Author Topic: wierd custom layout. :/  (Read 4195 times)
Offline BurgerBum
  • Location: Portland, where we're a mixture of the 60's 90's pie... mm... pie.
« on: Sun, 15 March 2015, 22:30:33 »
so, i type incorectly, and am not going to change that, the right side of my spacebar is pretty much worn down and thin.  :p
i hit it with my right index finger, right on the line between N and M on a standard qwerty keyboard.
so, i made myself a custom layout, keeping as few keys as possible, and being as space-concious as i could :p
 my main question, would be if there are any PCBs for this kind of layout, a place where i can get a custom PCB or find one that would work fine with some work put into it, or whatever. :D :)
http://goo.gl/1F7YZF
thats the link. if its broken yell at me or something.
let me know what you think! all feedback is appreciated. :D  ;)   ^-^
side note:
dont worry about wierd ergonomic issues with WASD and spacebar, i plan on making this keyboard when i have a separate gamepad, i dont like gaming on keyboards anyway. >.>
« Last Edit: Sun, 15 March 2015, 22:32:35 by BurgerBum »
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
Re: wierd custom layout. :/
« Reply #1 on: Sun, 15 March 2015, 22:43:11 »
Check this out, they make a complete for around 150... You could program it to what you want!
https://geekhack.org/index.php?topic=62471.0
« Reply #2 on: Sun, 15 March 2015, 22:46:54 »
It sounds like you and I have a very similar typing style. :)
Looks like you want a JD40 with an alternate bottom row. With a 3.5-unit spacebar. Keep an eye on my twitter feed for possible updates to the JD40. But don't expect 3.5u spacebar support to be added any time soon. I am liking the layout options I included on the JD45, and I usually like to leave support for larger, standard sized spacebar that you actually have hope of purchasing some day. :D
Offline BurgerBum
« Reply #3 on: Sun, 15 March 2015, 22:48:16 »
i saw that thread an hour or two ago but didnt understand what was going on. ._.  :(
so, they make custom PCBs and what not? :o
Offline BurgerBum
« Reply #4 on: Sun, 15 March 2015, 22:50:22 »
whats your twitter? :)
the jay dee what? o.o
« Reply #5 on: Sun, 15 March 2015, 22:58:40 »
Offline BurgerBum
« Reply #6 on: Sun, 15 March 2015, 23:20:17 »
http://twitter.carpekeyboards.com/ is my twitter. :)
sweet. :D :)
theres not just a place i can get a custom PCB from? *dies a little inside* NUU
Offline Ludovician
« Reply #7 on: Mon, 16 March 2015, 00:57:32 »
For the record, the pink text is very hard to read for those of us using the white background.
I do a similar thing with the spacebar while typing. Good luck finding something.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline jacobolus
« Reply #8 on: Mon, 16 March 2015, 01:04:52 »
Where are you going to source a 3.5 unit long keycap? Or are you making it yourself out of wood or something?
  • Kitteh Overlord
  • Say WHAAT...
« Reply #9 on: Mon, 16 March 2015, 01:29:19 »
DOH...  :'( How could I forget JD!
Sorry homie!
Offline BurgerBum
« Reply #10 on: Mon, 16 March 2015, 01:31:21 »
^-^ index space bar master race. :p
sorry. :o i'll leave things at default from now on.
Offline BurgerBum
« Reply #11 on: Mon, 16 March 2015, 01:37:43 »
i was previously thinking about just ABS or whatever plastic and having a friend print it. (3d printers and all) then i realized i dont have any friends with 3d printers......... xD
now that you mention it making a FULL keycap set out of wood would be really rad...
Offline Oobly
« Reply #12 on: Mon, 16 March 2015, 05:00:54 »
Does Enter deserve to be a home row key? I think one of these offers you a few more options and allows more character layouts with less characters needing to be on a Fn layer: https://geekhack.org/index.php?topic=62641.0
I'm also developing a portable programmable board with slightly similar layout, but it's going to be a while before any PCB's / complete boards are available: https://geekhack.org/index.php?topic=66836.0
I have left areas on the bottom row empty which I consider to be "dead" space, not easily rechable by either thumbs or pinkies.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline BurgerBum
« Reply #13 on: Mon, 16 March 2015, 23:17:46 »
deal is, those kinda keyboards dont fit my typing style. :/
do i need to get a a PCB in order for me to make a keyboard?
im actually at the point with my only working keyboard left that the main key (spacebar) is dying out and im needing to reach foreward and onto my laptop to type this. (super janky setup. :/ gonna fix it soon)
Offline neverused
« Reply #14 on: Mon, 16 March 2015, 23:29:15 »
Check jd's sticky with links for threads about making your own board, but no you don't need a pcb. You can hand wire a matrix with just a plate to hold the switches.
« Reply #15 on: Mon, 16 March 2015, 23:31:19 »
https://geekhack.org/index.php?topic=69582.0
Offline Touch_It
« Reply #16 on: Mon, 16 March 2015, 23:35:45 »
I don't think you need a pcb.  You could use plate mounted switches and wire a matrix up to a teensy like you have to with Apple m0110 keyboards.  But I'm no expert on that and couldn't be of any help really.  That just sounds like a cheaper/quicker alternative if it is feasible.
Edit beat by neverused.  I type to slow in my phone :)
Offline BurgerBum
« Reply #17 on: Mon, 16 March 2015, 23:40:21 »
jheesh dude! what did you freaking invent the keyboard itself?!!???!!!! you have alink for a thread you started for everything... o.o
i wouldnt be surprised if you linked me to a thread about using the different surfaces on your pet turtle for keys....
« Last Edit: Mon, 16 March 2015, 23:42:05 by BurgerBum »
Offline Oobly
« Reply #18 on: Tue, 17 March 2015, 04:49:55 »
The best way I can think of at the moment is to design your layout in the keyboard layout editor: http://www.keyboard-layout-editor.com/
Then copy and paste the raw output to swill's plate building tool: http://builder.swillkb.com/
And send the file to Big Blue Saw for them to make it for you: https://www.bigbluesaw.com/
Then all you need to do is wire up the switches and diodes into a matrix and solder that to a Teensy 2.0 and flash it with a good firmware, like TMK. Jd's links post should help you to get these steps done.
