Author Topic: No Choice! One keyboard! That's it!  (Read 32452 times)
Re: No Choice! One keyboard! That's it!
« Reply #150 on: Sun, 05 April 2015, 19:38:22 »
Realforce 104UB-DK 45G Silenced.
Yup. Although I'm rocking variable.
Offline ttzhou
  • in your base, belonging
« Reply #151 on: Tue, 07 April 2015, 09:17:04 »
GON Nerd TKL, Acrylic Housing, full decked out LEDs, pimped clears with 62g.
This is only after being in this hobby for 4 months. The amount of money spent to reach this realization though...  :eek:
Offline aref
« Reply #152 on: Tue, 07 April 2015, 12:00:26 »
This...
Offline bhtooefr
    • bhtooefr.org
« Reply #153 on: Tue, 07 April 2015, 14:20:01 »
Matias Tactile Pro PC with a pointing stick retrofit from the IBM TrackPoint IV (rubber dome) desktop board.
Offline Ettasian
« Reply #154 on: Tue, 07 April 2015, 15:09:12 »
My G80-0777. It's amazingly good for typing and i don't use any others anyway  :D
Cherry G80-0777/1
Offline thefebruaryman
  • turn it off and turn it on again
« Reply #155 on: Tue, 07 April 2015, 15:27:46 »
Hhkb pro 2 best I have used to date
Offline Nukez
« Reply #156 on: Tue, 07 April 2015, 15:37:35 »
HHKB is love HHKB is life
HHKB Pro2 : KBT Race S : CM Quickfire Ulti
Offline sypl
« Reply #157 on: Wed, 08 April 2015, 03:25:42 »
TIL off keyboard forums: The 6lb, 20-year old, still-in-perfect-working-condition IBM Model M, is a 'flimsy toy'. Anyway, I own two and love them, and if this is really gonna be a keyboard for life choice, then I gotta go with the keyboard I'm almost sure will last me for life.
Do that many people really own Model Fs? They seem kinda hard to come by. And which ones are people using? This one?: https://en.wikipedia.org/wiki/File:IBM_Model_F_AT.png. What do you do for for that sixkey cluster (home/end/pgup, etc) and arrow keys? You just toggle the scroll lock a lot?
« Last Edit: Wed, 08 April 2015, 03:32:40 by sypl »
Offline LennyRhys
« Reply #158 on: Wed, 08 April 2015, 04:41:19 »
My bro still has his original G80-3000.  My love for MX blues has been rekindled and I love the original Cherry doubleshot caps, so that'd have to be the board for me.
« Reply #159 on: Wed, 08 April 2015, 04:46:34 »
Awe Yeahhh!  :thumb:
Offline Nai_Calus
  • CLACK
« Reply #160 on: Wed, 08 April 2015, 05:03:26 »
The AT is pretty popular, probably the most used.
The 4704 Model Fs seem pretty popular as well, the Kishsaver of course is legendary, but the 107 is the closest to a modern layout you'll find on an F.
And yes, comparted to my over ten pound, solid metal, 31 year old keyboard I'm typing this on, I think your M does qualify as a flimsy toy. ;)
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline bhtooefr
    • bhtooefr.org
« Reply #161 on: Wed, 08 April 2015, 05:12:15 »
Needs more aircraft carrier if you're going that way:
That way you get all the keys you could possibly need, some remapping might be necessary though.
Also, the problem with the Model M is that the heat stakes (or "rivets") that hold the assembly together become brittle over time, and then break. A bolt mod can fix this, though.
Offline appleonama
  • Trollo en USA
« Reply #162 on: Wed, 08 April 2015, 05:25:02 »
hhkb type-s  ;D
