Author Topic: Cherry MX brown discontinued ?  (Read 13602 times)
Re: Cherry MX brown discontinued ?
« Reply #50 on: Wed, 21 January 2015, 10:29:44 »
didt they say a long time ago that they would produce ergo clears if there was enough interest?
Yes but the numbers were outrageous IIRC.
« Reply #51 on: Wed, 21 January 2015, 10:57:14 »
browns are the only tolerable mx switch, and thats because they remind me of topre
Where's the :puke: emoticon??
« Reply #52 on: Wed, 21 January 2015, 11:00:32 »
so many gifs to choose from :eek:
« Reply #53 on: Wed, 21 January 2015, 12:36:52 »
@demik: Topre is the iOS of keyboard switches. Expensive, proprietary, locked in, unmodifiable, almost 0 keycap options. Cherry is the Android. Inexpensive, open, easily modified and customised to your own tastes and preferences, huge range of keycap options.
You want something between a 45g and 55g? Too bad bro.
You want to try different keycap profile? Too bad bro.
You like that new thick doubleshot GMK keycap set from BunnyLake? Too bad bro.
You want a PBT spacebar that matches your set? Too bad bro.
Unless you ALSO buy a Novatouch and swap sliders.
You want to type without bottoming out? Too bad bro.
You like one of the two Topre switch options? Good for you... if the board layout you want comes in that option.
If not? Too bad bro, unless you spend twice as much so you can do a dome swap.
These are just some reasons that make Browns better than Topre (simply because they're an MX switch). Even though they're still a compromise between Reds and Clears. They're just 2 steps away from perfection. Stem and spring swap and you've got 62g ErgoClears or 62g/65g Blacks.
P.S. - I'm just pissed 'cos I'm still waiting for my milky BroBot that I'm sure I won. I get that, I'll throw away all my MX stuff, buy a HHKB and stop making long and useful posts and instead simply say "Get a HHKB" in every thread.
none of that matters to me tbh. dont really care to own a million diff keysets that i wont use. the classic sets are enough (again, to me). it provides the switch weight i like.
not my fault topre is perfect. blame the japanese.
Offline azhdar
  • Praise the AZERTY god
« Reply #54 on: Wed, 21 January 2015, 12:42:03 »
Hard to believe they would stop browns , it's the most popular switches on stock keyboards .
What would be great is they replace browns with ergo-clears .
Azerty Propagandiste
Offline yomammary
« Reply #55 on: Wed, 21 January 2015, 12:43:36 »
Yes.
RF 87u 55g | Leeku 1800
« Reply #56 on: Wed, 21 January 2015, 12:48:17 »
the only issue I would see is that ergo-clears vary so widely there isn't a set in stone definition of them, some people prefer lube some don't and the range of switches used varies greatly.
Offline azhdar
« Reply #57 on: Wed, 21 January 2015, 12:51:34 »
They could simply pull a spring from blue/red/browns , recolor the clear stem and create a simple ergo-clear.
We (picky geekhackers ) will still find a way to mod it or look for vintage north korean springs, but at least people that don't mod would have something way better .
Offline pesky brat
« Reply #58 on: Wed, 21 January 2015, 16:13:23 »
Kk
Offline Huxley2500
« Reply #59 on: Wed, 21 January 2015, 16:52:18 »
If it don'T click it don't stick.
Offline faceyourfaces
« Reply #60 on: Wed, 21 January 2015, 17:09:50 »
Loving the browns hate. Too bad it will be a long, long time before I can lay my fingers upon a Topre switch.
Offline kittykatmax
« Reply #61 on: Wed, 21 January 2015, 17:30:42 »
I love my Cherry MX Browns and hope the switch isn't going away.  My main board is a Max Keyboard Blackbird with browns.  It replaced a CM Storm QFS (also with MX browns), because I missed having a back-lit keyboard, and I loved that the keycaps were double-shot.  Before that I had a CM Storm QFR with MX Blues.  I liked MX Blues, especially the sound, I just didn't like gaming with them.
I have multiple RSIs, so a low actuation force is better for me (haven't had a chance to try Cherry MX reds, yet.  I tried one of those tester kits, but it was useless).  I like being able to have keycap options, so I haven't bothered to check out Topre, and I've tried but didn't enjoy Alps (hubby's pricey Datamancer "Executive" keyboard - which he set aside for my old CM QFR with MX Blue!).
