Author Topic: PMK not resolving correctly?  (Read 2996 times)
Offline engicoder
« on: Wed, 21 January 2015, 17:10:04 »
PMK seems to be switching to gymnastics.
88132-0
« Last Edit: Wed, 21 January 2015, 17:22:00 by engicoder »
Re: PMK not resolving correctly?
« Reply #1 on: Wed, 21 January 2015, 17:18:21 »
Works for me!
88130-0
« Reply #2 on: Wed, 21 January 2015, 17:30:26 »
It's damn slow for me tonight but gets there in the end (took about 4 minutes...)
« Reply #3 on: Wed, 21 January 2015, 17:37:03 »
PMK site always seems slow to me.
Offline sidel
« Reply #4 on: Wed, 21 January 2015, 17:45:37 »
I'm getting gymnastics as well.  lol.
Offline engicoder
« Reply #5 on: Wed, 21 January 2015, 17:48:00 »
I hear you!! You should try setting up all the child deals for a group buy on it.
Offline hjc1710
« Reply #6 on: Wed, 21 January 2015, 17:54:30 »
You are not alone on that. Their site is horrendously slow, and horrendous on mobile.
They use WordPress for the whole thing. WP isn't exactly known to be fast, but it's not that slow. They need to cache more (WPTotalCache would help), or, ideally, rebuild it and use a real framework instead of trying to leverage a CMS  :p
Filco Majestouch II (B) | Poker II (BR) | Cherry G80-11900 (BLK) | Das V3 (BR) | RS84 (soon...)
Granite | Skull Squadron | Deep Space | Raindrop R2 | Hyperfuse GMK (soon...)
Offline Data
« Reply #7 on: Wed, 21 January 2015, 18:47:01 »
That's your DNS doing that. Try replacing your DNS with the Google servers and see if it resolves correctly.
8.8.8.8
8.8.4.4
You can also try the Level3 servers:
4.2.2.1
4.2.2.2
Offline Smasher816
  • HHKB Master
« Reply #8 on: Wed, 21 January 2015, 18:49:07 »
Getting the normal site.
I would guess there is some DNS discrepancy, probably depending on your ISP / area in the world as Data is getting at. I'm curious where the people it doesn't work for are.
Edit: both me and sidel are in CA. I guess it's not a wide are thing, we just happen to be on different ISP's.
Offline engicoder
« Reply #9 on: Wed, 21 January 2015, 19:15:57 »
I'm using OpenDNS
208.67.222.222
208.67.220.220
Edit: As of now, it returns a 404.
« Last Edit: Wed, 21 January 2015, 19:18:32 by engicoder »
Offline Data
« Reply #10 on: Wed, 21 January 2015, 19:21:00 »
I'm using OpenDNS: 208.67.222.222 and 208.67.220.220
The only other possibilities are:
  • IP Conflict -- on the web?  Not at all likely.
  • Nameservers issue at the host or at the registrar -- I'd give this one a 10% chance
  • Malware browser redirect or something/someone has put a bogus static route in your HOSTS file -- this one is most likely, after DNS
