushkin says the post with the board needs to be on 1/1/15 or after. Twiddles was posted very late in December 2014.
« Reply #20 on: Thu, 22 January 2015, 09:28:01 »
oobly continues to make awesome small boards.
if only he didnt hate me :(
Offline Melvang
« Reply #21 on: Thu, 22 January 2015, 10:19:41 »
I missed that part.  Thank you for the clarification.
Offline katushkin
  • * Moderator
  • Just the guy
« Reply #22 on: Thu, 22 January 2015, 10:25:10 »
Yeah, I didn't actually put it in the OP this time, but I had to edit it in. I didn't remember if it was in the rules I copied in as well.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #23 on: Thu, 22 January 2015, 18:47:46 »
I did just get this:  A fully bolt modded model M keyboard.  Rock solid.
Edit:
This keyboard was done by Maxx at Phosphorglow.Net  There is no way I could do it myself.  I already tried and ruined a keyboard before I went to him.  I'll leave that work to the experts!  I guess it could be a nomination.  I don't know.
P.S. It turns 20 years old February 13th this year.
« Last Edit: Fri, 23 January 2015, 02:23:33 by Snowdog993 »
Offline Touch_It
« Reply #24 on: Thu, 22 January 2015, 19:10:53 »
Just for fun, I'm nominating myself.
Link:  https://geekhack.org/index.php?topic=65222.0
Offline Snowdog993
« Reply #25 on: Thu, 22 January 2015, 19:16:12 »
Double post.
« Last Edit: Thu, 22 January 2015, 19:20:05 by Snowdog993 »
Offline Oobly
« Reply #26 on: Fri, 23 January 2015, 04:03:36 »
That's an amazing board :D I bet it's VERY rewarding to type on...
Note to self: I must get myself a decent Model F.
Offline 1391406
« Reply #27 on: Fri, 23 January 2015, 12:54:03 »
I'll throw my hat in the ring with an ANSI modded 122-key Model F with Black and White key caps.
« Last Edit: Fri, 23 January 2015, 13:25:39 by 1391406 »
Offline Snowdog993
« Reply #28 on: Fri, 23 January 2015, 13:26:12 »
I'll throw my hat in the ring with a Model F 122 with Black and White key caps.
That looks really nice!  Where did you get the white lettering on the black keys?  It looks really sharp!
« Reply #29 on: Fri, 23 January 2015, 13:30:08 »
From a black IBM M13, most likely. :)
Offline 1391406
« Reply #30 on: Fri, 23 January 2015, 16:08:23 »
jdcarpe is right. They were harvested from a few IBM M13's.
« Reply #31 on: Sat, 24 January 2015, 05:00:17 »
That one's nice.
You even get bonus points for getting `\~ and \| right!
Offline 1391406
« Reply #32 on: Sat, 24 January 2015, 07:23:30 »
That one's nice.
Thanks! I was initially going to use a black key cap for \| but ultimately decided against it.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #33 on: Sat, 24 January 2015, 09:29:53 »
That one's nice.
You made the right choice
« Reply #34 on: Tue, 27 January 2015, 03:50:37 »
Offline katushkin
  • * Moderator
  • Just the guy
« Reply #35 on: Tue, 27 January 2015, 09:04:07 »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #36 on: Tue, 27 January 2015, 09:16:37 »
I'd like to nominate Zeal Gateron build: https://geekhack.org/index.php?topic=68061.msg1612642#msg1612642
This is the future
Offline Dihedral
  • Mostly Harmless
« Reply #37 on: Tue, 27 January 2015, 14:42:39 »
This is the future
Its not feburary yet and 2015 is already the year of the Gateron.
Offline FrostyToast
  • Litshoard
« Reply #38 on: Tue, 27 January 2015, 23:09:33 »
I would like to nominate my own keyboard.
Here is a potato:
55g with silver digilog.
Quote from: elton5354
« Reply #39 on: Wed, 28 January 2015, 03:29:05 »
Here is a potato:
That's actually only one step away from being my ideal keyboard - if it had yellow printed keycaps - perfect!
(Oh, and if the space bar was not deformed :p )
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #40 on: Wed, 28 January 2015, 07:57:03 »
Here is a potato:
It's OK, you'll eventually see the light and realize that a flipped spacebar is a good spacebar
Offline Oobly
« Reply #41 on: Wed, 28 January 2015, 10:22:27 »
Here is a potato:
Pah, no need to on SA profile. Only inferior profiles like DCS and OEM.
Offline billnye
  • ability man
« Reply #42 on: Wed, 28 January 2015, 10:35:10 »
I nominate my prince Zealio for his Gatorade build
https://geekhack.org/index.php?topic=68061.msg1609990#msg1609990
Offline MAR82
  • Keyboard Addict
« Reply #43 on: Wed, 28 January 2015, 10:44:32 »
I think there is little chance for me to win, but let's try to anyway  ;)
Here is my Gon NerD 60 build with MX White switches and clear covers on them, and last but not least BlackLight LEDs
* Gon Build-12-1.jpg (979.23 kB. 1000x750 - viewed 242 times.)
More pictures can be found here http://imgur.com/a/UzKvt#0
Offline MGH
« Reply #44 on: Wed, 28 January 2015, 10:51:49 »
How many M13 sets did you use?
Offline FrostyToast
  • Litshoard
« Reply #45 on: Wed, 28 January 2015, 10:53:00 »
Looks like three.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #46 on: Wed, 28 January 2015, 11:08:02 »
Here is a potato:
(Oh, and if the space bar was not deformed )
That's just... I can't... why would...
And only plebes use OEM and DCS. Cherry profile for life
Offline 1391406
« Reply #47 on: Wed, 28 January 2015, 14:50:12 »
Looks like three.
Correct.
Offline Oobly
« Reply #48 on: Thu, 29 January 2015, 07:37:58 »
Here is a potato:
 :D Actually, Cherry is acceptable as is, the only one of those cylindrical top profiles that doesn't create a sharp edge on the spacebar in normal orientation, but I still prefer how SA feels... mmm, them feels... Makes me want to just keep on typing, but I better stop now so this post doesn't get too long.
She's a beauty! Very clean and neat build. Looks awesome with those PuLSE SA caps on :)
Offline katushkin
  • * Moderator
  • Just the guy
« Reply #49 on: Thu, 29 January 2015, 08:28:19 »
OK, so currently we have about 6 boards with two nominations each, so make sure to go through the thread and +1 the ones you like, or I will have to make an executive decision myself, which I don't want to do because I'm afraid I will make people angry/sad :(
Only two days left to get your nominations in!
