Author Topic: Regarding GMK Classic Beige GB - UPDATE 27/07/15  (Read 170152 times)
Offline byker
  • Literally Canada
Re: Regarding GMK Classic Beige GB
« Reply #450 on: Fri, 17 July 2015, 02:08:53 »
It is starting in the next couple of weeks.
Offline KHAANNN
« Reply #451 on: Fri, 17 July 2015, 09:01:25 »
at the risk of being a **** -
it would be great if a single 1.5u R4 blank is added too (or 2)
Offline azhdar
  • Praise the AZERTY god
« Reply #452 on: Fri, 17 July 2015, 09:04:29 »
For cherry profil blanks you have the Gateron blanks provided by shadovved right here that will provide you a lot of blanks that will match a classige beige set.
Also it is to be said again, this is not an interest check thread, photekq is just stating what will be in the upcoming GB, he's not taking inputs.
« Last Edit: Fri, 17 July 2015, 09:52:40 by azhdar »
Azerty Propagandiste
« Reply #453 on: Fri, 17 July 2015, 09:27:55 »
Wait, really? So I should be saving some dough?
Offline KHAANNN
« Reply #454 on: Fri, 17 July 2015, 09:49:16 »
Thanks it's a good idea, I didn't consider using Cherry blanks from other manufacturers before
Although, If I decide to do it, I wouldn't color match, It's better to use a different color than a similar-color that doesn't 99%+ match the originals
« Reply #455 on: Fri, 17 July 2015, 12:08:43 »
I won't be adding anything at all to the set. The mockup in the OP is final (+ 2x blank 1.25u R4 keys not shown). What would you need blank R4 1.5u keys for anyway? HHKB layout?
Offline KHAANNN
« Reply #456 on: Fri, 17 July 2015, 12:14:39 »
I want it for a HHKB like layout, but 1.25 blanks work too, since there is additional space, 1.5 also opens up possibilities
Another usage is 1.5Alt + 1.5Blank winkeyless usage with osx - it's not something I'm going to use, but other people might like to use it in the future, in this scenario, the Control is bumped up to R3 with the 1.75 keycap that's already included
« Reply #457 on: Fri, 17 July 2015, 12:21:38 »
Right, I see. Makes sense. I won't be adding them to this one though. If you keep adding little things to cater to everyone it never ends. I feel the current set will allow most popular layouts to be used, even if the legends aren't 100% perfect for some of those layouts.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #458 on: Fri, 17 July 2015, 12:22:33 »
Can we add a 10u spacebar? I want to have CB on my WYSE board
Offline KHAANNN
« Reply #459 on: Fri, 17 July 2015, 12:27:29 »
I agree, I think someone needs to do a GMK Blanks GB - with several blanks for most used base colors - would simplify things a lot
« Reply #460 on: Fri, 17 July 2015, 12:34:38 »
This.
If everything's set in stone I can't imagine bothering the organizers with requests. A separate GB for additional keys seems best.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #461 on: Sun, 19 July 2015, 23:15:39 »
It's the end of the week, when is it starting?
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #462 on: Sun, 19 July 2015, 23:17:15 »
December 32nd
Offline uJalled
  • Shrimp cracker enthusiast
« Reply #463 on: Sun, 19 July 2015, 23:18:02 »
December 32nd
RIP my heart
Offline KHAANNN
« Reply #464 on: Sun, 19 July 2015, 23:20:27 »
Since the Dark Miami Nights GMK GB isn't completed yet, I'm guessing this one won't launch
Offline xqwtz
« Reply #465 on: Mon, 20 July 2015, 02:10:53 »
Is this the case, photekq?
« Last Edit: Mon, 20 July 2015, 02:12:34 by xqwtz »
Offline radio_killah
  • Chinchillin'
« Reply #466 on: Mon, 20 July 2015, 02:23:08 »
You guys really need to find something else to do besides wait for this group but to start. Potek is a regular person, busy just like the rest of us. Sit tight guys. It will happen.
Offline Ngt
« Reply #467 on: Mon, 20 July 2015, 02:59:04 »
wise words we should all listen to!
