Author Topic: Industrial SSK @ $100  (Read 17548 times)
Offline intelli78
« on: Tue, 20 January 2015, 12:49:12 »
« Last Edit: Tue, 20 January 2015, 21:20:48 by intelli78 »
Offline Dihedral
  • Mostly Harmless
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: Industrial SSK starting at $100.00
« Reply #2 on: Tue, 20 January 2015, 13:43:19 »
It's painted.  (badly)  Ugh.
Offline intelli78
« Reply #3 on: Tue, 20 January 2015, 13:44:58 »
Hmm - you could be right. Looking at the bottom pic on ebay, seems there are some fibers that appear to be trapped under paint.
Offline Dihedral
  • Mostly Harmless
« Reply #4 on: Tue, 20 January 2015, 13:55:36 »
An SSK's an SSK. Sand down and re-coat?
« Reply #5 on: Tue, 20 January 2015, 13:56:46 »
Your are missing the point. IF it was an industrial ssk it wouldn't just be an ssk.
Offline smknjoe
« Reply #6 on: Tue, 20 January 2015, 14:06:28 »
Bummer. It's ruined.
...and is that a used rubber in the top right corner of the picture?!?
SSKs for everyone!
Offline Touch_It
« Reply #7 on: Tue, 20 January 2015, 14:25:15 »
Ruined is a relative term.  While I agree that as far as originality goes, yeah it is a goner.  However as far as functionality goes it is probably fine.  If I were in the market for an SSK I would be happy to have this assuming it stays around the 100-125 range.  However Cindy certainly spoils us with prices.
Offline smknjoe
« Reply #8 on: Tue, 20 January 2015, 14:30:56 »
The seller is full of ****. He bought it NIB and it's barely used, but he neglects to mention the ****ty paint job. Red flag city. $20-$40 tops is all I'd pay for it. ......stored in a closet for years...and the keycaps are two piece when they should be one piece...
« Last Edit: Tue, 20 January 2015, 14:34:06 by smknjoe »
SSKs for everyone!
Offline intelli78
« Reply #9 on: Tue, 20 January 2015, 14:34:10 »
Yea I'm thinking it's a deliberate attempt to confuse people into thinking it's an industrial.
Offline smknjoe
« Reply #10 on: Tue, 20 January 2015, 14:36:06 »
^^^Bingo. They saw the other Industrial priced at $999.
SSKs for everyone!
Offline Dihedral
  • Mostly Harmless
« Reply #11 on: Tue, 20 January 2015, 14:51:14 »
Amazed they didn't paint a few caps blue as well :D
Offline smknjoe
Re: Fake painted industrial SSK - beware
« Reply #12 on: Tue, 20 January 2015, 15:09:38 »
I'm no SSK expert, but they did have some with two piece keycaps and some without blue keycaps as well if I'm not mistaken. There are different model #'s for different versions.
If the seller had explained the paint job in the description - the listing would be much less suspicious.
« Last Edit: Tue, 20 January 2015, 15:11:11 by smknjoe »
SSKs for everyone!
Offline fanpeople
« Reply #13 on: Tue, 20 January 2015, 17:32:39 »
To:
Subject: Re: Details about the item: npr_listener sent a message about IBM Model M Space Saving Keyboard SSK ID5000133 41G3613 #261742103850
Sent Date: 21-Jan-15 10:30:24 AEDST
Dear
Nope, it's the factory darkish-grey finish.
- npr_listener
To: npr_listener
Subject: Details about item:               sent a message about IBM Model M Space Saving Keyboard SSK ID5000133 41G3613 #261742103850
Sent Date: 21-Jan-15 10:27:42 AEDST
Dear npr_listener,
Did you paint this? I think you should mention that in the description just to avoid someone having issues with what they receive in case they don't notice.
well........... now it is officially a scam?
« Last Edit: Tue, 20 January 2015, 17:38:26 by fanpeople »
Offline 0100010
  • Not Sure
« Reply #14 on: Tue, 20 January 2015, 18:33:15 »
Part number is correct for an industrial SSK.
https://geekhack.org/index.php?topic=54340.0
Re: NOT FAKE NOT painted industrial SSK - no need to beware after all. maybe
« Reply #15 on: Tue, 20 January 2015, 18:56:46 »
So why does it look so hideous, gritty, and mottled?
