Author Topic: [GB] TMK Alps64 - 60% PCB for Alps  (Read 1586434 times)
Offline SJHL
Re: [GB] 60% ALPS PCB
« Reply #400 on: Fri, 10 July 2015, 15:20:57 »
Hasu, thanks again!
Not sure if this has been mentioned already but the PCB fits perfectly with Tex Acrylic case (See picture below).
I dremeled, filed, scrubbed and painted a Dell AT101W plate. Its not perfect but it doesn't look too bad in my eyes. I can't wait for Badwrench's DCS Infinity modifier kit!
« Last Edit: Fri, 10 July 2015, 15:58:14 by SJHL »
Offline joey
« Reply #401 on: Fri, 10 July 2015, 15:29:06 »
I've always wanted an ALPS 60% board, I kinda suck at soldering though...
If anyone in the UK needs a plastic 60% case I've got them on my webstore? (shameless plug)
If you get in round 3, I'll be happy to solder it for you.
Offline sean
  • Mechanical newb
« Reply #402 on: Fri, 10 July 2015, 15:31:47 »
Nice job SJHL. that plate looks like it was custom CNC'd!
Offline badboybry9000
« Reply #403 on: Fri, 10 July 2015, 15:46:17 »
No joke! I am stunned by the appearance of that plate. Well done!
Offline SJHL
« Reply #404 on: Fri, 10 July 2015, 15:57:19 »
Thank you!
Offline sean
  • Mechanical newb
« Reply #405 on: Fri, 10 July 2015, 16:16:19 »
Thank you!
I also like how you put a white on the capslock I'm definitely going to copy that :P
« Reply #406 on: Fri, 10 July 2015, 16:18:46 »
That's probably a locking cream alps. At least I hope it is haha. I have one on the function layer key on my Minitouch.
Offline SJHL
« Reply #407 on: Fri, 10 July 2015, 16:46:08 »
Yeah, it's a lock switch. Figured that I should use it since I had one.
Offline Frizer
« Reply #408 on: Fri, 10 July 2015, 19:25:13 »
Lovely job, is the TEX acrylic case available anywhere other than MD?
Offline a-c
« Reply #409 on: Fri, 10 July 2015, 21:15:29 »
Currently exclusive to Massdrop. The current buy ends in 2 days.
Offline cheddarbek
« Reply #410 on: Fri, 10 July 2015, 21:41:09 »
I'm going to end up waiting until late August to get my metal TEX from MD. Such is life.
The Alps cover 65% of Switzerland's surface area (41,285 kmē), making it one of the most alpine countries. Despite the fact that Switzerland covers only 14% of the Alps total area (192,753 kmē),[2][3] many alpine four-thousanders (48 of 82) are located in the Swiss Alps and practically all of the remaining few are within 20 km of the country's border.
Offline lishi
  • Luxury Taste Buds
    • Personal Website
« Reply #411 on: Sat, 11 July 2015, 12:20:05 »
Took some pictures of my completed board:
http://imgur.com/a/DZXiZ
Thanks Hasu for the PCB and Nubb for the plate!
All the kustom 60s
Offline punkpc
« Reply #412 on: Sat, 11 July 2015, 12:21:31 »
This looks great! I really hope there is a 3rd round.
Offline Pyrelink
« Reply #413 on: Sat, 11 July 2015, 19:22:03 »
I will definitely take a Round 3 PCB.
Offline njbair
    • nickbair.net
« Reply #414 on: Sun, 12 July 2015, 00:43:12 »
So then I'm assuming the TMK firmware supports this?
My boards:
Offline cheddarbek
« Reply #415 on: Sun, 12 July 2015, 00:44:46 »
I'm curious about how to implement this as well. I'm planning on using a locking switch for my build.
Offline lishi
  • Luxury Taste Buds
    • Personal Website
« Reply #416 on: Sun, 12 July 2015, 00:47:27 »
Tmk has support for locking switches I believe. Haven't read the documentation for it though
All the kustom 60s
Offline cheddarbek
« Reply #417 on: Sun, 12 July 2015, 00:50:54 »
Hasu has documentation for capslock, numlock, and scroll lock, with a locking switch  but I haven't seen documentation for fn lock with a locking switch. Perhaps I missed or misread something.
