Author Topic: [IC] Hubble Mira Custom TKL (GB is 3... 2... 1... launched!)  (Read 813207 times)
Offline Zeal
    • Zeal Generation Inc.
Re: [IC] Hubble Mira Custom TKL With b.Mira PCB
« Reply #200 on: Sun, 29 March 2015, 17:11:17 »
Metallic blue anyone? This time in WKL!
As always, 4k render. :)
« Last Edit: Sun, 29 March 2015, 17:13:25 by Zeal »
Offline DrHubblePhD
  • I am star stuff
« Reply #201 on: Sun, 29 March 2015, 17:22:58 »
Winkeyless blockers, updated case height, and a new plate to boot  :thumb:
plate now has cutouts for easy switch removal, stepped caps lock, short right shift, and compatibility for 87 and 84 key layouts!
« Last Edit: Sun, 29 March 2015, 17:25:46 by DrHubblePhD »
« Reply #202 on: Sun, 29 March 2015, 17:25:38 »
Can I have one yet?
Offline Cottonsox
« Reply #203 on: Sun, 29 March 2015, 17:25:58 »
Please just take my money now.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #204 on: Sun, 29 March 2015, 17:27:06 »
Can I have one yet?
I know right XD
Just gives me something to look forward to
Offline DrHubblePhD
  • I am star stuff
« Reply #205 on: Sun, 29 March 2015, 17:27:43 »
Can I have one yet?
I know right XD
And some free wallpaper for 4k monitors  :p
Offline Zeroo
« Reply #206 on: Sun, 29 March 2015, 17:49:53 »
Really hoping I'll have the money available for this once it's all done, it just looks so good! :D
Offline FreeCopy
« Reply #207 on: Sun, 29 March 2015, 18:14:18 »
I think if I were to make it in the group that gets the gold stab wires I'd go with a gold case. Other than that I'm torn on what I would want.
This is something I'm really looking forward to.
Rather accommodating options. Very nice!
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline Zeal
« Reply #208 on: Sun, 29 March 2015, 19:06:09 »
Metallic Silver. WKL.
4k @ 100+ Passes
Offline njbair
    • nickbair.net
« Reply #209 on: Sun, 29 March 2015, 19:15:43 »
I like some of these colored renders, but dies anyone else feel apprehensive about choosing a color that might potentially limit your cap options on such a pricey custom board?
My boards:
Offline Cottonsox
« Reply #210 on: Sun, 29 March 2015, 19:19:55 »
I am in that boat, but it's really personal preference.  I am sure that there will be MOQ attached to the color options, or only a few offered. I wouldn't worry if you want a more neutral color there will be at least one sort of grey/silver offered (assumption on my part). I know i will be jumping on a darker gey/gunmetal if that option is offered. Otherwise, i will asses what is there and get the next best one i like, be it silver, black, etc etc..
Offline DrHubblePhD
  • I am star stuff
« Reply #211 on: Sun, 29 March 2015, 19:21:25 »
Yes, these colors are mostly just for fun. It is likely that the final buy will contain only one or two of these "exotic" colors.
Offline user 18
« Reply #212 on: Sun, 29 March 2015, 19:25:06 »
I like seeing all of the pretty renders, but I'm fairly locked into a grey colour, unless there's a blue that really grabs me.
Avatar by ashdenej
Offline njbair
    • nickbair.net
« Reply #213 on: Sun, 29 March 2015, 19:27:30 »
A NASA board needs to have a blue option.
My boards:
« Reply #214 on: Sun, 29 March 2015, 19:31:23 »
Need to round off those sharp edges inside the arrow cluster with the same radius as the rest of the corners.
Offline DrHubblePhD
  • I am star stuff
« Reply #215 on: Sun, 29 March 2015, 19:34:03 »
I had this conversation earlier with Zeal. Many customs such as the Corsa or the 356cl have those two corners un-filleted. Honestly when I use the same radius it looks weird. I may add a more subtle curve, but overall it will probably stay that way.
« Reply #216 on: Sun, 29 March 2015, 19:37:36 »
I just checked a few of my Aluminum boards.  You're right.  For example, the Cheat rounds those corners but with much smaller radius.  Looks like KMAC uses the same small radius on all the internal corners.
Offline njbair
    • nickbair.net
« Reply #217 on: Sun, 29 March 2015, 19:40:19 »
The WKL blocks are sharp-cornered, too. It's because they're outside corners, unlike the rest which are inside corners.
