Author Topic: Are lighter switches actually better for gaming?  (Read 14479 times)
Offline Data
Re: Are lighter switches actually better for gaming?
« Reply #50 on: Thu, 28 May 2015, 15:57:28 »
I'm going to HULK SMASH the keys anyway, so it might as well be with a sturdy spring behind it.  At least I'll get the benefit of a slightly faster reset.
Honestly though, if there's a difference it's so small as to be insignificant.  I game on Browns right now.  I have Blacks, Clears, and Reds available but it's all the same to me.
Offline IAmTheGuy
« Reply #51 on: Thu, 28 May 2015, 18:55:23 »
Actually, I think keys with shorter travel are better performers for gaming.  I play a lot of games that needs precise animation canceling, and I found that keys with shorter travel and a contact point at the bottom of the press gives you the most control and speed.
Also, I found ghosting to be most helpful for one of my games :3  This is because ghosting automatically releases a keypress when another one is pressed with no overlap and no delay - which is incredibly hard to do manually (took me 2 years of almost daily practice to do consistently-of course only then I figured out this cheat  :))).
So your typical laptop scissor switches are great! - except they feel like crap.
For most games though, I don't think the type of switch matters as far as player performance goes.  I do find clicky switches annoying when recording a game though.
« Last Edit: Thu, 28 May 2015, 19:03:04 by IAmTheGuy »
Offline MellowFellow
« Reply #52 on: Thu, 28 May 2015, 19:02:29 »
Your mileage may vary.
Offline livingspeedbump
    • KeyChatter
« Reply #53 on: Wed, 03 June 2015, 14:16:14 »
Honestly I often game with whatever keyboard is plugged in at the moment (lately just BF4, fyi), and I honestly don't even think about the switches while I'm in the middle of a game. Sometimes I almost feel like heavier switches prevent me from accidentally hitting the wrong keys though, so if I had to give an answer I'd probably say I'd prefer something like greens or clears over reds or browns. Totally personal preference though, having a heavy switch would probably really bother some people trying to game.
<- My Collection (so far)
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #54 on: Wed, 03 June 2015, 14:19:04 »
Me.
I find heavy switches very distracting while gaming. No idea how to explain it but I'm very conscious of how hard I have to press a keyswitch when I'm playing with heavy switches. It pulls me out of the immersion a lot. Typing I don't notice the difference between heavy and light switches nearly as much however.
    • KeyChatter
« Reply #55 on: Wed, 03 June 2015, 14:32:55 »
Me.
And honestly you are probably a much better gamer than I. For me its just something I'll do for a few minutes to waste time, so I don't really get into caring very specifically about my switches for it.
