Author Topic: [IC] Hubble Mira Custom TKL (GB is 3... 2... 1... launched!)  (Read 814251 times)
Offline hoggy
  • * Ergonomics Moderator
Re: [IC] Hubble Mira Custom TKL (PLEASE CHECK ON YOUR NUMBER)
« Reply #1350 on: Sat, 19 September 2015, 03:08:58 »
Its a shame, but thanks for trying.  On the plus side, you've saved us from a bad finish. :-)
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #1351 on: Sat, 19 September 2015, 06:14:26 »
That is a shame. Sort of odd how cerakote can be done on something so large and intricate as many guns are but cerakote didn't quite work out on a keyboard.
I wonder why? steel vs aluminum? type or steel/aluminum?
GON NerD TKL DTA Edition
Offline ninjadoc
« Reply #1352 on: Sat, 19 September 2015, 06:32:26 »
Cerakote is OUT! Guy tried on my board five times and was unable to get a finish he was happy with. I had another board I brought in and he doesn't want to try another one. He spent to much time and money and was unable to get a finish that any of us would want on our desk. Sorry guys, he tried and I was really excited about the possibility but it was unsuccessful.
I'm convinced it was the board. The shop didn't want to try after 5 tries. He was upset and hated to turn the money down. I offered to pay for the supplies but he wouldn't accept it. I understood why he wouldn't because he is a small shop but I really liked him and his product. The thing I wasn't sure about was that he sandblasts everything to clean him and prepare it for coating. With the aluminum it gives a very rough, textured feel. On my keyboard the surface felt like sand which was obviously a product of the sandblasting. It only felt like that on a few of the gun stocks that are obviously plastic and would deform more due to sand blasting. The aluminum of my keyboard was obviously more impacted by the sandblasting. Water and acetone beaded up and ran off everything else he cerakoted that he showed me. On the keyboard it seemed to soak in but the bad part it rubbed off which should not happen. I first noted it when I set it on the counter and it scratched. We tried rubbing the scratch, you could feel it, and the cerakote seemed to rub off with his finger. I suggested acetone and it rubbed off in places. He's been through the training course at the company that produces cerakote and certifies applicators, and has done this for a living for 5 years and has never had that happen. He was very frustrate and felt it as a challenge and spent a lot of time and money on the board and really was afraid to try it on any other product like it. The board is made of 6061 T6 aluminum which is a standard aluminum so I have no explanation of the difficulties. I'm trying powder coating now so I can at least use the board.
Offline Data
« Reply #1353 on: Sat, 19 September 2015, 16:11:47 »
AR15 receivers are typically 7000-series forged or milled aluminum.  They take cerakote without any problems.  The coating doesn't really care as much about surface material.  Many guys cerakote their polymer stocks and grips.
Offline asgeirtj
« Reply #1354 on: Sun, 20 September 2015, 10:02:14 »
Won't this board have some kind of rubber stands at the bottom?  To keep it in place?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline ninjadoc
« Reply #1355 on: Sun, 20 September 2015, 20:24:28 »
I can safely say the cerakote did care about the material in this instance. I would have wondered if it was defective cerakote but ---he tried 5 different times with diffrerent colors to see if he could figure out the issue. If he had called me after the first or second time I would have asked him to stop which would have diminished his frustration and expense. I think it was the board and what had been done to it in the past but we don't need to get this thread derailed discussing that because it doesn't change the fact that cerakote is off the table. If you want to discuss it with me via PM's that's fine, but lets leave the thread for the Mira and what we are doing to get a good product out for all of us.
Offline ninjadoc
« Reply #1356 on: Sun, 20 September 2015, 20:28:43 »
I think something like these ( https://www.thehardwarehut.com/catalog-product.php?p_ref=259853 )will be included but I can't say that with 100% certainty.
Offline Data
« Reply #1357 on: Sun, 20 September 2015, 20:51:02 »
I didn't mean to imply otherwise. More than happy to continue with anodizing.
