Author Topic: XTant plate *shipping to me*  (Read 17788 times)
« on: Fri, 27 February 2015, 17:57:26 »
I have contacted a place about getting custom XTant plates made. He has estimated $70/ea for a small run of 5. Does anyone else with a prototype kit want one?
This is a GB for XTant prototype plates. You will most likely be able to use these with the production version but that has not yet been determined. WCass has his working using this plate and the prototype PCB. I plan to finish up my prototype kit with this plate. You may consider joining this GB if you plan to build a prototype XTant.
This GB will close on March 4. Payment is expected at the time the GB closes (or beforehand). If the price ends up being less than your payment I will partial refund the difference. Everyone is splitting shipping from the shop to me, which I will bill you for when I ship them to you.
Since there are only 10 prototype PCBs, and one has already been made, I figured getting a quote of 5 is a good start. Please refer to the XTant topic for details on the project as a whole.
https://geekhack.org/index.php?topic=51767.0
I will be monitoring this topic and will respond to questions here or via PM.
Interest list:
[1] dorkvader *paid*
[1] prdlm2009 *paid*
[1] HaaTa *paid*
[1] Hypersphere *paid*
[1] Fohat.digs *paid*
[1] Muirium (DT) *paid*
[1] Melvang *paid*
Total : 7/7
Here is a word from WCass about the Prototype kits:
The two rivets on the back plate are not where they need to be. I removed them using a rotary tool with a cut wheel - cut away the flange on the back of the plate then popped the tops off. The new PCB has one hole for a new stud between the Caps Lock and A and another hole between right bracket and pipe-backslash. The second of these two holes is not in the best location and I plan to move it between Enter and up arrow. You might make a new hole in the PCB there and use that. I used two clamps to hold the PCB to the back plate to mark the location to drill new holes. Aligned properly, you should see two white silkscreen dots through the old rivet holes on the back of the back plate. Mark the back plate through the new holes and drill with a 1/8" bit. Secure the PCB with two #4-40 x 1/4" flat head machines screw (plate side) and weld nuts (PCB side), and #6-32 x 3/8" bolt with a star washer on the PCB side. With the back plate facing up, put the rivet washer over the #6 bolt and around the captive nut. Put on the controller, star washer and then nut. Feed wire through controller and switch PCBs and solder on both sides. Columns 13 thru 16 go to ground on the switch matrix PCB, so no wires there if using xwhatsit controller (it might confuse the controller) but wires there should be OK for DPH controller (designed to auto-skip grounded columns).
Basically: some work is needed to get them put together properly. The location of some holes is not ideal. You can use the original XT backplate if you are prepared to drill new holes in it. I will be fully documenting my assembly efforts in a similar style to the bolt mod guide I did earlier.
NEWS
3/4 plates close at 8 orders
3/5 Shop contacted with order
3/5 Error found in one of the CAD drawings. New file created
3/5 Shop contacts me back: $75/plate
3/6 Shop contacts me back with payment details. They take paypal. Payment is due before shipment. They have added our order to the queue.
3/6 with this info in hand I will start billing/invoicing.
3/6 payment PM sent
3/15 if I haven't heard back form them by 3/20, I will contact the shop again and voice my disappointments.
4/30 plates are done.
4/30 plates are paid for and in transit to me
« Last Edit: Thu, 30 April 2015, 23:38:48 by dorkvader »
Offline vivalarevolución
Re: XTant plate
« Reply #1 on: Sat, 28 February 2015, 07:03:35 »
Just wanted to reiterate my interest here.
Offline berserkfan
Re: XTant plate
« Reply #2 on: Sat, 28 February 2015, 17:42:40 »
methinks you should wait one more week, or else send a mass pm to the 9 remaining people with the PCB.
At these tiny production runs, every additional order can bring down the price quite a bit.
Re: XTant plate
« Reply #3 on: Sat, 28 February 2015, 21:41:38 »
I have started contacting people who have kits and will extend the deadline if need be.
Edit: I have contacted everyone I know to have a prototype kit.
« Last Edit: Sat, 28 February 2015, 22:40:10 by dorkvader »
Re: XTant plate
« Reply #4 on: Sun, 01 March 2015, 09:29:20 »
I would like to get one, let me work on it.
