Author Topic: Where to buy stickers and lube (conus)? What kind of lube for clears?  (Read 2293 times)
Offline Willyc277
Have some mx clears coming in for a build and would like to get them as sweet as can be. I've got 62g gold springs to throw in them. Trying to figure out where to buy stickers and lube and also what type of lube I should get! Should I be lubing the springs and sliders? Should I use the same for both? What about stabs?? I'm so excite  ;D
Re: Where to buy stickers and lube (conus)? What kind of lube for clears?
« Reply #1 on: Fri, 13 March 2015, 18:31:43 »
I suggest going to Google use site:geekhack.org then put the keywords to what you want to know you'll learn much more that way
Offline sirisaac1982
  • The Answer is 42...
« Reply #2 on: Sat, 14 March 2015, 15:09:46 »
I bought stickers at a craft store called Michael's. Their not "keyboard" decals but you'd be hard pressed to tell the deference. I used them to mark the side of certain key secondary functions for my Ducky Legend.
Offline Firebolt1914
  • POM Overlord
« Reply #3 on: Sat, 14 March 2015, 15:21:25 »
I think OP was talking about switch stickers, not stickers to label things.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #4 on: Sat, 14 March 2015, 15:21:26 »
You can find lube at elitekeyboads or the CTRLALT store
Offline FreeCopy
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
« Reply #6 on: Sat, 14 March 2015, 15:37:25 »
Do you know where to find them? The stickers I have work perfectly for the task but, each to his own.
  • POM Overlord
« Reply #7 on: Sat, 14 March 2015, 15:59:50 »
Are you talking about switch stickers to put in the keyswitch, or stickers as in stickers to label the keyboard?
Edit: in reply to person above
« Last Edit: Sat, 14 March 2015, 16:03:17 by Firebolt1914 »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #8 on: Sat, 14 March 2015, 16:02:05 »
switch stickers