Offline lishi
  • Luxury Taste Buds
    • Personal Website
« Reply #418 on: Sun, 12 July 2015, 01:01:48 »
Ah, I see. Didn't realize you were talking about the fn key.
All the kustom 60s
Offline Yoe
  • Alps & ISO <3
« Reply #419 on: Sun, 12 July 2015, 02:50:49 »
If you use a locking switch in place of an momentary fn switch, you are all set. Just put it there and enjoy the locking function :) The thing with caps lock, scroll lock and num lock is that the "locking" is normally done in the software. Makes putting a locking switch there instead a bit harder as you need to adapt the firmware (no problem at all in TMK).
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #420 on: Sun, 12 July 2015, 04:34:50 »
Has anyone looked into replacement PBT spacebars that would match an AEKII set?
Does anyone know the size of the AEKII spacebar? I might look around and see if we can find a PBT alternative.
Offline ctm
  • Hello, world!
« Reply #421 on: Sun, 12 July 2015, 13:05:25 »
Matias is working on ALPS PBT caps and there are multiple sizes of spacebar. There might be one that fits AEKII.
Coming:
Ellipse Model F F62.
Offline kennardsmith
« Reply #423 on: Fri, 17 July 2015, 15:10:27 »
and done!
Those mod colors are perfect! Well done!
[Control] is just left side of [A]. It comes from Sun Type3 key layout.
Offline vivalarevolución
« Reply #424 on: Fri, 17 July 2015, 15:11:28 »
My life's biggest regret is not getting in on this group buy.  Rats.
Offline Yoe
  • Alps & ISO <3
« Reply #425 on: Fri, 17 July 2015, 15:33:38 »
and done!
Nice dye job! Is it Dylon? What colors did you use?
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #426 on: Fri, 17 July 2015, 15:36:53 »
If the white PBT caps they're making end up being the same shade of white as their ABS ones then they are going to be a very bright white.  I guess you could try to dye some to color match.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline henz
  • What?
« Reply #427 on: Fri, 17 July 2015, 16:11:31 »
and done!
I bought a old mac keyboard with those modifiers, so I stole them from it :), I'll look it up tomorrow . so not that hardcore.. ;)
Offline merlin64
    • MechMerlin
« Reply #428 on: Fri, 17 July 2015, 18:21:10 »
Which mac keyboard did you get it from?
Offline nevin
« Reply #429 on: Fri, 17 July 2015, 18:27:28 »
Believe some of the datadesk adb keyboards?, also had a rounded f row that was a different color
Offline punkpc
« Reply #430 on: Fri, 17 July 2015, 18:34:12 »
Yep I was just about to say that. I had one when I was a kid. Had it for my Macintosh.
Here are pics of the DATADESK Lil'Big Board ADB keyboard that I'm guessing he used.
Oh and don't get the LittleFingers. It is not Alps and the keycaps are too small anyway.
There is a review of it by xDezor Here
https://geekhack.org/index.php?topic=39350.0
« Last Edit: Fri, 17 July 2015, 18:47:04 by punkpc »
« Reply #431 on: Fri, 17 July 2015, 19:52:18 »
What a cute keyboard squeeee
Offline Yoe
  • Alps & ISO <3
« Reply #432 on: Fri, 17 July 2015, 22:40:25 »
Great info! Thanks! :D
I should look for one of those... :)
Offline njbair
    • nickbair.net
« Reply #433 on: Fri, 17 July 2015, 23:03:28 »
I brought my new Alps 60% home this evening and got it set up on my Ubuntu desktop. I recently downsized my home office space, and a smaller keyboard is a really welcome change so far. I also spent a good bit of time this evening learning the TMK firmware and setting up my first custom config. I'm mainly a Dvorak user, but I often need to go back to QWERTY for certain things, including games. I'm also thinking about learning Colemak. So I borrowed the layout-switching idea from Poker-style boards (Fn+Q for QWERTY, Fn+D for Dvorak, etc.), and the HHKB layer from hasu's config (with Enter and Space as my momentary HHKB layer toggles), and frankensteined a setup that so far seems pretty solid for my use case.