« Last Edit: Sun, 01 March 2015, 14:28:09 by fohat.digs »
"A whole civilization will die tonight."
- D Trump 2026-04-07
Re: XTant plate
« Reply #5 on: Sun, 01 March 2015, 14:27:43 »
OP updated with an idea of the sort of work you will have to  do to make a prototype XTant kit into a working XTant.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: XTant plate
« Reply #6 on: Sun, 01 March 2015, 14:49:56 »
While I don't have the disposable income for one of these right now, if anyone wants one but doesn't want to do the work for any reason, I will offer build services along with floss mod.
Re: XTant plate
« Reply #7 on: Wed, 04 March 2015, 00:00:10 »
GB ends today (march 4). If you are interested, please register your interest now. I will be contacting the shop with the final order and sending invoices tomorrow.
Offline Melvang
Re: XTant plate
« Reply #8 on: Wed, 04 March 2015, 00:09:10 »
We are on the same page here, right?
Re: XTant plate
« Reply #9 on: Wed, 04 March 2015, 01:36:43 »
I have marked *paid*, should clear things up.
Re: XTant plate
« Reply #10 on: Thu, 05 March 2015, 11:56:19 »
gb is now over. Invoices going out soon.
« Last Edit: Thu, 05 March 2015, 16:52:02 by dorkvader »
Offline Melvang
Re: XTant plate *invoicing*
« Reply #11 on: Thu, 05 March 2015, 12:08:20 »
Now for some of us, how would we go about sourcing a PCB?
« Reply #12 on: Thu, 05 March 2015, 16:54:19 »
News: updated CAD files sent to shop. I have also contacted them about my final order and what type of payment they take.
The gerber files are available. You can download them and send them to a PCB fabrication shop of your choice. Since one-off PCBs are so expensive, you could do a small run like WCass did with the initial prototype.
I recommend that you wait on a second prototype PCB run until we get some more of the first run finished. I think there was some discussion about moving the mounting holes to a better location.
Also, you can try contacting WCass to see if he has any more PCBs left.
Edit: I got a final quote from the shop at $75/each for the XTant plates.
« Last Edit: Thu, 05 March 2015, 17:12:04 by dorkvader »
Re: XTant plate *waiting*
« Reply #13 on: Tue, 24 March 2015, 09:16:37 »
Any updates?
Offline Melvang
« Reply #14 on: Tue, 24 March 2015, 09:22:13 »
If someone can locate a full sized printable file for the layout, I can make foam mats.
« Reply #15 on: Tue, 24 March 2015, 09:39:31 »
Located:  https://github.com/wcass-/XTant/tree/master/XTant
« Reply #16 on: Tue, 24 March 2015, 19:48:45 »
Any updates?
Oh I will have to call them and sort it out.
I have tomorrow off so hopefully I can do it then.
that'd be awesome.
« Reply #17 on: Tue, 24 March 2015, 19:56:43 »
that'd be awesome.
The awesomeness has been completed by wcass:  https://github.com/wcass-/XTant/blob/master/XTant/XTant%20pad.pdf
Although I can't seem to get it to print right.  Maybe contact wcass for the pdf file as an attachment rather than the link.
Offline Melvang
« Reply #18 on: Tue, 24 March 2015, 21:26:25 »
that'd be awesome.
I will download that and see about getting it printed somewhere on something heavy enough to actually use as a template multiple times.
Would anyone be willing to buy mats for this, say $15 shipped?
« Reply #19 on: Sun, 05 April 2015, 16:32:21 »
Any updates?
Offline berserkfan
« Reply #20 on: Mon, 06 April 2015, 11:00:37 »
still waiting for the obligatory porn photos...
« Reply #21 on: Tue, 07 April 2015, 19:32:05 »
Any updates?
I made a note to call them during my lunchbreak at work tomorrow
Offline Melvang
« Reply #22 on: Tue, 07 April 2015, 19:50:20 »
Has anyone gotten in touch with Unicomp about doing a small run of caps that will be needed for this?
