Author Topic: [IC] ISO Poker 3/Pok3r 60% Keyboard - Closed  (Read 82934 times)
Offline FoC_Tow
  • Brokehlicious
Re: [IC] ISO Poker 3/Pok3r 60% Keyboard - PHOTOS!
« Reply #150 on: Thu, 26 March 2015, 12:33:06 »
The new placement of the arrow keys is the worst decision I think they could've made.
The fact that the FN position is also on the right doesn't even make it comfortable to use with 2 hands... Real shame!
I believe using the DIP switches, you can swap the PN and FN buttons around. LED versions will be available, but not likely until first batch is sold.
FYI there can be an MX green version if I can get 60+ orders for it.
You'd still have your left arm crossing your body though :/
Maybe it will also have a dip switch for alternative Fn options like the KBP V60.
V60 had many options to use for example caps lock as an Fn afaik!
If something like that is possible the arrow key position doesn't seem bad to me personally at all as you can comfortably use them right handed while staying on home row.
« Last Edit: Thu, 26 March 2015, 12:35:52 by FoC_Tow »
Offline Prollgurke
« Reply #151 on: Fri, 27 March 2015, 09:13:29 »
Edit: Also all of the symbols on the third layer of the number row are non standard but that might actually be done on purpose I guess.
For example swiveled brackets {} would usually be on 8 & 9 and square brackets [] would be on 5 & 6...
Are you sure? I've been using de layout my entire life and I've always had those brackets like in the picture. The only difference I can see are the y and z key. (I guess they just forgot to switch those for the picture.)
Offline FoC_Tow
  • Brokehlicious
« Reply #152 on: Fri, 27 March 2015, 09:24:15 »
Whoops, I just double checked and your right Prollgurke it is the standard way!
Since I switched to ansi I've only been using Iso on my macbook, so this is what I was referencing too.
Haven't used Iso boards for a while so I totally forgot its the Macbook which is non standard in this case...
Offline againer
« Reply #153 on: Mon, 30 March 2015, 06:46:36 »
Is it possible to get blank keycaps in the first round too?
I doubt there will ever be keycaps in a  swiss layout, so I will have to stick with blank keycaps :(
If its not possible i will have to live with a DE layout ( clear switches )
Offline Giorgio
« Reply #154 on: Mon, 30 March 2015, 13:05:33 »
This would be so nice...
ISO users reunite!
Offline Giorgio
« Reply #155 on: Mon, 30 March 2015, 13:18:05 »
is the keycap profile OEM or CHERRY?
Offline Dihedral
  • Mostly Harmless
« Reply #156 on: Mon, 30 March 2015, 13:36:08 »
AFAIK OEM.
EDIT: Disclaimer - this is kinda an educated guess.
Offline ideus
  • Björkö.
« Reply #157 on: Mon, 30 March 2015, 14:41:57 »
AFAIK OEM.
Only some Leopolds come with stock non-OEM key caps. Of course Cherry boards come with Cherry profile key caps.
Offline Giorgio
« Reply #158 on: Tue, 31 March 2015, 05:30:27 »
too bad  :-[
I missed the sale for the vortex cherry pbt
Offline NorrisB
« Reply #159 on: Thu, 02 April 2015, 20:11:21 »
any updates on this?
Offline wlhlm
« Reply #160 on: Fri, 03 April 2015, 08:40:37 »
too bad  :-[
It's on there fairly regularly, just wait until it drops again.
Offline Ravenbutt
« Reply #161 on: Mon, 06 April 2015, 11:59:01 »
Would like a UK Layout with MX Clears. :)
Offline Tiramisuu
« Reply #162 on: Mon, 06 April 2015, 18:59:08 »
Programming Instruction
Note:
.. big sigh  POK3R still not main layer programmable.  :-[
Waited, hoped.. oh well.
The POK3R built in 4-layers. The default layer can not be programmed. Only layer 2~layer 4 can be. FN + R_ctrl, M,<,> and ? keys are fixed can not be programmed.
Step 1. Choose the layer (FN+<,> or ? key) which you want to programming.
