Author Topic: Tex 60% Case w/ feet?  (Read 99118 times)
Offline awhitedev
« on: Sun, 22 February 2015, 19:47:28 »
I was looking to buy one of your Tex 60% cases. Do these come with aluminum feet? If not, are there any options for a 60% case that is slightly elevated?
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: Tex 60% Case w/ feet?
« Reply #1 on: Mon, 23 February 2015, 11:05:01 »
No aluminum feet. They come with 4 large Rubber feet, and 6 small Rubber feet.
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline drewba
« Reply #2 on: Thu, 05 March 2015, 11:39:37 »
Came here to find an answer to this question. Just ordered one, thanks!
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #3 on: Sun, 08 March 2015, 19:37:41 »
hey dudes, i just had a quick question about the tex cases.
i have a bronze and black...
the bronze tex case seems to have an opening for dipswitches fitted for pokers
while the black tex case fully exposes the v60 dips,
which models do you guys currently have in stock?
Offline 00zeRO
  • * Moderator
« Reply #4 on: Mon, 09 March 2015, 19:12:16 »
That is a great question. To our knowledge, the screws are in the wrong spot on the current batch to fit a V60 without some sort of modification. Sight unseen, since I am at home away from the office until tomorrow, I will have to say that they fit the smaller 4 DIP layout of the Poker II. I will know better once I get to the office tomorrow... :thumb:
Offline drewba
« Reply #5 on: Mon, 09 March 2015, 21:45:02 »
Hoping this is helpful - I received my tex today from mechanicalkeyboards.com and it definitely came with the larger rectangular opening for the dips.
Offline Cotay
« Reply #6 on: Sat, 03 June 2017, 11:09:00 »
So what are the chances that the purple Tex 60% case is ever coming back in stock?
Offline 00zeRO
  • * Moderator
« Reply #7 on: Mon, 05 June 2017, 12:12:33 »
This larger hole is to accommodate larger DIP switch banks. Many newer keyboards have 6 instead of 4.
Offline drewba
« Reply #8 on: Tue, 06 June 2017, 14:52:01 »
I appreciate the follow up 2 years later  ;D :p
Offline Cotay
« Reply #9 on: Tue, 06 June 2017, 22:38:12 »
Maybe I'll get a response in 2 years.  ;D
Offline 00zeRO
  • * Moderator
« Reply #10 on: Wed, 07 June 2017, 13:19:04 »
Gah...good gravy. So very sorry for that...not sure how we missed seeing the new response after two years...
Offline 00zeRO
  • * Moderator
« Reply #11 on: Wed, 07 June 2017, 13:20:48 »
Not sure of the chances...we are still waiting for production. I'd imagine it will be a good chance, though we won't likely stock many of them.
Offline drewba
« Reply #12 on: Fri, 09 June 2017, 16:59:15 »
I was just goofing around. I purchased the TEX case from you guys awhile back and very happy with it!  :thumb:
