Author Topic: Light Pad  (Read 6634 times)
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Light Pad
« Reply #1 on: Fri, 06 March 2015, 11:29:23 »
Must. Contain. Excitement.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: Light Pad
« Reply #2 on: Fri, 06 March 2015, 11:46:50 »
Wow, that looks great! I wish I could read the text - I can't translate from my current location.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: Light Pad
« Reply #3 on: Fri, 06 March 2015, 11:49:27 »
Here:
Thanks to the support of the customer demand survey has been completed.
The participation rights are given only to those members who participate in the current research needs.
When new information we will inform separately.
Oh ... For reference price (including VAT) 160,000 원 taekbaebi to doeldeut proceed separately.
We will let you know the exact number substrate quantities and schedules to be out.
Hey ~
Starter Members equipment you are ten thousand years.
Many deulkkeseo you for your inquiry Please obtain a light pad (D-pad)
I tied once more commissioners to proceed Try demand.
I do not know exactly whether the current demand to continue once the investigation is in progress.
Current progress quantity 20 degree progress , I'd like to.
The demand survey participants deduction is limited to the room is.
It's not really a lot of the quantity still hoping to finish this one doeldeut progress haebogu
We will request.
If the demand survey believe that success at the firm would probably give me progress.
I'm going to create labor demand survey participation can come ask.
So that progress can be comfortable with each other.
Write come carefully before participating please.
The photo below is a sample picture.
(Duck0113's photos have been spread arbitrarily)
Light Pad Description
Components
1. body (aluminum 6061), 11 degrees: 1
2. Cherry reinforcement plate (STS-304 1.5T): 1 개
3. PCB: 1 개
4. Fixing Bolts
5. beompon
Features reinforcement plate
- Reinforcing plate had a connection outage housing construction,
   The test results were most kigam production of stainless steel reinforcement plate 1.5T think this is good for the housing.
- Velocity when the switch noise (resonance) and are not delivered to the body.
- In the case of non-reinforced with cherry switch assembly is also available.
Housing characteristics
- Using special heat sheet of Thyssen Krupp 6061 Series
- Light pad consisting of a body when there is little difference in color anodizing.
- 11 degree slope itself
Features of the board
- All components soldered complete except for switch
- Complete kimaeping Support
- Full LED and LED stand-side support
- RED color LED high brightness side application (separate LED color change when buying and soldering required)
- Up to 12 possible macro settings key
- USB connection
- Cherry switches, as well as the Alps series switch is also designed to be used as
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Light Pad
« Reply #4 on: Fri, 06 March 2015, 13:15:28 »
I need this.
Rehosted pics:
So it is essentially an upgraded butterfly pad right? Should be a great match for the Orion and Viper boards at that 11° angle.
« Last Edit: Fri, 06 March 2015, 13:17:46 by JaccoW »
|||My other keyboards :
x
Offline SL89
Re: Light Pad
« Reply #5 on: Fri, 06 March 2015, 13:33:59 »
now i have to wonder if this will be offered with the LightSaver...
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Light Pad
« Reply #6 on: Sun, 08 March 2015, 06:45:13 »
If you have a LightSaver you don't really need one of these as it already has a numpad. It would still look really nice though. :)
x
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Light Pad
« Reply #7 on: Mon, 08 June 2015, 04:50:01 »
Did this ever take off?
x
  • Frenzy Classic.
Re: Light Pad
« Reply #8 on: Mon, 08 June 2015, 11:01:07 »
Yes. GB on kbdlab is finished. We can't reach it :(
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Light Pad
« Reply #9 on: Tue, 09 June 2015, 17:48:47 »
That's a shame. :(
If it ever does come up I hope we do get another chance.
x
  • Frenzy Classic.
Re: Light Pad
« Reply #10 on: Wed, 10 June 2015, 07:56:40 »
That's a shame. :(
I'm not sure. If I know anythings about it, I 'll update here.
Re: Light Pad
« Reply #12 on: Tue, 23 May 2017, 05:08:04 »
Is it going to be a GB for the Light Pad?
You realize this thread you are replying to is almost 2 years old?
Offline ihalatch
Re: Light Pad
« Reply #13 on: Tue, 23 May 2017, 05:09:33 »
Yes of coarse. I just can't find anything recent?
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Light Pad
« Reply #14 on: Tue, 23 May 2017, 12:48:26 »
I mean that was enough time for me to find one second hand, resolder it and then **** up the PCB really bad when I desoldered someting.
x
