Author Topic: [HELP!?] Cleaning more-than-stubborn stains off PBT?  (Read 6277 times)
Offline NexVestrum
« on: Tue, 03 March 2015, 16:24:36 »
My poor keys picked up some nasty stains a while ago and I had some time today so I tried cleaning them off. They're PBT with paint filled engraving, I used warm water, 3 denture tabs, let them soak for 15 minutes, then rinsed them off annnnnd
It looks a lot worse in person.
ew.
The bottom key is one that was pretty clean before hand, the middle picked up a lot of black around the top edges and looks overall discolored. and the top (and many others) picked up black exclusively around where the paint is. I'm starting to think this black came off of my carrying case, a Grifiti Chiton sleeve. My dishsoap has bleach in it so I'm hesitant to use that, does anyone know if bleach is safe on colored PBT w/ paint? Or does anyone have some sort of magic potion that will make these look like new?
« Last Edit: Wed, 04 March 2015, 00:57:38 by NexVestrum »
Re: [HELP!?] Cleaning more-than-stubborn stains off PBT?
« Reply #1 on: Wed, 04 March 2015, 07:35:23 »
I have never used denture chemicals, that seems weird to me. I use a teaspoon of powdered laundry detergent (Charlie's) with half a teaspoon of Oxi- in a liter of hot water for 10-20 minutes, then rinse well and air dry.
For the 2% of caps that do not come completely clean with that, my next step is a light scrub with a toothbrush and a slurry of wet detergent with or without Oxi-
Next is the foam "eraser" pad and finally I go to my drawing table and use my electric eraser with mildly abrasive white or green strip.
Harsher chemicals like acetone or naptha are great solvents for certain things like adhesives, but would probably play hell with painted legends. Test first!
- D Trump 2026-10-24
« Reply #2 on: Wed, 04 March 2015, 07:46:40 »
electric eraser
How have I went my entire life not knowing such a thing existed. :eek:
« Reply #3 on: Wed, 04 March 2015, 08:30:51 »
Because people mostly stopped drawing with pencil and paper by the early-mid-1990s.
http://www.ebay.com/itm/VINTAGE-BRUNING-ELECTRIC-ERASER-ERASING-DRAFTING-TOOL-87-201-30W-/221699147340?pt=LH_DefaultDomain_0&hash=item339e4c864c
Offline Huxley2500
« Reply #4 on: Wed, 04 March 2015, 11:34:31 »
Try magic eraser.
« Reply #5 on: Wed, 04 March 2015, 11:37:27 »
Try magic eraser.
You might end up with messing up the texture of the caps with one of those.
« Reply #6 on: Wed, 04 March 2015, 12:53:58 »
Any form of abrasion will scrub the texture off very quickly.
Offline NexVestrum
« Reply #7 on: Wed, 04 March 2015, 13:50:25 »
I actually have a new magic eraser lying around and it seems soft enough to not wear down the surface texture. I'll give that a try,  thanks! If that does nothing I'll have to go pick up some detergent and oxi. Thanks for the suggestion, I'll post the results later.
« Reply #8 on: Wed, 04 March 2015, 15:56:46 »
Don't be fooled.
Those white "magic erasers" have "stealth" abrasion and will take the texture off quickly.
Offline NexVestrum
« Reply #9 on: Wed, 04 March 2015, 16:06:44 »
Don't be fooled.
Oh thanks, glad I didn't try it yet. These caps would not be easy to replace. So any other ideas?
« Reply #10 on: Wed, 04 March 2015, 16:25:56 »
It looks like that white line art is peeling up already, so I can hardly imagine anything that would not bother it beyond soap and water.
Starting with a toothbrush and a slurry of powdered laundry detergent is almost always safe.
I have never had a problem with alcohol but several people here seem scared of it.
Acetone (and, always test first, naptha) are last resorts for PBT, not ABS, and are almost certain to damage any sort of paint or film or sticker. Likewise for "citrus oil" cleaners.
If none of the solvents will do the job, then you will need to abrade the surface to erode the dirt. If it is a stain that has penetrated the surface, you will have to grind deep enough to get below it.
If you knew the origin, you could tailor a remedy to that, directly, without having to employ the scattergun approach.
Offline NexVestrum
« Reply #11 on: Wed, 04 March 2015, 20:19:38 »
Tried warm water/detergent (arm and hammer + oxyclean) - nothing even after scrubbing with a toothbrush. I went fo rthe magic eraser and tested it on the back and side of the cap where and unintentional "polishing" wouldnt be noticable, again, nothing. This stain is EVIL and I'm really starting the think the Grifiti sleeve rubbed some black dye on my pretty caps  >:D
Offline berserkfan
« Reply #12 on: Wed, 04 March 2015, 22:00:41 »
You know you yourself are a vintage when the things you use start being listed in the vintage category...
« Reply #13 on: Fri, 06 March 2015, 17:21:37 »
Harry Truman was president when I was born, Dwight Eisenhower had not yet even been nominated to run for the office of president.
However, I am still a "spring chicken" because I was born in the 2nd half of the 20th century.
There are still at least 5 people still alive verified born in the 1800s.
PS - I own one of those identical Brunings in just about the same condition. My roommate and I were working for Georgia Power Company in 1977 (it was old then) and he swiped it from them. Later, I nicked it from him.
« Last Edit: Fri, 06 March 2015, 17:27:34 by fohat.digs »