« Reply #23 on: Tue, 07 April 2015, 20:01:26 »
Not sure.  What we need is a keyset like below, except a Caps Lock key in the Caps Lock spot, and probably all blanks for the left hand F-key cluster.
96667-0
Offline Melvang
« Reply #24 on: Tue, 07 April 2015, 21:19:58 »
I was debating on getting in touch with them anyway to see about doing a mod set group buy with symbols similar to 7bits round 4 stuff.  But for this I think more traditional legends would be best.  I will do some drawing on ideas in the next few days.
« Reply #25 on: Wed, 08 April 2015, 08:48:56 »
Which exact symbols are you referring to?  I'm quite sure that Unicomp will only do symbols and labels that have previously appeared on IBM and Unicomp keyboards.
Offline Melvang
« Reply #26 on: Wed, 08 April 2015, 08:52:59 »
  I have already contacted 7bit for use of these legends and he said it was fine and offered to send me the svg files.
« Reply #27 on: Wed, 08 April 2015, 09:30:56 »
That would be super cool, those are great symbols.
Offline Melvang
« Reply #28 on: Wed, 08 April 2015, 11:53:05 »
Email has been sent to Unicomp.  If they are willing to do it, would standard or these symbols legends be prefered.  Either way, I was going to post an IC for these legends for a standard group buy with possible kits for other popular boards such as the AT, unsaver, SSK, etc.
« Reply #29 on: Wed, 08 April 2015, 12:37:25 »
I'll be interested to hear what they say.
« Reply #30 on: Tue, 21 April 2015, 21:03:12 »
wait explained:
shop was waiting for a purchase order from me. I didn't know they needed one. I submitted a PO and they doublechecked the drawings i had. i expect to have more news soon.
thank you for your patience.
Offline Touch_It
« Reply #31 on: Tue, 21 April 2015, 21:13:37 »
that'd be awesome.
Yes
« Reply #32 on: Thu, 30 April 2015, 15:49:54 »
just got word: plates are done. i will pay for them now.
« Reply #33 on: Thu, 30 April 2015, 18:23:41 »
Solid news.
« Reply #34 on: Thu, 30 April 2015, 23:36:52 »
plates are paid for. financials updating soon.
Re: XTant plate *shipping to me*
« Reply #35 on: Fri, 08 May 2015, 21:01:52 »
i have some bad news
the plates got bent the wrong way. it's my mistake. not sure what i can do about it. next week i will look around locally for people that can bend these.
« Last Edit: Fri, 08 May 2015, 23:17:14 by dorkvader »
« Reply #36 on: Sat, 09 May 2015, 07:41:46 »
Oops.  Potentially dumb question, but would it be possible to just kind of use the plate flipped or something?  Or will that not work with the PCB?  I'm having difficulty visualizing in my head.
« Reply #37 on: Sun, 10 May 2015, 12:04:08 »
it would need a new pcb (think of it this way: arrowkeys on the left 10 function keys on the right.
I'll see if i can get them flattened and bent locally, but it might have to wait a bit for me to raise the funds.
it would be MUCH cheaper to just print new pcbs but the awkward position of some keys (right shift) and reverse staggar make it unappealing i think.
« Last Edit: Sun, 10 May 2015, 12:27:39 by dorkvader »
« Reply #38 on: Sun, 31 May 2015, 12:57:58 »
Any updates on this?
« Reply #39 on: Wed, 05 August 2015, 07:05:27 »
I've contacted all the original members from the group buy here, but just wanted to reiterate that I'm reviving this group buy and finishing it out to its end. I'll be contacting the plate manufacturer and getting price quotes.  Also, I will be doing a small run of PCBs for myself and a couple others that need them.
Please ask questions if you have them and let know if you need more details.
« Reply #40 on: Mon, 10 August 2015, 22:23:04 »
Placed the PCB order with the same PCB fabricator that wcass used.  They were surprisingly affordable, and the order process was smooth and easy.
Currently getting a price quote on the barrel/top plates.  I will PM all interested parties when I have that available.
