Author Topic: Assembling Cherry stabilizers?  (Read 3899 times)
Offline swornxin
    • Nailed Down Custom Pins
« on: Sun, 08 March 2015, 00:24:25 »
I have never had to do this before, so I went the way that looked at least somewhat correct.  I can't figure out how to mount them to my plate yet though.  Can anybody tell me if I'm doing this correctly?  I have an extra set if I've messed these ones up too badly.
EDIT:  So what I really need to be doing is mounting to the PCB.  Can someone outline the steps of doing that?
« Last Edit: Sun, 08 March 2015, 01:12:28 by swornxin »
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline phoenix1234
Re: Assembling Cherry stabilizers?
« Reply #1 on: Sun, 08 March 2015, 00:38:28 »
I think they are PCB mounted stabilizers.
You should mount them to the PCB instead of the plate.
Indeed, if you have plate, the plate must support to mount the PCB stabilizers.
I like linear switches
Offline swornxin
« Reply #2 on: Sun, 08 March 2015, 00:56:10 »
Ah, yes.  They are actually PCB, and the plate does allow PCB mounted stabs.  I just have no idea how to install them into the PCB.   :(
Offline phoenix1234
« Reply #3 on: Sun, 08 March 2015, 05:49:16 »
Maybe this clip @1:20 can help
[it was recorded and guided by mkawa]
Offline swornxin
« Reply #4 on: Sun, 08 March 2015, 23:07:48 »
I got it, I was trying to put them in the wrong way.  First timers, huh?  Thanks all.
