Author Topic: MX Blues with what spring?  (Read 1399 times)
Offline ManicMatt1125
« on: Thu, 05 February 2015, 11:58:11 »
Hi, I have searched and have not found a definitive answer. I am trying to simulate MX greens. I have the option of getting blues with 55g, 58.5g and 62g springs. My question is which spring choice will most likely replicate MX greens?
Re: MX Blues with what spring?
« Reply #1 on: Thu, 05 February 2015, 12:01:18 »
I think they've got 80g springs? You want those.
None of the options you listed will be anywhere close to being like Greens.
Edit: Sprit says his 85g springs are close to being the weight of MX Clears. And 100g is close to MX Grey which have the same spring as MX Green.
  • Live long and prosper
« Reply #2 on: Thu, 05 February 2015, 12:02:46 »
Get Green springs? :P
But seriously, you want MX Heavy springs (Blacks, Greens, Clears)
tp thread is tp thread
« Reply #3 on: Thu, 05 February 2015, 12:03:44 »
Also what CLiB said. Ghetto Greens are MX Blue Stems with MX Heavy springs and they're pretty close to Greens imo. If I didn't find stock MX Greens, I would've put Ghetto Greens in my KMAC.
« Reply #4 on: Thu, 05 February 2015, 12:23:34 »
hmm, This is for a GON board, I am hiving it pre-assembled so those are my only options, aside from me buying the springs separate and doing it myself ( which won't happen as I don't have the time) Thanks for the answers, I guess I will go with the 62g
« Reply #5 on: Thu, 05 February 2015, 12:24:59 »
If they are 62G korean springs, they will feel like regular Blues...
if they are regular 62G springs, they will feel slightly heavier than normal Blues...
