Author Topic: Model M 42H1292, tested, $39.99 shipped  (Read 5398 times)
Offline ander
  • I type, therefore I am
« on: Tue, 17 March 2015, 17:30:36 »
Here's a very late ('97) Model M 42H1292, tested and with no obvious physical flaws, on eBay for $39.99 with free U.S. shipping. It's UK-made but has the standard ANSI layout.
It's nothing very special to a collector—but if anyone just wants a genuine IBM buckling-spring keyboard for half the price of a new Unicomp, it seems like a decent deal!
Offline cooldiscretion
  • Convicted guilty of being totally rad.
Re: Model M 42H1292, tested, $39.99 shipped
« Reply #1 on: Tue, 17 March 2015, 18:09:51 »
So fresh and so clean. :thumb:
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Tue, 17 March 2015, 19:13:57 »
It's even made by IBM rather than Lexmark. Should be a good buy, this :) .
« Reply #3 on: Tue, 17 March 2015, 19:51:19 »
Almost every dead Model M I have ever bought was a 42H made in Greennock.
On the other hand, this price is very close to the price of a set of caps alone from Unicomp or clickykeyboards, probably at least equal if you add in a half-dozen barrel inserts.
- D Trump 2026-10-24
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #4 on: Wed, 18 March 2015, 00:16:40 »
It would be if it were Buy It Now.  But that is just the STARTING bid on the keyboard.  I'm with Fohat on this one.  I haven't had great luck with 42H boards.
Offline ander
« Reply #5 on: Thu, 19 March 2015, 00:32:12 »
Oh, heh heh, I thought it was a BIN, actually... Sorry, must've gotten it mixed up w/another one. I don't know if there's a way to delete a topic you start. Probably not, so I'll just live in humiliation for a while. (I'm married, so I'm used to it.)
Indeed, though, as it's one of the last straggler M's produced, I didn't think the collecting community would care about it (no one's bid on it yet). I just thought someone might be interested who just wanted a good KB to use... People like that actually exist, don't they?  :?D
Quote from: fohat.digs
Almost every dead Model M I have ever bought was a 42H made in Greennock... On the other hand, this price is very close to the price of a set of caps alone from Unicomp or clickykeyboards, probably at least equal if you add in a half-dozen barrel inserts.
Certainly it's as good as a Unicomp, isn't it? An' tis made in Scotland, laddie—e kinna be that bad now, eh?
« Last Edit: Wed, 08 April 2015, 17:42:45 by ander »
Offline Snowdog993
« Reply #6 on: Thu, 19 March 2015, 01:21:07 »
The difference is like night and day.  The original controllers actually connect to the center ribbon seen in the first picture. (This actually IS a Greenrock terminal board from 1999, and has the hook for the 42H controller LOL!)
The second picture shows where the ribbon cables connect to the SDL controller.  Easy enough to see how it connects.
The third and fourth picture is just where the 42H controller is.  Yup.  That's all there is to it.  A little self-contained controller and LED panel all in one.  Notice the plastic hook in the first picture where the 42H controller would sit.
That controller sits at an angle (Oh I would guess about ~5 degrees) that is only being held by two small holes at the bottom of the controller sitting in two plastic nibs on the barrel frame.  The plastic "hook" on the right, is just holding the newer controller at that angle to the frame applying pressure to the contacts on the differently designed membrane that goes there.
It's a cost cutting move, but also makes for some serious issues with the keyboard not functioning properly.
Let's just say, it's not my favorite controller at all.
I hope I explained the difference well enough for everyone to understand.
« Last Edit: Thu, 19 March 2015, 02:07:48 by Snowdog993 »
Offline ander
« Reply #7 on: Thu, 19 March 2015, 05:05:22 »
Well, there you have it then! Luckily for us, we caught you at a moment when you had time to prepare all that.
« Reply #8 on: Thu, 19 March 2015, 06:59:30 »
I remember this being a Buy-It-Now listing when it was first posted, and considered buying it strictly as a parts donor.
A seller who was watching his listing might consider changing BIN to auction if he got several "watchers" in the first few hours.
Offline Snowdog993
« Reply #9 on: Thu, 19 March 2015, 09:50:39 »
What the heck kind of answer was that?  There is smart, and then there is smart ass.
Offline ander
« Reply #10 on: Fri, 20 March 2015, 04:52:22 »
Quote from: ander
Quote from: Snowdog993
I meant it must've taken quite a while to assemble, write, format and post all that "evidence", didn't it? Considering your expertise, thoroughness and attention to detail, I'd guess you were a pretty busy, in-demand person in other areas of your life as well.
Offline ander
« Reply #11 on: Fri, 20 March 2015, 04:53:08 »
Quote from: ander
I meant it must've taken quite a while to assemble, write, format and post all that "evidence", didn't it? Considering your expertise, thoroughness and attention to detail, I'd guess you were a pretty busy, in-demand person in other areas of your life as well... A lawyer, maybe?
Offline Snowdog993
« Reply #12 on: Fri, 20 March 2015, 09:45:25 »
Quote from: ander
I am a very busy person.  The way I took your answer was in a different context entirely.  It could be taken 2 ways.
Offline Snowdog993
« Reply #13 on: Fri, 20 March 2015, 22:56:54 »
Quote from: ander
There was no need for me to get angry at you.  I'm sorry.  I took what you said the wrong way.