- D Trump 2026-10-24
Offline intelli78
« Reply #16 on: Tue, 20 January 2015, 19:10:38 »
Offline fanpeople
« Reply #17 on: Tue, 20 January 2015, 19:19:37 »
Interesting isn't it. The top just looks horrid though. Is it possible that the bottom is legitimate but the top is off a normal SSK. Like a frankenboard.
Or could it just be dirty and bad photo?
« Last Edit: Tue, 20 January 2015, 19:22:33 by fanpeople »
  • Live long and prosper
« Reply #18 on: Tue, 20 January 2015, 19:21:46 »
Quite possible... but why would anyone do that to an industrial SSK?
tp thread is tp thread
« Reply #19 on: Tue, 20 January 2015, 19:21:53 »
Edit: dammit tapatalk... y u double post?
Offline FrostyToast
  • Litshoard
« Reply #20 on: Tue, 20 January 2015, 19:21:58 »
The bottom looks painted over as well.
There are a bunch of visible imperfections...
Quote from: elton5354
Offline DrHubblePhD
  • I am star stuff
« Reply #21 on: Tue, 20 January 2015, 19:22:59 »
I thought the industrial models had a more textured surface, this seems almost flat...
Offline Zeal
    • Zeal Generation Inc.
« Reply #22 on: Tue, 20 January 2015, 19:24:22 »
Before:
After:
Does this look better? 5mins touch up.
Looks like it's covered in a layer of dust.
Back label doesn't look like imperfect paint. Just long dust / pet hair strands?
« Last Edit: Tue, 20 January 2015, 19:28:13 by Zeal »
Offline fanpeople
« Reply #23 on: Tue, 20 January 2015, 19:25:38 »
Do you reckon I should ask the seller for some more photos? Maybe wipe the board with a cloth?
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #24 on: Tue, 20 January 2015, 19:34:28 »
Did some more cleanup. You're welcome.
« Reply #25 on: Tue, 20 January 2015, 19:35:27 »
hehehe
Offline Snowdog993
« Reply #26 on: Tue, 20 January 2015, 21:11:20 »
It might be just a crappy picture.  But I still think it is painted over.  Why?  I don't know.  Only the seller knows apparently.
But then again, I looked at the listing with the new picture, and the color is better.  I'm still not convinced.  Maybe he lost the keys or replaced them.  You never know what can happen in 20+ years.  If he is the original owner, he should know more than he does.
« Last Edit: Tue, 20 January 2015, 21:17:08 by Snowdog993 »
« Reply #27 on: Tue, 20 January 2015, 21:18:15 »
Seller seems legit per an ebay message I received and he has seen this thread, I told him you guys were a bunch of nut bags. :P
Offline fanpeople
« Reply #28 on: Tue, 20 January 2015, 21:19:18 »
Oh snap
He added another photo, I think I want it now....... :'(
« Reply #29 on: Tue, 20 January 2015, 21:20:27 »
seems legit enough...
rack up those bids ppl...
Offline Zeal
Re: Industrial SSK @ $100
« Reply #30 on: Tue, 20 January 2015, 21:21:06 »
gg. Let the bid war begin.
Offline Snowdog993
« Reply #31 on: Tue, 20 January 2015, 21:22:43 »
At least I am nuts.  It does look good in the new picture.
I'll show you a painted bezel.
Offline FrostyToast
  • Litshoard
« Reply #32 on: Tue, 20 January 2015, 21:26:57 »
Wow. That's a really nice paint job.
Still fake.
Yup.
Definitely fake.
I say about tree fiddy.
If a guy possibly named FrostyToast bids higher than that, the dude is a fsking moron.
Whew, got 'em good Frosty.
IKR other Frosty, they won't realise that I'm joking. Fsking nerds aren't even going to look again.
Yeah I know Frosty. Now what's this worth? 10,000 bucks?
Yeah we'll go with that. Go for it, pal.
« Reply #33 on: Tue, 20 January 2015, 21:32:58 »
Funny story....hope he doesn't mine me sharing....he had another one that he threw away because it got dirty. :eek:
Offline Zeal
« Reply #34 on: Tue, 20 January 2015, 21:33:58 »
rip
Offline Snowdog993
« Reply #35 on: Tue, 20 January 2015, 21:36:25 »
Those first pictures had me convinced that it was painted.  That's a given.
