Author Topic: [GB] (CLOSED) TX1800 [Finished]  (Read 608015 times)
Offline kin25
    • TXKeyboards
Re: [GB] TX1800 (Housing, PCB, Parts, Keycaps)
« Reply #250 on: Sat, 14 February 2015, 11:15:58 »
Old black is vintage black?
Right. vintage black very smooth slider
Offline tjweir
« Reply #251 on: Sat, 14 February 2015, 13:04:34 »
Hence the reason I'm buying lots. :)
Offline Sygaldry
  • Edema Ruh
« Reply #252 on: Sat, 14 February 2015, 13:10:30 »
OMG with the Purple caps, I can't decide if I want to go with Grey or Silver Case......
FML.
I wanted to submit my order last night but I couldn't decide!  :'( :'( :'(
null
Offline tjweir
« Reply #253 on: Sat, 14 February 2015, 13:12:27 »
FML.
Ya, I'm now thinking about a PBC and plate as well.
Too many awesome group buys going on here right now!
#firstworldproblems
Offline Sygaldry
  • Edema Ruh
« Reply #254 on: Sat, 14 February 2015, 13:14:30 »
FML.
#firstworldproblems
Yeah I think those caps would look phenomenal with an original Cherry housing as well!
Ki, do you know if the Plate and PCB combo would be compatible with a G81-1800 housing? I only have a G81-1800 and not a G80-1800 so I'm not sure if they are the same. (I know this has been asked before but I don't think anyone gave a definitive answer)
« Last Edit: Sat, 14 February 2015, 13:26:05 by Sygaldry »
null
Offline kin25
    • TXKeyboards
« Reply #255 on: Sat, 14 February 2015, 13:32:56 »
FML.
#firstworldproblems
you can use pcb and plate on original housing (g81 or g80)
but
you must cut the housing a little.
it's not hard to cut.
Offline Sygaldry
  • Edema Ruh
« Reply #256 on: Sat, 14 February 2015, 13:33:53 »
FML.
#firstworldproblems
but
Which parts need to be cut?
null
Offline kin25
    • TXKeyboards
« Reply #257 on: Sat, 14 February 2015, 13:58:20 »
FML.
#firstworldproblems
but
i will take some pictures and post in March.
in this month, i have no time to do..
next week is korean new year holidays.
I'm going on a trip for a week.
Offline Sygaldry
  • Edema Ruh
« Reply #258 on: Sat, 14 February 2015, 14:00:36 »
FML.
#firstworldproblems
but
Ah okay.
Have a good trip!
Just one last question: if I had a G80-1800 case, nothing would need to be cut at all?
« Last Edit: Sat, 14 February 2015, 14:02:47 by Sygaldry »
null
Offline BlackDragonTribal
  • BDT
« Reply #259 on: Sat, 14 February 2015, 15:43:15 »
Offline kin25
    • TXKeyboards
« Reply #260 on: Sat, 14 February 2015, 20:59:58 »
there is a little difference between g80 and g81 housing.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #261 on: Sun, 15 February 2015, 04:07:20 »
I am already checking what caps i (will) have which fit, regarding rows especially. Unfortunately there are not that many sets out there which would cover the whole board! I'm happy with this layout since i have so many Round 5 caps ordered, that i could cover this board i think 3 times :)
I am not sure yet if to buy these PBT caps together with the TX1800 or not, they look very nice though!
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #262 on: Sun, 15 February 2015, 09:17:15 »
what's the last day we can submit an order?
Trying to make sure I've got money lined up for this!!!
Edit: nvm, I'm dumb. So the 28th is the last day correct?
« Last Edit: Sun, 15 February 2015, 09:19:19 by ApocalypseMaow »
Offline kin25
    • TXKeyboards
« Reply #263 on: Sun, 15 February 2015, 09:33:21 »
Right, FEB.28.
Offline kin25
    • TXKeyboards
« Reply #264 on: Sun, 15 February 2015, 12:59:03 »
Update.
I took some Proto keycaps from Lyn3.
These are just Proto... so the quality is not the best.
He is trying to increase the quality.
I think the quality is getting better.
(Numpad keycaps were not printed yet.)
90867-0
90869-1
90871-2
« Last Edit: Sun, 15 February 2015, 14:42:59 by kin25 »
Offline monotagary
  • Keycaps > Rent
« Reply #265 on: Sun, 15 February 2015, 13:47:25 »
Update.
I took some Proto keycaps from Lin3.
That purple looks so good.
Offline exitfire401
  • The Force is Re/\l
« Reply #266 on: Sun, 15 February 2015, 13:51:34 »
Yup...you just informed my thoughts that the purple caps would look amazing on gray. So glad I've got that order in.
Offline kin25
    • TXKeyboards
« Reply #267 on: Sun, 15 February 2015, 14:13:07 »
Yes, the pictures for you. :)
Offline stoic-lemon
« Reply #268 on: Mon, 16 February 2015, 03:40:48 »
Damn it. It was hard enough just thinking about buying a keyboard. Those caps look fantastic.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #269 on: Mon, 16 February 2015, 05:28:31 »
This is the FIRST individual here on Geekhack to offer a complete 1800 based keyboard with all the PBT keys supplied as well  :o .
Doesn't get any better than this people  :thumb: :thumb: :thumb: :thumb: .
Offline kin25
    • TXKeyboards
« Reply #270 on: Mon, 16 February 2015, 05:50:17 »
Thanks~
I hope this GBers will be satisfied with housing, keycaps and other parts.
