Author Topic: Topre keycaps for Realforce 55g?  (Read 4164 times)
Offline overthetop
« on: Sun, 01 February 2015, 01:05:17 »
can you suggest some websites please?
Offline madhias
  • BS TORPE
    • Madhias' Flickr
Re: Topre keycaps for Realforce 55g?
« Reply #3 on: Sun, 01 February 2015, 02:40:37 »
http://stores.ebay.com.au/widebasket/Keyboard-/_i.html?_fsub=8043909010
Oh great, and now i want to buy some caps there...
Get 'em while you can - rumour has it that they are no longer being made.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #4 on: Sun, 01 February 2015, 03:02:39 »
The red set is very tempting for me! Fits nice to a beige/white/grey set - i could imagine also only some caps or a number row in red.
Offline Sygaldry
  • Edema Ruh
« Reply #5 on: Sun, 01 February 2015, 19:47:55 »
That is not something I needed to hear lol....
So tempted to get a white Realforce set and dye it to resemble the 10th Anniversary set.......................
But alas, my wallet cannot handle right now...
null
Offline dispenserg
« Reply #6 on: Sun, 08 February 2015, 11:42:16 »
I was thinking of buying a set for my HHKB Pro 2 but I've heard something about some of the keys not fitting. Can anyone clarify?
« Reply #7 on: Mon, 09 February 2015, 03:38:47 »
There is no complete coloured HHKB replacement set, just the white and black sets from EK (if they are still available).
I believe the RealForce sets will fit an HHKB, as long as you don't mind having some of the keys in the wrong places.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #8 on: Mon, 09 February 2015, 18:06:24 »
Yeah basically you have to cheat the short right shift with the number pad 0 key.  And maybe up arrow key for the FN key.
Offline tkim
« Reply #9 on: Mon, 06 April 2015, 05:10:06 »
I always look at getting these caps but the price turns me off, then I start going down the path of thinking well should I just pay $40 more and get another FC660C.  :))
Offline Sed8op8
  • Keyboard Padawan
« Reply #10 on: Mon, 06 April 2015, 05:23:48 »
$66 more now. The cheapest place I've seen the fc660 now is on ebay for $216 now that EK now longer stocks them!