Offline myotherteeshirt
« Reply #1358 on: Thu, 24 September 2015, 07:45:21 »
Hi there!
Can i still get in on this?
Offline diqkiq
« Reply #1359 on: Thu, 24 September 2015, 10:42:06 »
Hi there!
You can. Under the the OP, you will see a link for late comers.
Filco Majestouch TKL, Noppoo Choc Mini, Realforce 87 55g, Model M TKL, Ducky Shine 3 TKL, KC60, Planck.
Offline justnits
« Reply #1360 on: Thu, 24 September 2015, 22:37:43 »
Okay sorry for disapearing for a bit. I have been busy with a lot of stuff lately.
But without further ado, I present to you the Hubble Mira!
sorry i lost my card reader, so potatoes only for now :-[
okay so here is my unbiased review of the Mira prototype:
things that are great:
  • Its undeniably beautiful, i had friends stop by and without knowing what it was thought it was awesome
  • The weight is perfect. Not too heavy, not too light.
  • The pcb and plate fit great and mount securly to the case
  • There is no rattle or shaking in the plate when installed
things that will be fixed:
  • The blockers are too tall, so i had to mutilate a couple shift keycaps. Easy fix.
  • Minor spacing issues with the escape and left control keys
  • USB hole is not large enough and is slightly too far right (about a mm)
  • the screw threads are not deep enough on the weight, another easy fix
  • The anodizing on the board was done poorly, we have already chosen a different shop, so no worries here
I hope you are excited as I am! Once we confirm the fixes with the shop and nail down our coating options I will announce a start date for the GB!
As far as anodizing we have located a company that has given us very fair prices with the ability to create custom options. Essentialy how it will probably work is that there will be no charge for base colors (Gold, black, blue, green, red, violet, bronze, blue pewter, and titanium), and if there are 10 or more people who want a custom color, they can pay a small amount and we will get it made. Ninjadoc has samples from this shop, so you can see when he posts them what it should look like.
I'm not too sure if you have tested out the prototype with other keycaps such as DSA, SA and Cherry profile keycaps as these keycaps have sharp edge at the bottom.
I noticed the top case curves especially on the insert pgdown clusters, arrow clusters, and the right control, where the corner of the keycaps are very close to the case.
granted that the DCS profile keycaps works without much issue since it has a curve edge at it's bottom.
But my concern goes towards sharp edges keycaps such as the ones mentioned above. I can only estimate as much as what I can see from the picture here. On a separate case, one of CMStorm's latest keyboard has issue with DSA keycaps hitting the corner of the inner case, but Cherry profile keycap has no issue because when compared, the DSA keycaps has a slightly larger bottom edge.
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline KaminKevCrew
« Reply #1361 on: Sat, 26 September 2015, 22:34:07 »
Is the Pre-order form still valid? I'm very, very interested in getting a limited production run keyboard, but I'd like to be sure that there's still a spot available.
Anyway, thanks!
Offline asgeirtj
« Reply #1362 on: Sun, 27 September 2015, 11:21:42 »
I hope this board will have flush bezels with they keycaps.  I've seen some boards which the keycaps get buried and I've seen some boards where the keycaps are too exposed, hope there will be perfect middle ground with this board.
Offline ninjadoc
« Reply #1363 on: Tue, 29 September 2015, 09:02:40 »
DrHubble is dealing with the sudden death of two friends at school so updates are delayed until he is back to working on the Mira. Sorry. If I find out anything about the current status I will let everyone know.
« Reply #1364 on: Tue, 29 September 2015, 09:04:56 »
As someone who's had a college friend pass away suddenly, I can imagine the pain he's going through, except double.
My condolences.
Offline swimmingbird
  • keyset hoarder
« Reply #1365 on: Tue, 29 September 2015, 09:21:40 »
Damn sorry to hear that - my condolences go out to you hubble
Offline tribade
« Reply #1366 on: Tue, 29 September 2015, 11:18:56 »
That's truly horrible. I remember dealing with the sudden death of a friend in college and obviously it was an incredibly difficult time. All our thoughts are going out to him.
