Author Topic: Would a Vortex Aluminum Case bring my QFR TKL back to life?  (Read 1381 times)
Offline anowt
  • "I want you to buckle my spring" ♪♪~
« on: Fri, 30 January 2015, 12:26:36 »
So I got a Topre board, and it makes my QFR TKL w/ mx blues feel puny by comparison. I think it's because the QFR TKL housing is plasticy. It just sounds plasticy and cheap. Would a vortex aluminum housing make it sound better? Anyone with experience on this?
« Last Edit: Fri, 30 January 2015, 12:30:02 by anowt »
Front Line: IBM Model M SSK
Tactical Team: QFR TKL (MX Blue)
Recon: KUL ES-87 (MX Red)
Special Operations: RF 87U 55g
Offline Oobly
Re: Would a Vortex Aluminum Case bring my QFR TKL back to life?
« Reply #1 on: Fri, 30 January 2015, 14:22:56 »
MX Blues do just sound plasticky and cheap. No way around that that I know of.
A metal case will definitely make the whole board feel more solid and better to use, but you may have to try a non-clicky MX switch (such as 62g ErgoClears, ahem) to improve the sound and feel.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline spiceBar
    • ChessTiger.com
« Reply #2 on: Fri, 30 January 2015, 18:29:27 »
I have noticed that an aluminum case tends to emphasize high-pitched frequencies, to it would make you keyboard sound even farther from the Topre "Thock" than it is now.
I think it would not save your QFR TKL.
Offline Valen
« Reply #3 on: Fri, 30 January 2015, 19:23:37 »
My TEX aluminum case does make my V60 feel more solid. On the down side, it emphasizes the ping that clear switches have but I don't really mind.