WHEN DOES IT START? :p Joking I'm not in the hurry any way.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #468 on: Mon, 20 July 2015, 07:30:53 »
This isn't true, he had to rework the shipping as the shipping rates changed
Offline kirkvomit
« Reply #469 on: Mon, 20 July 2015, 09:04:04 »
I want it just for retro win keys, will it bepossible to buy modifier keys separately?
Offline azhdar
« Reply #470 on: Mon, 20 July 2015, 09:05:42 »
Maybe once the GB get launched you can arrange to split a kit with someone, it's a very common thing to do.
« Reply #471 on: Mon, 20 July 2015, 10:56:40 »
This
No, sorry.
That isn't what's stopping me. I'll launch regardless of whether or not that's still running.
Offline 64rky
« Reply #472 on: Mon, 20 July 2015, 11:00:03 »
Yay! I'm in for two! When's this starting ;)
Offline Ngt
« Reply #473 on: Mon, 20 July 2015, 11:08:13 »
Yeah I might join for one as well. :)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #474 on: Tue, 21 July 2015, 13:18:02 »
Hi photekq,
Glad to see the little updates on your plans for the GB :)
I hope to be able to join :D
Offline gameaholic
« Reply #475 on: Tue, 21 July 2015, 15:14:28 »
Insert excitement gif of your choice
Here
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline clacktalk
  • circa 2015
« Reply #476 on: Tue, 21 July 2015, 15:19:23 »
I'LL BUY A SET IF U START THE GB
I GUESS I MEANT "WHEN" BUT "IF" WORKS TOO
diary of a clacktalk
radio_killah: too much frank
Offline ATXTider
  • I keep it playa while some choose to play it safe
« Reply #477 on: Tue, 21 July 2015, 15:42:36 »
QFT
« Reply #478 on: Tue, 21 July 2015, 15:43:21 »
GO AWAY FRANK
« Reply #479 on: Tue, 21 July 2015, 15:46:35 »
Don't you guys understand this is all part of the experience?  If you want a "classic" and "well-aged" colorway, you have to wait a sufficient amount of time.  Otherwise it might as well be called the New Beige GB, and nobody wants that.
Offline byker
  • Literally Canada
« Reply #480 on: Tue, 21 July 2015, 15:56:48 »
That is true. The caps are aging as we speak.  ;)
Offline Air tree
« Reply #481 on: Tue, 21 July 2015, 15:58:02 »
Like a fine wine.  ^-^
« Reply #482 on: Mon, 27 July 2015, 03:41:38 »
Good news!
Everything seems to be ready to go. I promised I would give roughly 1 weeks notice, and this is it.
So long as I don't discover any issues and so long as nothing changes, the GB will start in 1 week give or take a day or two.
Just as a recap, here are the final mockups :
7u and 6.25u spacebars in L9 will also be offered.
Pricing is as follows (changed slightly from last time as we will be having the sets presorted) :
Main set :
EU - £82.50 - 115EUR~
NON-EU - £72.50 - $112.50~
Extras set :
EU - £27.50 - 38.50EUR~
NON-EU £22.50 - $35~
Spacebars :
£2 - $3.1~ / 2.8EUR
As said before, EU is more expensive because the EU order sets will be shipped to me and VAT will have to be paid. However, you will pay no import charges, so you don't lose any money in the end!
Any questions please do post.
« Last Edit: Mon, 27 July 2015, 03:45:43 by Photekq »
Offline azhdar
« Reply #483 on: Mon, 27 July 2015, 03:47:32 »
I Believe .
« Reply #484 on: Mon, 27 July 2015, 03:48:07 »
I Believe .
but what do you believed?
Offline rm-rf
« Reply #485 on: Mon, 27 July 2015, 03:48:36 »
oh... this!
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
Re: Regarding GMK Classic Beige GB - UPDATE 27/07/15
« Reply #486 on: Mon, 27 July 2015, 03:57:57 »
Go go go  :cool:
Offline bazh
« Reply #487 on: Mon, 27 July 2015, 04:05:29 »
is the price included shipping?
HHKB Pro2 white
Newbie again
« Reply #488 on: Mon, 27 July 2015, 04:12:54 »
No. The price for the main set non-eu is just about the same as every other GMK GB. I'd be losing a tonne of money if it were that price incl. shipping.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #489 on: Mon, 27 July 2015, 04:30:43 »
 ;D YaY  ;D
It's bout to happen.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Ngt
« Reply #490 on: Mon, 27 July 2015, 04:43:25 »
I'm not sure I understand your answer. Is it included for the EU orders? If no, how much would the shipping fees be for EU order?