Ultimately, though, I'm waiting on AcidFire's keyboard project.
Offline Merranza
« Reply #62 on: Wed, 21 January 2015, 17:49:50 »
If I may vouch for the reds, the more I type on them, the more I love them. Been a week now since I have my new keyboard and I'm getting the feeling the switches are slowly broking in. It's so smooth and easy on fingers/hands/wrists it's really a pleasure to type on them. Weirdly, some people say they are boring compared to browns. For sure, with browns you get that light tactile feedback but it's not true you have no feeling with reds. I'm feeling the spring way more with linear switches than with tactile where the bump takes all the place. I'm not really a touch typist yet (will try to work on it in the next months) but sometimes I get that focus/speed burst where I can chain a streak of words at my fastest speed and you literally get the feeling your fingers are flying/dancing on keys. It's pretty hard to describe :) You have to try this really.
Offline kittykatmax
« Reply #63 on: Wed, 21 January 2015, 17:56:20 »
I've been curious about trying a 60% keyboard...maybe I'll pick one up with reds.
« Last Edit: Wed, 21 January 2015, 17:58:26 by kittykatmax »
Offline RoflCopter4
« Reply #64 on: Wed, 21 January 2015, 17:58:46 »
I hope Cherry goes out of business entirely.
Acer KB-101A with Blue Alps | HHKB Pro 2 | '85 122 Key IBM Model F | '86 1390131 "Silver Label" Model M | AEK M0115 with Orange Alps | Focus FK-2001 White Alps | Chicony 5181 with SMK "Monterey Blue" Switches | Dell AT101W | Unicomp "Ultra Classic" | Razer Blackwidow 2013
Offline Merranza
« Reply #65 on: Wed, 21 January 2015, 18:01:33 »
Looking how the mainstream keyboards are selling with cherry switches right now, I think your hopes won't be fulfilled for a little while...
Offline snipars
« Reply #66 on: Wed, 21 January 2015, 18:06:46 »
that'd be crazy, although i doubt it would happen
Duck Octagon + Gateron Black |HHKB Pro 2 | Poker 2 + Vintage Black + Tex case | Unicomp Ultra Classic | WASD V2 |
Offline RoflCopter4
« Reply #67 on: Wed, 21 January 2015, 18:16:49 »
I'm just being an ass. Of course it won't happen. As through most of Cherry's history, keyboards is a pretty small portion of their business. Mechanical keyboards could stop selling entirely on a dime and Cherry would be fine.
« Reply #68 on: Wed, 21 January 2015, 18:57:55 »
Unfortunately, Cherry clones would probably become standard after then as opposed to Matias Alps or some other switch.
« Reply #69 on: Wed, 21 January 2015, 19:41:02 »
At least you are good at it.
Offline Oobly
« Reply #70 on: Thu, 22 January 2015, 02:49:41 »
You sure about that, bro? Don't you even want to try a 55g HHKB? Or POM keycaps? Well you can't, but don't you want to? Come on, you know you do.
If they keep doing business they way they are now, they just may... They really need to put some more effort into smoothing the stems / quality control and actually creating some kind of innovation of their products, but at the moment they're all talk and no action, whereas the clone makers are stepping up their game. To be honest, I think they'll survive, there'll always be Cherry MX switches, but the clone makers will be gaining more and more market share regardless. If I were a clone maker (or Cherry themselves), I'd reduce the range to 3 switches, 62g Linear, Tactile (Clear stems) and Clicky. No Brown sliders, no "quiet" click sliders and no "light" and "heavy" springs, just 62g.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #71 on: Thu, 22 January 2015, 09:33:00 »
pbt is fine. i dont feel a difference between materials anyway :(
Offline GL1TCH3D
« Reply #72 on: Thu, 22 January 2015, 11:57:07 »
Just take a weekend trip to my place and try some topres =)
(Though there are probably several people in your city with topre)
Offline ynrozturk
« Reply #73 on: Thu, 22 January 2015, 19:32:19 »
Ugh not this again..
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline blazarcher
« Reply #74 on: Thu, 22 January 2015, 20:59:54 »
Filco Majestouch Ninja - Poker I