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
Offline FranksNewLiver
« Reply #1367 on: Tue, 29 September 2015, 12:35:10 »
That is awful. My condolences.
Offline fi0x
« Reply #1368 on: Thu, 01 October 2015, 06:49:51 »
My condolences. The heart and prayers of everyone here go out to you DrHubble.
My grandmother passed away 2 years ago... I still can't believe she is gone. It can feel unreal sometimes.
~I̶ ̶a̶m̶ ̶n̶o̶t̶ ̶a̶ ̶k̶e̶y̶b̶o̶a̶r̶d̶ ̶g̶e̶e̶k̶ ̶(̶I̶ ̶w̶o̶u̶l̶d̶ ̶l̶i̶k̶e̶ ̶t̶o̶ ̶t̶h̶i̶n̶k̶ ̶I̶'̶m̶ ̶o̶n̶e̶)̶ I am a keyboard geek~
Offline asdfjkl36
  • blue shirt guy
« Reply #1369 on: Thu, 01 October 2015, 09:57:49 »
Sorry to hear about DrHubble.
Best wishes go out to him and those affected by this tragic event.
Offline Jokrik
« Reply #1370 on: Tue, 06 October 2015, 05:58:58 »
Just found out about this
My deepest condolences to Dr, the family and friends
RIP
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #1371 on: Tue, 06 October 2015, 11:05:24 »
I haven't been keeping on with this thread because i didn't buy one but that really sucks to hear about your friends man.
Hope you're doing okay.
Offline hoggy
« Reply #1372 on: Tue, 06 October 2015, 13:26:28 »
Sorry for your loss. My condolences.
Offline livingspeedbump
    • KeyChatter
« Reply #1373 on: Tue, 06 October 2015, 15:30:56 »
« Last Edit: Tue, 06 October 2015, 18:38:31 by livingspeedbump »
<- My Collection (so far)
    • KeyChatter
« Reply #1374 on: Tue, 06 October 2015, 15:32:08 »
Also, very sorry to hear about the loss DrHubble  :(
Offline DrHubblePhD
  • I am star stuff
« Reply #1375 on: Tue, 06 October 2015, 15:55:17 »
Update to come... please stand by, we are close to launch
Offline Steezus
  • Keeper of Facts
« Reply #1376 on: Tue, 06 October 2015, 15:57:36 »
Good news! Glad to see you back Doctor.  :thumb:
Offline diqkiq
« Reply #1377 on: Tue, 06 October 2015, 16:21:57 »
Cool
Offline Bucky
« Reply #1378 on: Tue, 06 October 2015, 18:05:21 »
Sweet, excited to get this baby rolling :)
  • keyset hoarder
« Reply #1379 on: Wed, 07 October 2015, 02:50:28 »
Glad to see you back Dr  :)
Offline filphil
  • One day I hope to find a love like JD and Turk
« Reply #1380 on: Wed, 07 October 2015, 07:41:26 »
HE SAID LAUNCH GUYS.  :))
I'll see myself out now.  Sorry.
    • KeyChatter
« Reply #1381 on: Thu, 08 October 2015, 12:03:09 »
Gave spot #13 to Binge.
Offline theanyday
  • love love love
MIRA SE | White Fox w/ 67g Zealios | POK3R w/ Blues | K70 w/ Browns | Planck w/ Greens | NovaTouch TKL
Offline Jokrik
« Reply #1383 on: Fri, 09 October 2015, 03:49:47 »
There will be more on the actual gb if I'm not wrong, unless you want that no 13
Offline Steezus
  • Keeper of Facts
« Reply #1384 on: Fri, 09 October 2015, 09:17:25 »
I think it was more that the first 57 people got free gold stabs, custom numbering on the case weight, and you get your board before anybody else.
« Reply #1385 on: Sat, 10 October 2015, 16:50:18 »
Do we know when this is happening? I'd prefer to avoid being late... I really want this board and I missed the original 57...