Step 2. Press FN + Right CTRL to enter the programming mode (Spacebar right LED steadily lit)
Step 3. Press the key you want to program (Spacebar right LED flashing)
Step 4. Key in the programming content and then press PN (Spacebar right LED steadily lit again)
Step 5. Repeat step 2 and step 3 to program other keys.
Step 6. Press FN + Right CTRL to exit programming mode ( Spacebar right LED off)
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline ideus
  • Björkö.
« Reply #163 on: Mon, 06 April 2015, 19:01:01 »
This is vaporware.
Offline wlhlm
« Reply #164 on: Tue, 07 April 2015, 02:12:14 »
This is vaporware.
What do you mean? It certainly exists:
(photo from LeandreN)
Offline wlhlm
« Reply #165 on: Tue, 07 April 2015, 02:17:23 »
Note:
Can it remember what layer was active across reboots? I think a non-programmable main layer wouldn't be such a problem then. :rolleyes:
« Last Edit: Tue, 07 April 2015, 02:21:05 by wlhlm »
Offline Giorgio
« Reply #166 on: Wed, 08 April 2015, 05:56:41 »
I would ask them by myself, but I've already messaged them three times in one day  :-X
https://m.facebook.com/Vortexgear
Note:
Offline ideus
  • Björkö.
« Reply #167 on: Wed, 08 April 2015, 10:10:04 »
This is vaporware.
Yeah, it is a prototype, that does not mean the keyboard is a "product" yet, ready to be sold.
Offline wlhlm
« Reply #168 on: Wed, 08 April 2015, 10:23:49 »
This is vaporware.
I think you're right in that these models are different from the ones that actually will be sold.
At least, this video review by Rhinofeed shows a Pok3r with mounting holes for LEDs and pre-soldered resistors, but QWERTim confirmed that the released model won't allow for that.
EDIT: Added a screenshot
« Last Edit: Wed, 08 April 2015, 10:29:16 by wlhlm »
Offline seigmenn
« Reply #169 on: Thu, 09 April 2015, 04:52:36 »
I'm interested in Nordic layout with mx brown.
Offline opendealer
« Reply #170 on: Fri, 10 April 2015, 01:59:43 »
I would like a UK Layout with MX Clears, too. I'm located in the United States, so I'm not sure how much the shipping would be. I've just checked the Corus Keyboards website and they charge $45 to ship it to the USA. They have no ISO layout keyboards in the US warehouse.
Offline Somberlain
« Reply #171 on: Sat, 11 April 2015, 18:11:01 »
UK with MX clears for me too.
Offline leechbook
« Reply #172 on: Tue, 14 April 2015, 07:21:41 »
Are we still expecting the keyboards to ship next month?
Offline wlhlm
« Reply #173 on: Tue, 14 April 2015, 07:38:59 »
Who knows. The ANSI version has been delayed as well.
Offline againer
« Reply #174 on: Wed, 15 April 2015, 08:33:58 »
Massdrop has started a drop  with poker3  so i hope  the iso version will be ready next month too.
Are there any new informations?
about the price, when we can preorder the board when it will be shipped?
Is there a chance, that we can buy a carrying case and some blank (thick white pbt) keycaps with the board together, so that we europen ppl dont have to make multiple international orders?
Offline mp101
« Reply #175 on: Wed, 15 April 2015, 09:42:15 »
+1 here
Offline ctrlX
« Reply #176 on: Wed, 15 April 2015, 10:05:20 »
Those that are hunting for ISO version of the Pok3r can check here: http://corus-kb.com/27-pok3r-
Any news on backlit version in the future? Really want with LEDs, but if none will be released I'd like to pre-order non-backlit right away.
Offline QWERTim
    • QWERKeys
« Reply #177 on: Thu, 16 April 2015, 10:00:28 »
Hi Everyone
Unfortunately I'm not able to run this interest check for pre-orders anymore due to logistical issues that need solving first. Rest assured once this is fixed, we will be able to fulfill any orders received.
If you are still looking to purchase a Pok3r, I believe there is a site, which someone has already linked to, which should stock them when launched.
I'll try and keep everyone updated with Pok3r news!
