Author Topic: Corsair RGB K65 - $100.00 + shipping  (Read 3942 times)
Offline mogo
« on: Sat, 24 January 2015, 21:24:00 »
http://www.ebay.com/itm/Corsair-K65-Rgb-/181649250410?pt=LH_DefaultDomain_0&hash=item2a4b23986a
Like new keyboard for 50 bucks under retail, probably won't last long. I really wanna get it JUST to cannibalize all those awesome clear switch housings from it, but I think I'll wait for a broken board (hopefully cheaper) to go up and let someone get this working one for now.
Re: Corsair RGB K65 - $100.00 + shipping
« Reply #1 on: Sat, 24 January 2015, 21:32:26 »
Pretty much the only reason to get it.
« Reply #2 on: Sat, 24 January 2015, 21:34:32 »
What good are the clear switch housings without the RGB LEDs on the PCB?
« Reply #3 on: Sat, 24 January 2015, 21:36:37 »
To look sexy.
« Reply #4 on: Sat, 24 January 2015, 21:37:50 »
To look sexy.
But they don't have holes for regular leds....people want them for boards with no backlighting?
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #5 on: Sat, 24 January 2015, 21:51:32 »
There's lastpilot's boards...
GON NerD TKL DTA Edition
Offline mogo
« Reply #6 on: Mon, 26 January 2015, 13:10:58 »
NeRD boards also allow for SMDs, and I'm planning on using SMD for my endgame board, so I really need those clear housings. :)
Offline mogo
« Reply #7 on: Mon, 26 January 2015, 13:11:43 »
And that specific build is so damn inspiring, it has been a great source to look at for planning my dream build. :b
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #8 on: Tue, 27 January 2015, 20:20:02 »
My Shine II is my fallback and may actually be a sleeper endgame board, but...I got a hankerin' to build me a Phantom boys...and I would sho nuff put some clear cased switches on that badboi
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
« Reply #9 on: Tue, 27 January 2015, 20:22:56 »
Why would you want clear cased switches on a phantom? It doesn't have any backlighting.
Offline 00zeRO
« Reply #10 on: Tue, 27 January 2015, 20:25:27 »
Because I want to light it up like a NerD
« Reply #11 on: Tue, 27 January 2015, 21:39:12 »
But there's no LED backlighting on a Phantom.
« Reply #12 on: Tue, 27 January 2015, 21:58:02 »
If we keep saying it will it sink in?
Offline berserkfan
« Reply #13 on: Tue, 27 January 2015, 22:29:05 »
lemme guess, he just wants the excuse to drill into his pcb, add the pads, wire them up, add resistors, etc. He's THE GEEKHACKER of the year if he's willing to change a non-LED board into an LED board and post his build log!
Offline Lain1911
  • God of the Wired
« Reply #14 on: Tue, 27 January 2015, 22:58:18 »
Can rgb leds be bought yet?
Offline 00zeRO
« Reply #15 on: Wed, 28 January 2015, 11:39:55 »
They will be soon...
Offline 00zeRO
« Reply #16 on: Wed, 28 January 2015, 11:41:48 »
Okay, but if you modify the case with LED's attached to either a Scroll Lock or Num Lock key LED and provide the right resistance and voltage, you can light up the whole case. I am not necessarily looking to light up each key, just make the case glow...sheesh...