« Last Edit: Tue, 11 August 2015, 05:34:18 by vivalarevolución »
« Reply #41 on: Fri, 14 August 2015, 17:00:22 »
PCBs currently are scheduled to be on my doorstep on Monday.  I placed the order on Sunday and they are being shipped from China, so I call that a pretty good turn around.  It helps that the main DHL international shipping hub is two hours away at the Cincinnati Airport.
The metal plate fabricator has confirmed the order and has said that the plates should be ready in 2-3 weeks. When everything arrives to me, I'll send out PMs asking for shipping addresses.
Now that I have those items out of the way, I will contact Unicomp about a possible group buy for keycaps.  Perhaps they could cut us a slight deal rather than having to pay full price for each individual keycap.  The layout has some flexibility, so keys that could fit alternative layouts, like ISO, could be included.  I'll think about it.
« Last Edit: Sat, 15 August 2015, 09:16:08 by vivalarevolución »
« Reply #42 on: Mon, 17 August 2015, 19:21:13 »
For anyone that ordered a PCB, those are in.  They look good.  Wcass changed the location of one of the holes for connecting it to the plate, move it more towards the vertical center.  I recommend cleaning off the dust and smudges before installing, but the quality looks great.
The turnaround from the fabricator was phenomenal as well, with the order placed on Sunday and delivered two Mondays later, so a little over a week from placing to the order to delivery to my door.  They are based in China near Hong Kong, so that's a pretty damn good turnaround in my book.
« Reply #43 on: Wed, 09 September 2015, 18:13:00 »
Plates are in.  I plan to have them shipped by the end of the week.  Also, oddly enough, the PCB fab sent me an extra fab, and I just noticed.
I matched up the plates with the stock XT backplate and wcass's PCB, threw some XT barrels in there, tested the space bar with the washer stabilizers.  Everything seems to work well.  I will not test an assembled XTant before I send out these parts, so we will all do a sort of group test.  Also, the plates are a little rough, so if you want the plates to look nice and pretty, you will need to finish them yourself.
Thanks to wcass for the design and experimentation, dorkvader for getting this started, IBM for making the original XT keyboard, the PCB fab (PCBWay), the metal fab (Weld Engineering and Fabrication), xwhatsit for his Model F controller, orihalcon for making more of xwhatsit's controller, DHL, UPS, Ebay, Unicomp, and everyone that has been involved with the marvels of air travel and the internal combustion engine (although I'm hoping for widespread adoption of electric motors sooner rather than later).  Thanks everyone for the patience.  Sorry if I forgot anyone.  We're all in this together.
Now here is a low-quality photo dump.  Enjoy.
110592-0110594-1110596-2110598-3110600-4110604-5110606-6110608-7
« Last Edit: Wed, 09 September 2015, 21:03:43 by vivalarevolución »
Offline 0100010
  • Not Sure
« Reply #44 on: Thu, 10 September 2015, 08:21:12 »
Nice.  Looking forward to yalls XTant builds...
Offline XMIT
  • formerly jsoltren
« Reply #45 on: Thu, 10 September 2015, 08:23:46 »
We just replaced our pickup truck with a Nissan Leaf. :D
If you have a spare PCB and plate, let me know.
« Reply #46 on: Thu, 10 September 2015, 15:34:09 »
Won't fit quite as many keyboards, but I approve.
« Last Edit: Thu, 10 September 2015, 16:09:00 by vivalarevolución »
« Reply #47 on: Mon, 05 October 2015, 15:31:39 »
Just wanted to let you guys know that I got my XTant assembled and working.  I'm wondering if anybody else has gotten there yet. Quite a good feeling to have one of these completed.  Now I need to get the proper keycaps...
Offline XMIT
  • formerly jsoltren
« Reply #48 on: Sun, 11 October 2015, 12:16:02 »
Turns out renting a box truck for a day is cheaper than owning a pickup truck, and allows carrying even more keyboards! Why, just the gas I end up saving in a month or two covers the rental.
« Reply #49 on: Fri, 04 December 2015, 21:05:25 »
For all those that bought an XTant PCB from me:  I finally have a working black ink cartridge and I will be sending out some labels that you can attach to the backplate to show that the XTant has been refurbished with a new PCB and barrel plate, courtesy of the design genius of wcass.  Hoping to send these out before Christmas.