Offline fanpeople
« Reply #36 on: Tue, 20 January 2015, 21:36:44 »
I hate him, ask him where his local rubbish dump is? I will tell the police that it is evidence in a case of crazy and they will find it for me?
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #37 on: Tue, 20 January 2015, 22:33:40 »
He will be kicking himself so hard when the bidding concludes on this one :))
« Reply #38 on: Tue, 20 January 2015, 22:50:45 »
People throw them away, shred them, just send them all to me instead!  I'll even pay postage!
Offline smknjoe
« Reply #39 on: Wed, 21 January 2015, 07:07:08 »
The new pic looks like a completely different and legit board. I wonder what those spots were on it? Rat piss?
Snowdog, I'm with you man. Those first pics were really bad. I'm convinced it's real now, but I'm still not sure it was well taken care of considering the before and after pics. Good luck to whoever get's it.
SSKs for everyone!
Offline smknjoe
« Reply #40 on: Wed, 21 January 2015, 07:19:06 »
The more I look at the before and after pics the more I see that it was a ****load of dust on the before pics. The dark spots are where the dust has been rubbed off from handling it. Someone ask him to take another pic of the back now that it's all cleaned up.
SSKs for everyone!
Offline Ellipse
    • Brand New Model F and Beam Spring Keyboards
« Reply #41 on: Wed, 21 January 2015, 09:05:36 »
The seller updated his listing with a note as well.   Seems like he was using iPhone photo filters that distorted the original images.   It looks to be in great shape and a "real"  I SSK despite not having the IBM logo on top.
« Reply #42 on: Wed, 21 January 2015, 09:09:02 »
I still wouldn't touch it, even at $100.
Offline Snowdog993
« Reply #43 on: Wed, 21 January 2015, 10:13:52 »
I wouldn't either.  The model number of the keyboard is for an IBM Personal Systems 2 Space Saver Keyboard.  It does look exactly like one from that.  I don't see where the "industrial" portion of it falls into place at all.  I will pass.
Edit: Specifically standard SSK.
« Last Edit: Wed, 21 January 2015, 10:20:12 by Snowdog993 »
Offline Ellipse
« Reply #44 on: Wed, 21 January 2015, 12:47:19 »
The model number 41G3613 is a variation of 41G3600 which is the more common industrial SSK part number.   Google it and you can see examples.   This one up for auction is not a mod or a "regular" SSK. It should fetch $800 to $1000 without the logo.
IBM/Lexmark issued many part numbers for parts with virtually no variation so this is not out of the ordinary.
« Last Edit: Wed, 21 January 2015, 13:14:49 by Ellipse »
Offline Snowdog993
« Reply #45 on: Wed, 21 January 2015, 13:00:32 »
Good luck however you feel about it.  I told you what I discovered.  Take it or leave it.
Offline intelli78
« Reply #46 on: Wed, 21 January 2015, 13:01:52 »
Maybe you should explain the source of your information...
Offline Snowdog993
« Reply #47 on: Wed, 21 January 2015, 13:11:16 »
Okay.
http://www.ebay.com/itm/IBM-Personal-System-2-Space-Saving-Keyboard-Model-M-Clicky-PS-2-New-in-Box-/131110156558?pt=PCA_Mice_Trackballs&hash=item1e86c6390e&afsrc=1&rmvSB=true
That one sold for 2 grand, and it was for the IBM PS/2.
IBM Personal System 2 Space Saving Keyboard Model M Clicky PS/2 New in Box
You are bidding on a vintage IBM Model M Space Saving Personal System 2 Keyboard.  It is brand new and has never been used.  The box was only opened to inspect and verify the contents.  The PS/2 interface cord is still sealed and wrapped.  If you are looking at this you know how rare it is and how often these come along.  Please ask all questions before bidding.  It comes with box and foam as well.  Item has all feet and the elevators are in perfect working condition.  The shipping will be fully insured to your street address.  Thanks for looking and happy bidding.  Serious bidders only please.
Part Number: 41G3613
Date: 11-03-92
Offline smknjoe
« Reply #48 on: Wed, 21 January 2015, 13:14:38 »
That was an Industrial SSK that sold.
SSKs for everyone!
Offline intelli78
« Reply #49 on: Wed, 21 January 2015, 13:14:42 »
Ah, but that auction was for an industrial board. The pics are gone now, but we had a big discussion about it on GH. That's exactly why it went for $2k.