 ;D ;D
Offline captvizcenzo
« Reply #271 on: Mon, 16 February 2015, 06:04:04 »
Kin, I replied your email. Waiting for your feedback so I can decide whether I'll have it it assembled in Korea or local at my place. ;D
Offline Prelim
« Reply #272 on: Mon, 16 February 2015, 06:35:39 »
no 65g springs?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline tjweir
« Reply #273 on: Mon, 16 February 2015, 07:28:26 »
Offline Chromako
  • Worshipper of the Topre and IBM Gods
« Reply #274 on: Wed, 18 February 2015, 03:01:33 »
Wow. I really wish I had the funds to buy this, but I'm still recovering from my Model F restoration that went way over budget. gah.
Anyway, this looks awesome, and I love the TX1800 layout. I wish you all the best!
Thou Shalt Not Violate Causality, Nor Shalt Thou Invert Thy Spacebar.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #275 on: Wed, 18 February 2015, 03:13:04 »
Go for the budget option and order just the plate and PCB and use the case of an G81-1800. It's not often you can get your hands on a backlit 1800 board. ;)
|||My other keyboards :
x
Offline Elrick
  • Hype Master
« Reply #276 on: Wed, 18 February 2015, 17:15:53 »
Kin25, have just sent you a pm detailing what I want from you.
An all BLACK Mamba TX1800 keyboard, this will be the ONE I've been looking for such a long time, please make this happen soon here on Geekhack  8) .
Offline monotagary
  • Keycaps > Rent
« Reply #277 on: Wed, 18 February 2015, 17:47:13 »
April is soooooooooooooooooo far away.
Offline exitfire401
« Reply #278 on: Wed, 18 February 2015, 17:51:29 »
My wallet is weeping in anticipation of its arrival...this and the alu hhkb case is going to put a deep hurtin on my finances for the next few months
Offline Ouro
  • Laughable
« Reply #279 on: Wed, 18 February 2015, 18:02:58 »
The purple set with Hangul  :eek: I won't allow myself to miss this group buy.
Offline monotagary
  • Keycaps > Rent
« Reply #280 on: Wed, 18 February 2015, 18:14:56 »
Oooohhh God, why is 2015 the best year for GBs but also the year of me having no so little disposable income...
At least I will have nice keyboards.  :(
Offline Sygaldry
  • Edema Ruh
« Reply #281 on: Wed, 18 February 2015, 18:15:44 »
Every year is the year of me having so little disposable income...  :'(
null
Offline exitfire401
« Reply #282 on: Wed, 18 February 2015, 18:21:48 »
With any luck, I won't like the v3 brobot design, and then I'll have plenty of disposable income!
Offline monotagary
  • Keycaps > Rent
« Reply #283 on: Wed, 18 February 2015, 19:02:18 »
What a wishful thinker you are!  ;D
Offline Eiji
  • Saa eins zwei drei.
« Reply #284 on: Wed, 18 February 2015, 21:09:22 »
Ordered a bunch of parts, any estimates on shipping cost since it's nothing big like the case or PCB Kin?
Offline exitfire401
« Reply #285 on: Wed, 18 February 2015, 21:15:53 »
I know...I'm going to love it and continue to be broke
« Reply #286 on: Wed, 18 February 2015, 21:28:04 »
Still not sure black or gray case  :-\
Offline Dee1
« Reply #287 on: Wed, 18 February 2015, 22:45:45 »
You could always get both! :P
I got black for myself, but the grey does look really nice. :)
Offline monotagary
  • Keycaps > Rent
« Reply #288 on: Thu, 19 February 2015, 00:39:33 »
Such is life here at wallet hack.
Offline kin25
    • TXKeyboards
« Reply #289 on: Thu, 19 February 2015, 03:51:40 »
sorry.. I'm in China in this week to enjoy korean and chinese new year holidays.
It's difficult to connect to GH.
on Monday i'm going home.
i will reply then.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #290 on: Thu, 19 February 2015, 05:49:06 »
Hey Kin, can you show us a picture of the G80-3000 pcb?
x
Offline Elrick
  • Hype Master
« Reply #291 on: Thu, 19 February 2015, 06:34:06 »
i will reply then.
No worries, enjoy your celebrations we all can wait till this Monday for more details.  Happy New Year of the Goat  :thumb: .
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #292 on: Thu, 19 February 2015, 07:20:09 »
Where did you get the aluminum HHKB case?
Mmm... machined aluminum
« Reply #293 on: Thu, 19 February 2015, 07:56:42 »
I'm thinking more towards grey...
Offline exitfire401
« Reply #294 on: Thu, 19 February 2015, 08:00:21 »
I haven't, there are 2 potential upcoming group buys for one.
Offline Sygaldry
  • Edema Ruh
« Reply #295 on: Thu, 19 February 2015, 10:06:04 »
2? I've only seen Mimic's. Which one is the other one? O.o
null
« Reply #296 on: Thu, 19 February 2015, 11:26:59 »
If anyone is just buying caps and not the board I will buy your short shift if you don't need it.
Offline tjweir
« Reply #297 on: Thu, 19 February 2015, 11:33:51 »
It appears that LYN is making prototype caps for a few people as Duck has a bunch of awesome looking pictures on his site.
http://duck0113.tistory.com/113
Edit: I think these are pushing me off the fence to get a set.  :3
Offline monotagary
  • Keycaps > Rent
« Reply #298 on: Thu, 19 February 2015, 12:21:43 »
I was about to say the same thing... Who else is doing this besides Mimic?
« Reply #299 on: Thu, 19 February 2015, 12:25:28 »
Doesn't OP say you can buy just the caps at a slightly higher price than GB with the keyboard price?
