Author Topic: {GB} Clear Switch Covers ($0.20/ea) SOLD OUT  (Read 201492 times)
Offline Synjin
Re: {IC} PBT Blanks ($40/set) & Clear Switch Covers ($0.20/ea)
« Reply #50 on: Tue, 03 February 2015, 22:47:49 »
But still. I have a ton of stuff to finish. Sadly I now have to delay them because I now would like to be sign corn these first.
Offline Synjin
« Reply #51 on: Tue, 03 February 2015, 22:48:31 »
Yeah since that should be like +- 1-2 pieces at most.
Offline DrHubblePhD
  • I am star stuff
« Reply #52 on: Wed, 04 February 2015, 22:07:50 »
Two things I am always looking for, cant wait to add some of these tops to some of my boards  :thumb:
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #53 on: Wed, 04 February 2015, 22:15:22 »
Once mine come since I ordered directly, I can send you a few if you want to test them or since I know your other ones didn't work too well.
Offline Geroximo
« Reply #54 on: Thu, 05 February 2015, 13:05:37 »
Do these clear switch covers allow opening a plate-mounted switch without desoldering it?
If so, I'm in.
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #55 on: Thu, 05 February 2015, 16:39:08 »
If so, I'm in.
That would depend on the plate you are using more than the switch covers.......
You need a plate with notches cut out to allow removal of switch tops without desoldering :thumb:
Offline ideus
  • Björkö.
« Reply #56 on: Thu, 05 February 2015, 16:43:42 »
I need my clear tops badly, to build my Infinity with an Tex low profile case, it would look awesome.
Offline swornxin
    • Nailed Down Custom Pins
« Reply #57 on: Thu, 05 February 2015, 19:50:23 »
Would be interested in the switch tops.  Filled out form.
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline pmh1410
« Reply #58 on: Thu, 05 February 2015, 22:42:06 »
Hi Shadovved, i'm interest a set but i would to know who made it ?
I got some clear top cover and try custom it with Black 59g, it's very good and smooth. Product from Gateron ( not Abostudio)
Offline LechnerDE
« Reply #59 on: Fri, 06 February 2015, 08:03:27 »
Filled out the form.
I am especially interested in the thick PBT sets.
I prefer the grey tones, because blank sets in black / white are readily available.
Also, I'd prefer 1tone sets. At these prices I'd prefer to buy two sets for mix 'n' match. This way people can choose between classic and symmectrical look ("`~" and "\|" keys).
Concerning ISO it would be great if each set contained an extra 1.25 key (as left shift) and 2 extra alphas.
People could use the enter keys from other sets. An Enter key in a different color would be a nice accent on a blank set I think :thumb:
Offline ideus
  • Björkö.
« Reply #60 on: Fri, 06 February 2015, 08:29:32 »
When is this IC going to turn into a GB?
Offline Shadovved
« Reply #61 on: Fri, 06 February 2015, 09:06:13 »
Yes, it should be the same.
Offline Shadovved
« Reply #62 on: Fri, 06 February 2015, 09:06:48 »
I could ask if that could be purchased separately, the 1.25x and two 1x keys........probably just cost a little more on top of the set??
Currently the full beige/white and the full black sets are looking the most popular.
Could probably run the GB offering 1-tone sets and a select few 2-tone sets that are more popular.......really depends.
Offline Shadovved
« Reply #63 on: Fri, 06 February 2015, 09:06:54 »
Would start the GB probably late Feb, would like the samples to arrive before I jump into GB.
Offline Ngt
« Reply #64 on: Fri, 06 February 2015, 09:36:51 »
What is the purpose of the clear top? For the LED light to shine through the switch? That's purely an aesthetic mod, isn't it?
« Reply #65 on: Fri, 06 February 2015, 10:22:22 »
I'm really interested in this, I'll definitely be buying a set if the caps are white.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #66 on: Fri, 06 February 2015, 10:35:17 »
Clear switch tops are purely for aesthetic
Offline mroverkill
« Reply #67 on: Fri, 06 February 2015, 13:16:55 »
Definitely interested in a set of thick dark grey PBT blanks.
I'd consider picking up a set of white mods or even a full white set as long as they are pure white and not a beige or off-white.
Offline Shadovved
« Reply #68 on: Fri, 06 February 2015, 22:20:01 »
All the single colour options should be available seeing that interest is mainly in single colour sets.
Offline Shadovved
« Reply #69 on: Sat, 07 February 2015, 13:54:51 »
Manufacturer has given a number of 200 sets for $31, provided we can hit it :cool:
Offline ideus
  • Björkö.
Re: {IC} PBT Blanks ($31/set) & Clear Switch Covers ($0.20/ea)
« Reply #70 on: Sat, 07 February 2015, 14:00:21 »
Is the same date for both, the caps and the tops? Please excuse me if this has been explained before.
Offline Shadovved
« Reply #71 on: Sat, 07 February 2015, 14:02:07 »
Yeap, I'll run it together, if the interest for both is sufficient, if not, I'll run the one that is enough.
The clear tops is looking good, if that's what you are asking :))
Offline VinnyCordeiro
« Reply #72 on: Sat, 07 February 2015, 14:30:27 »
Form submitted.
Offline mroverkill
« Reply #73 on: Sat, 07 February 2015, 16:05:39 »
Awesome, I'm in for Dark Grey and White at $31/set for sure. Not sure if you need to update my form entry to reflect that.