I've got to say I really appreciate the TMK firmware. Having used the Infinity firmware (using the KLL spec), I very much prefer TMK. In fact, I am probably going to end up flashing both of my Infinity's with TMK. It's very well-documented and approachable, and the keymap syntax makes sense. So thanks to hasu for all of your hard work, not only on this PCB but on the firmware that makes it useful.
My boards:
Offline henz
  • What?
« Reply #434 on: Sat, 18 July 2015, 04:28:43 »
ye it was a lil big Datadesk
it had fake alps in it and one black on enter. i bought it just because i wanted the colored modifiers.
Offline punkpc
« Reply #435 on: Sat, 18 July 2015, 08:12:59 »
Well great find! I have been looking for one of these for years... With the colored modifiers or not, but all I can find is the littlefingers one.
Offline henz
  • What?
« Reply #436 on: Sun, 19 July 2015, 14:36:00 »
oh man Hasu, you are killing my freetime with this tmk firmware. now i have to create a million layers
Offline njbair
    • nickbair.net
« Reply #437 on: Mon, 20 July 2015, 20:07:36 »
I was really tempted to do the same thing. But I ended up scrapping the mouse layers so I just have a HHKB function layer (triggered by either Space or Enter), and switchable QWERTY/Colemak/Dvorak layers. But it was still super fun learning the firmware and customizing my layout.
My boards:
Offline henz
  • What?
« Reply #438 on: Tue, 21 July 2015, 01:21:00 »
This tapping function keys didn't work that great for me. I guess I tap too slow.
Offline njbair
    • nickbair.net
« Reply #439 on: Tue, 21 July 2015, 19:49:38 »
I don't think it's based on speed. I think it just waits until you release the key to trigger the action. For example when I press space down and hold it, nothing happens. If I press another key in my function layer while still holding it, the function layer's action is executed. But if I let up the space bar without pressing any other keys, no matter how long I held it down, the space character will appear onscreen.
My boards:
Offline sean
  • Mechanical newb
« Reply #440 on: Wed, 22 July 2015, 22:35:16 »
 :D :D :D Round 3?  ;) ;) ;) ;)
Offline hasu
  • @tmk
« Reply #441 on: Thu, 23 July 2015, 00:27:10 »
I'll part with leftover from round 2 before starting round 3 :D
Several preassembled PCBs are available, which have cosmetic flaws like scars, blur silk prints or etc but they work functionally without problem. PM me if you are interested in getting one.
It costs 35(PCB)+10(Shipping)=$45USD in total and see the first post for the detail.
Offline punkpc
« Reply #442 on: Thu, 23 July 2015, 05:57:57 »
So sorry if this is bad for saying, but no discounts on the cosmetic defects or is this because there is no margin? If that is the case. I can understand that. Can you at least show us a example of what one of these cosmetic defects look like?
Offline hasu
  • @tmk
« Reply #443 on: Thu, 23 July 2015, 07:15:39 »
As I said before all PCBs had more or less defects unfortunately because of sloppy production by cheap mediocre PCB house. The leftovers are a bit worse than others.
http://i.imgur.com/T4OilAr.jpg
Ugly silk prints and exposure of copper.
Offline punkpc
« Reply #444 on: Thu, 23 July 2015, 07:36:33 »
Oh... that's not so bad. I was thinking way worse. I will be fine with one of those. PM coming your way.
Offline VinnyCordeiro
« Reply #445 on: Thu, 23 July 2015, 08:30:25 »
Now I have to wait until the 11th of next month to buy a leftover PCB, already exploded my budget for keyboards.  :'(
I just hope that they are still available by that date...
Offline sean
  • Mechanical newb
« Reply #446 on: Thu, 23 July 2015, 14:12:27 »
I just PM'd you about one of the extra boards :>
Offline zenless
« Reply #447 on: Thu, 23 July 2015, 14:26:54 »
Shoot i hear that. I need to sell some stuff off so i can take on this as a project :-/
Offline AKmalamute
  • HHKB Scrub
« Reply #448 on: Thu, 23 July 2015, 15:19:24 »
Hopefully I responded in time. I've responded to Hasu's reply-PM about one of the boards.
Should go with that plate I just bought quite nicely ... now, where to get those weird stabilizers?
HHKB-lite2, Dvorak user
Offline gogusrl
« Reply #449 on: Fri, 24 July 2015, 04:35:28 »
sent a pm as well.