« Reply #491 on: Mon, 27 July 2015, 04:47:12 »
No, none of those prices are including shipping. I was just saying the non-EU set price is about the same as every other GMK buy. I specifically said non-EU since the EU orders are more expensive than most GMK buys due to VAT. Again, you pay no import charges if you're in the EU, so it will work out around the same price as if you were buying a set from a US-based buy if not a little cheaper.
Shipping to EU will cost £10 or something for like 1-3 sets I think.
Offline pcnnnn
« Reply #492 on: Mon, 27 July 2015, 04:55:37 »
Any chance you would consider moving the 1.75x Shift to the Main kit?
The current arrangement means that anyone who use a 60% with 1.75x R. Shift and 1x Fn would have to get the extra kits just for the two keys. It's kinda steep considering we only uses like half the keycaps of the main kit in the first place  :p
Offline swimmingbird
  • keyset hoarder
« Reply #493 on: Mon, 27 July 2015, 04:59:16 »
Fantastic news and great pricing!
Thanks for running this photekq!
« Reply #494 on: Mon, 27 July 2015, 04:59:46 »
You can say that of the 4 iso keys aswell. You can say that of the 4 windowed lock keys too. Eventually you're left with no extra kit.
You have to draw the line somewhere. I deliberately tried to make the extra kit full of commonly used (but not as commonly as the regular keys in the main set) keys to ensure it would reach MOQ. I also wanted to keep the main set to the absolute core keys needed for 1.25 and 1.5 layouts. I even considered only having one type of winkey in the main set but it was apparent that there's a great deal of disagreement when it comes to those keys.
The key selection will remain the same. It's absolutely final and has been for a very long time. I've considered everything and thought out the sets very carefully. In my eyes it is as good and as sensible as can be. It should also be noted that I have taken input from various members of the community.
« Last Edit: Mon, 27 July 2015, 05:02:09 by Photekq »
Offline Ngt
« Reply #495 on: Mon, 27 July 2015, 04:59:57 »
Thank you for the explanation. ;)
Offline KHAANNN
« Reply #496 on: Mon, 27 July 2015, 05:09:34 »
Please, please add a bumped F/J to the main kit, let's start making this a thing, the scooped one is not for everyone and the alphas are most probably the most important part of a kit as the modifiers can easily be outsourced one way or another (like CMYW or something)
(Edit: I'm going to join anyway, but probably going to join 2+ of each if the bump thing becomes a reality)
« Last Edit: Mon, 27 July 2015, 05:11:28 by KHAANNN »
« Reply #497 on: Mon, 27 July 2015, 05:17:07 »
1. The sets are final. It's not just me being lazy at this point. It's not even me being stubborn (which I am, admittedly). It's because I'd need to contact GMK for a new quote, wait probably a week for a response, update the pricing, etc.. i.e more delays - the absolute last thing I want!
2. I lurk a lot. I also did a lot of looking around while working out the key selection. I don't want to toot my own horn but I generally know what people want in a keyset. I came to the conclusion that people who prefer bumped F/J are a tiny minority. When it comes to GMK buys you just can't cater to minorities (sorry demik). Sure, it's only two keys, right? Yes. It will barely affect the cost. But how about just adding two more? It's only two again, you did it for the F/J keys.. It all adds up. The line has to be drawn somewhere. I've drawn the line where the sets are now - they're both packed full of useful keys, and are incredibly juicy. I just don't think bumped F/J would add anything for the vast majority of people.
1. is far more important at this point though. 2. is more just why they aren't there already. Seriously.. I don't want more delays.
EDIT : Now.. if we hit 400 orders that's a different story. Then I can consider it.
« Last Edit: Mon, 27 July 2015, 05:27:26 by Photekq »
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #498 on: Mon, 27 July 2015, 06:04:55 »
I was at lunch, came back, wanted to reply to write HORAY, 1800 support, hit reply and it was edited and gone :)
Offline Belfong
« Reply #499 on: Mon, 27 July 2015, 06:06:26 »
Has this been asked? Is this set pre sorted by GMK aka Triumph Adler?
