Author Topic: Deck forums shutting down operation  (Read 12372 times)
Offline hyperlinked
« Reply #50 on: Sat, 05 September 2009, 17:48:28 »
Quote from: mike2h;115089
it is as good as its going to get baring any improvemants from another surgery- wich i have serious doubts about. my mission is to not let it get worse, have seen-as i know you have- to many people let their injury/pain get the best of them. after a while it is an easy thing to do.
It's good that you're determined to not allow your injury to limit you from living as normal of a life as possible, but really try to have the discipline to know when enough is enough for your body. It's like that phrase, "live fast, die young."
"Fast" is a different speed for everyone depending on their unique set of circumstances. Hold back enough so that you don't wear out your parts. Of course, this is easy for me to say and I suspect that if I were in your shoes, I'd be exactly the kind of person who would be so determined to be not defined by my disability that I'd be gung-ho to the point that it'd eventually come back to haunt me in my later years.
If you continue to need pain killers to get through typing sessions even after you've become proficient at typing properly and have developed the coordination and hand endurance you need, it might be time to consider an adapted approach like some of the other input methods that people have suggested here.
for reference, before i injured my arm i was doing curls with 45lb dumbells- 2 sets of 10. recently got myself to doing 1 set of 10 with 15lb. my goal is 2 sets of 8 with 20lb but dont think its going to happen. i can still do the 45lb with my lt arm;)
Curls with 45lb dumbells! Dude, you had some serious guns back in the day! No wonder this is so frustrating.
Again, without having access to a medical record for you, I can't say too much, but it may be a better goal to shoot for 2 sets of 15 with 8lbs or 3 sets of 20 with 5 lbs with your right arm. You need endurance far more than you need raw strength to carry out daily tasks and condition your hand and arm to hold up better throughout the day.
For someone looking to develop athletic power and a great beach physique, 2 sets of 8 reps would be perfect, but for you, number of reps means far more than the actual weight because the goal isn't to get you to the point in which you can move heavy objects with ease again.
« Last Edit: Sat, 05 September 2009, 17:51:06 by hyperlinked »
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline hyperlinked
« Reply #51 on: Sat, 05 September 2009, 18:22:50 »
Quote from: webwit;115133
You should really look into the DataHand. It may not be the solution, but there's a chance it's the perfect one for your situation, and if that is the case, it is "cheap". Only problem is you can't try these (or even buy these)to check if this is really the case ;)
If he's having fine motor control problems (coordination) as a result of his injuries, DataHand might not help much because you'll probably actually need to have more coordination to use it instead of less.
Offline mike2h
« Reply #52 on: Sat, 05 September 2009, 19:49:43 »
thx guys. think ill give the deck kb a few months before i try anything else. first ill have a short adaption period to it then ill have a much longer period were ill be 'learning' to type & then(& during) getting my arm used to what i assume will be new & diffent use of my arm muscles.
great to know i have this thread to refence back to if it comes down ot me having to look at other options.
aside from that, kinda 'ancy' waiting for my new kb(next fri) already plannin on changinging the QWASDE keys to green leds a little down the road. i can order them from deck & they are compatible with existing power so i dont have to swap out resistors, so thats cool. think the green wiil look good contrasted against the white leds.
