Author Topic: What could be the cause of this issue?  (Read 27199 times)
Offline Lukeyslife
Re: What could be the cause of this issue?
« Reply #50 on: Mon, 02 March 2015, 14:44:36 »
Here is a screenshot link for the Hardware Monitor including temps and voltages:
http://s21.postimg.org/408enp5x3/screee.png
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #51 on: Mon, 02 March 2015, 15:01:24 »
Voltages look to be WAY under spec.
+12 is at 8.016
+5 is at 3.145
I am thinking this is the majority of the issue
Do you have a volt meter that you can measure voltages with directly off the PSU with it out of the PC?
All you have to do is disconnect ALL power cables from the PSU and put in a jumper between the green and any black wire on the big plug that feeds into the motherboard.  With the switch on the PSU on it will turn on as soon as you install the jumper.
If you are getting close to these same numbers, the PSU is toast.  If you get normal numbers, it is either to close to max and is voltage is dropping due to efficiency dropping because to close to max loads.
Offline Lukeyslife
« Reply #52 on: Mon, 02 March 2015, 15:34:56 »
+12 is at 8.016
+5 is at 3.145
I mean the PSU is only around maybe nearly 2 months old now, it was a new one because the old one (same model) was faulty the fan controller would go nuts randomly and make very loud noises like a grinding sound.
So do I need a bigger PSU?
I thought 650W was fine for my setup giving me enough head room
Offline Lukeyslife
« Reply #53 on: Mon, 02 March 2015, 15:37:03 »
+12 is at 8.016
+5 is at 3.145
Also would it matter if it's plugged into a anti-surge extension socket, it's an extension socket which has around 5 sockets and 3 are taking up although only 2 are actually being used. I do have in my wall outlets 5 different sockets taken up would that affect anything?
Offline Melvang
« Reply #54 on: Mon, 02 March 2015, 15:38:47 »
+12 is at 8.016
+5 is at 3.145
That is why I am suggesting check it without anything plugged in.  It could also be bad voltage regulation on the motherboard.  Either way those voltages can't be in spec.
+12 is at 8.016
+5 is at 3.145
I wouldn't think so.  The PSU is going to convert AC to DC and should be cleaning up the signal anyway.
Offline jacobolus
« Reply #55 on: Mon, 02 March 2015, 16:01:46 »
All the voltages being off by 30% has to be way way out of spec. No wonder stuff is behaving wonky. In a properly functioning machine it shouldn’t ever get more than a few percent off.
I wonder if those numbers are accurate though. Can you test with a multimeter?
« Last Edit: Mon, 02 March 2015, 16:06:33 by jacobolus »
Offline Lukeyslife
« Reply #56 on: Tue, 03 March 2015, 14:09:35 »
I will ask my parents if they have one, I'm not 100% sure we will but I may be in luck
Offline munch
« Reply #57 on: Tue, 03 March 2015, 17:48:57 »
it's not about how many watts you have, just so you don't go and buy something extremely overkill, but rather the quality of the power supply - how stable power it can deliver etc (simplifying it here :p).
you should be fine with much less than 650w, as long as it is a good PSU.
Offline Oobly
« Reply #58 on: Wed, 04 March 2015, 01:24:40 »
Those figures are WAY off what they should be, but I strongly suspect they're wrong. Many people have the same issue of voltages incorrectly reported and they seem to be somewhat similar to the ones you list, so it looks like the only way to see the actual values would be with a multimeter. The system wouldn't boot with 8v on the 12v lines.
And I was wrong about the 500W requirement, sorry, seems that 500W is the recommended minimum for your combination of CPU / GPU, so 650W still has some headroom. All the newer PSU's are switching to improve efficiency and include filtering and smoothing, so by the time the power is coming out the PSU it's been quite well conditioned. Quite often a faulty capacitor can cause problems, though. I have a Zalman 600W PSU that made one particular motherboard of mine really struggle to boot. Replaced a couple of capacitors with higher quality ones and hey presto, better than new :)
So I'm afraid we're not much closer to a solution yet, but I do think it has at least a little to do with regulation / smoothing / ripple / noise / interference on one of the lines.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Lukeyslife
« Reply #59 on: Wed, 04 March 2015, 11:26:41 »
yeah last night I launched speed fan and the 12v rail was displaying 12.20v and I also read that HW monitor is very unreliable as far as voltages go.
However the 3.3v rail is always set to 2.49 in Speedfan so I'm guessing that could be the line which is the problem, the rest seem on par.
Also I forgot to mention in my OP that mid way through this ordeal, maybe exactly a year ago my mice felt worse than they did now A LOT worse.
I remember one time that I think my PC either rebooted or my PC had crashed or something, but the PC kind of glitched and the next time I used the PC the mouse felt completely different?
So from some weird power glitch it actually changed how it felt and has stayed that way ever since, back before this happened the mice felt even slower and less precise.
Offline Lukeyslife
« Reply #60 on: Wed, 04 March 2015, 13:27:17 »
Hmmm I'm so confused ahaahha,
I unplugged my mouse around 3-4 times last night because of my PS/2 adapter didn't work so I gave up, now my mouse feels a lot better again for some reason.
I'm not bragging, but even when I have 85-95% accuracy in my mouse not even 100% I can destroy.
This images prove it's not placebo, just my natural aim etc.
It would just be nice to have 100% aim so I could let rip again  :D :))
http://s17.postimg.org/obsav60r3/de_dust20003.jpg
Offline Lukeyslife
« Reply #61 on: Thu, 26 March 2015, 06:59:54 »
Hi everyone,
So i'm back in a way ahaha.
So i've just been using my PC the way it is lately, I am now nearly sure it's something to do with power not just how the mouse feels but my speed of the PC overall.
I did notice when I originally installed my new RAM ages ago (1-2 years) the PC was way faster and the new CPU.
Since this problem had occurred I notices the PC felt slower.
Now today I decided I would plug my PC into a wall socket, I used to have it on a anti power surge extension (which has 5 sockets on it).
I plugged it in this morning and my PC instantly booted a lot faster and everything has sped up?.
I do have my modem and router all plugged into the same area, I'm wondering whether the wall sockets are being drained too much by different units (monitors, modem, router)
Offline Melvang
« Reply #62 on: Thu, 26 March 2015, 19:09:42 »
Sounds like a cheap power strip
Offline heedpantsnow
  • Old enough to know better
« Reply #63 on: Fri, 27 March 2015, 10:21:39 »
Usually computers behave weirdly when there are power issues. I've never, ever heard of one feeling slower because of power.
Could be a component or drive with intermittent problems that slows the OS due to wait states, theoretically exacerbated by power fluctuations. But I'd say it's a stretch.
I'm back.
Offline Lukeyslife
« Reply #64 on: Fri, 10 April 2015, 12:47:11 »
Hi everyone again,
So on this issue I bought another gaming PC which I am aiming to sell, at the time I thought it would be a good idea to test the rig and see whether or not it was just my PC that forced mouse movements to feel off.
I'm not 100% sure about it being slightly placebo, I notice a difference movements feel sharper; BUT it feels the same so I have completely wiped my PC from being the cause which is great news.
The only bad news is that it is either to do with my monitor, or worse the power leading to the computer isn't good enough.
So yeah the mouse still feels off, I can make movements it feels almost smoothed out. When playing CSGO trying to make large movements it feels as if I hit a barrier and the mouse slows when I hit a certain point
it's extremely weird.
I'm guessing it has to be the monitor but I don't know how the monitor is causing the issue as such, is it just picking up mouse input wrong on screen in correlation to the GPU?
I will try another monitor even a TV just to compare I'm hoping this should finally nail it down.