Offline ideus
  • Björkö.
« Reply #74 on: Sat, 07 February 2015, 16:08:31 »
Give me my clear tops, take my money... :)
Offline Ngt
« Reply #75 on: Sat, 07 February 2015, 17:30:35 »
Will it be $10 to ship the caps internationally?
Can we take part in the GB without participating in the IC?
Offline yode
  • s a d b o y s
« Reply #76 on: Sat, 07 February 2015, 17:39:55 »
submitted... interested in a couple of sets. Been waiting for some thick pbt blanks...
300 OTF GBE OBLOCK ON BD
Offline ideus
  • Björkö.
« Reply #77 on: Sat, 07 February 2015, 17:59:40 »
I think so, they are always independent, however I do not see the point of not participating in the IC if you want to buy them.
Offline Ngt
« Reply #78 on: Sat, 07 February 2015, 18:10:37 »
Because I am not sure I want to buy them to be honest, so I don't want to twist the number by adding my command as I'm not sure it will be made.
Offline ideus
  • Björkö.
« Reply #79 on: Sat, 07 February 2015, 18:12:16 »
Then there is no rush, just wait until the GB be offered and you could join then, if your mind has arrived at a harbor.
Offline Ngt
« Reply #80 on: Sat, 07 February 2015, 18:13:43 »
Thanks that the answer I was looking for. :)
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #81 on: Sat, 07 February 2015, 19:47:06 »
Any word yet on whether the stepped caps lock is off centered stem or not?
Offline Shadovved
« Reply #82 on: Sat, 07 February 2015, 20:26:05 »
No need, you already have one set logged under your name, I just need to gauge the interest for colours and numbers, not if you are definitely in or not :))
Offline Shadovved
« Reply #83 on: Sat, 07 February 2015, 20:28:34 »
And no. Not yet. Nobody's replying me on weekends. But I'll make sure to ask ASAP, it is a pressing concern! ;D
Offline Shadovved
« Reply #84 on: Sat, 07 February 2015, 21:10:43 »
And it is confirmed, stepped lock side stemmed, non-stepped lock centre stemmed.
« Reply #85 on: Sat, 07 February 2015, 21:37:54 »
So quick. Thanks a bunch! :) I'm so in for this.
Offline PB82
« Reply #86 on: Sat, 07 February 2015, 22:57:44 »
Any info on the texture on these?
Offline Shadovved
« Reply #87 on: Sun, 08 February 2015, 00:39:58 »
Texture as in? The surface of the cap?
I'm can only guess that it's like the BSP ones, or maybe a little more textured.
I'll need to feel it when the sample arrives.
Offline cinnamoncider
  • Thorpies are snappy
  • No clack; no life.
« Reply #88 on: Sun, 08 February 2015, 07:46:43 »
Signed-up for dark grey mods and light grey alphas  ;D
Offline mroverkill
« Reply #89 on: Sun, 08 February 2015, 12:04:54 »
Meant to clarify two full sets, one dark grey, one white.
Offline Shadovved
« Reply #90 on: Sun, 08 February 2015, 16:42:09 »
Alright, I'll change your entry to 2 sets instead.
I'll put your colour choice as dark grey first since white has enough votes to survive anyway :))
Offline hjc1710
« Reply #91 on: Sun, 08 February 2015, 17:22:38 »
In for 100 clear switch tops :thumb:.
Filco Majestouch II (B) | Poker II (BR) | Cherry G80-11900 (BLK) | Das V3 (BR) | RS84 (soon...)
Granite | Skull Squadron | Deep Space | Raindrop R2 | Hyperfuse GMK (soon...)
Offline mroverkill
« Reply #92 on: Sun, 08 February 2015, 19:54:54 »
Great, that's what I would have wanted anyway.
Offline Shadovved
« Reply #93 on: Mon, 09 February 2015, 17:59:34 »
Yeap, edited for you :thumb:
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #94 on: Mon, 09 February 2015, 18:34:34 »
I may be interested in some of these. They look to be great quality for the price. A good opportunity to try blanks. I will review how this is planned to work and go from there.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #95 on: Mon, 09 February 2015, 18:39:51 »
Sorry random question. Will the mods include the two caps | and ~ in the mod color so we can have a symmetrical layout?  Would that be possible to support?  Thx...
Offline Shadovved
« Reply #96 on: Mon, 09 February 2015, 19:07:53 »
Probably will have it in both symmetrical layout and non-symmetrical layout, will need to ask the manufacturer to add extra caps.
But if the price goes down further, you guys probably can buy two sets and mix it according to your needs :thumb:
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #97 on: Mon, 09 February 2015, 20:22:14 »
Ya. That's what I was just thinking. I see in the spreadsheet that the price per set is $40, but in the thread it is $31.  I am guessing the $31 number is more current?
Thanks for doing this BTW. I forgot to mention that initially. I have much love for people with the gonads to run GBs. :)
Offline Shadovved
« Reply #98 on: Mon, 09 February 2015, 20:37:07 »
Yea, thanks for pointing it out, I have edited the form accordingly :thumb:
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #99 on: Mon, 09 February 2015, 20:40:21 »
Cool. So do I understand correctly that if we get a bunch more orders we could potentially get additional reductions?  This could be one of the best pbt options available right now. Really excited to hear what your impressions are when you get the samples.