Offline slushi
« Reply #1386 on: Wed, 14 October 2015, 12:00:34 »
Wooooohoooo! I signed up  :thumb:
 HHKB Pro 2
Offline asdfjkl36
  • blue shirt guy
« Reply #1387 on: Wed, 14 October 2015, 14:40:52 »
I keep forgetting but
I'll be giving away a Mira shirt (Medium) and a Mira Hoodie (also Medium) sometime soon.
So for those of you interested (and have placed a pre-order) just reply here and I'll select someone.
Not sure if I should do a giveaway for each or do a giveaway for both. Let me know what you guys think.
  • keyset hoarder
« Reply #1388 on: Wed, 14 October 2015, 15:37:07 »
Do it separate to share the MIRA love around - I'd be happy to chip into the extra shipping cost for whoever wins given your incredible generosity  :thumb:
Offline roostrc0gburn
  • its just plastic
« Reply #1389 on: Wed, 14 October 2015, 17:10:42 »
nice! i missed out on the swag train first time around
Offline aznairjordan
« Reply #1390 on: Wed, 14 October 2015, 18:31:10 »
Oooh I'm interested! Didn't want to drop that much on some clothes at that point. I'm all for a giveaway for both so two people are happy, but its extra work/money for you :(
TGR Jane CE|FC660C|Orion V2
GMK Hyperfuse|GMK Olivetti|GMK Red Alert|Soulfree's Teal|GMK Cyan
Offline asdfjkl36
  • blue shirt guy
« Reply #1391 on: Wed, 14 October 2015, 19:03:53 »
Yea. I dont mind paying the cost of shipping. Not a problem.
So i guess here's the form (Made it quickly since i'm starting a midterm right now)
https://docs.google.com/forms/d/1w6JaHyacXH2uRB4gIrzVnjscR3OzUNZ5w7sSBDLfqNA/viewform?usp=send_form
Hopefully everything's okay with the form.
Offline Cottonsox
« Reply #1392 on: Wed, 14 October 2015, 19:49:09 »
Awesome giveaway!
Offline DrHubblePhD
  • I am star stuff
« Reply #1393 on: Thu, 15 October 2015, 11:08:25 »
Okay guys update time!
So after talking to the manufacturer, it looks like we are going to need some big numbers to make the Mira happen. It will be a challenge to hit the necessary units, but damn it were going to try  :p
Im hoping ninjadoc can fill you in on the finalized list of anodizing options. After we get a pricing scheme worked out I will set a day for the launch of the group buy.
More info to come.
-Hubble
Re: [IC] Hubble Mira Custom TKL (GROUP BUY STARTING SOON)
« Reply #1394 on: Thu, 15 October 2015, 11:11:48 »
I would be V-interested.  Count me in.
  • its just plastic
« Reply #1395 on: Thu, 15 October 2015, 11:16:29 »
this IC is like one, long teaser. Doc, if this project does not meet MOQ, can we please talk about at least having the first 57 made, even if that means a higher price point?
Offline DrHubblePhD
  • I am star stuff
« Reply #1396 on: Thu, 15 October 2015, 11:19:53 »
I never said we would just give up if the MOQ wasnt made. We have developed a trust with our current CNC shop, if we can go through them we would like to. If not, we find a different shop and try again.  :thumb:
We are going to get it made.
  • its just plastic
« Reply #1397 on: Thu, 15 October 2015, 11:27:11 »
good to hear. I'm in
Offline slushi
« Reply #1398 on: Thu, 15 October 2015, 11:41:35 »
Got the invoice and have sent payment! Hope this all pans out   ;D
 HHKB Pro 2
Offline ninjadoc
« Reply #1399 on: Thu, 15 October 2015, 19:49:41 »
I haven't forgotten everyone. The bottom line is that the standard colors can be done without an extra fee and custom colors can be done with at least 5 units and 15 would be ideal to keep the added cost of the color in the 20 - 30 range. I will do my best to post pictures in the next 2 - 3 days.