For those without manufacturing experience, you can't machine a sharp inside corner because spinning mills will always cut round. You can minimize this fillet/radius by using a smaller cutter, but only to a point. The only way to fabricate a sharp inside corner would be casting or die-punching, neither of which yield the same beautiful result as a milled piece.
My boards:
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #218 on: Sun, 29 March 2015, 19:55:42 »
I'm currently transitioning to 60% boards but I really want to see this board made.  I think the Mira will put the KMAC and the 356 to shame.  The right key set on this board is going to take it to the next level.  Something with a full SA profile would look good, but really, this board needs a key set designed specifically for it.
Design it! :D
I used the custom key set designer on WASD to create this and added a mockup of one of Booper's astronaut key caps.
With the site's limited color options, I tried to make a colorway inspired by the lunar surface.  I think it would look good on the gray keyboard in the OP and on the pink render created by Zeal.  But I think the Mira needs a more polished design for its key set.
I tried making something to reflect the theme of the binary star but it looks awful.
http://www.keyboard-layout-editor.com/#/layouts/37dd711f75e80c0e0255a4195b1c5c1c
Image of Mira
It's not practical, but I think a set of backlit black keys without alphanumeric legends but with legends resembling the night sky would look awesome.  The assembled alpha and mod keys would look something like this.
I like the greys, but not so sure about the legends they are a little bland.
I'm not to fond of the second one either. :confused:
I think Cospar wouldv'e been perfect for this. Shame this never took off (No pun intended :p).
Offline feizor
« Reply #219 on: Sun, 29 March 2015, 20:19:32 »
I have too many neutral color boards, I will be in for an exotic!
Offline korrelate
  • iubeo stultum esse libenter
« Reply #220 on: Sun, 29 March 2015, 21:00:48 »
just curious: is the logo milled into/ through the surface or is it a sticker? If milled, any chance of ordering without? It's a cool design, don't get me wrong, jus not a fan of logos.
Topre REALFORCE
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #221 on: Sun, 29 March 2015, 21:05:05 »
Would also like to know about no top logo?  I wouldn't be using any LEDs other then the lock keys anyways.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Cottonsox
« Reply #222 on: Sun, 29 March 2015, 21:11:11 »
i see the logo as one of the design elements which identifies this board and makes it unique, if your looking for no logo there are other options out there in the market and upcoming.
I am not the biggest fan of the acrylic insert, i would prefer to be able to use a alu insert and possibly in a different color, although i don't see this being feasible in the as i am probably a minority.
Offline DrHubblePhD
  • I am star stuff
« Reply #223 on: Sun, 29 March 2015, 21:14:05 »
Well I havent heard back from CNC shops yet, depending on the cost there may be an engraved logo option. Either way there is nothing stopping you from not installing the logo LEDs
Offline Bromono
  • Wanabe Cicerone
« Reply #224 on: Sun, 29 March 2015, 21:16:07 »
I want the opposite :D just engrave the logo wherever you can!
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #225 on: Sun, 29 March 2015, 21:17:54 »
I was actually thinking the same thing about the aluminum insert. The main reason why I wouldn't want the acrylic is because I wouldn't be putting LEDs under it anyway.
Not that the acrylic would keep me from getting one. It just wouldn't be lit up.
*Edit*  A engraved logo would be a great option also  :thumb:
« Last Edit: Sun, 29 March 2015, 21:24:31 by CommonCurt »
WTB/WTS/WTT ---->
Offline LXXXIX
« Reply #226 on: Sun, 29 March 2015, 21:21:09 »
Would opting out of the acrylic and replace it with the engraving drive down the cost? If so about how do you think? Don't get me wrong the LED logo is really neat, but I'm just curious.
Offline njbair
    • nickbair.net
« Reply #227 on: Sun, 29 March 2015, 21:21:24 »
Engraving could only be cheaper, since it's basically the same cut but at only .030" deep instead of through the top plate.
My boards:
Offline Cottonsox
« Reply #228 on: Sun, 29 March 2015, 21:22:02 »
For me, i am really not sure if i would use it with LED's or not under the logo, i would like to see it in action or test it myself to see how i felt.
Then if i didn't like it and there was an option for the alu insert i would jump on it, if not to change the feel every now and then. But yeah, i have accepted that if there is only the acrylic insert that is fine by me.
Offline DrHubblePhD
  • I am star stuff
« Reply #229 on: Sun, 29 March 2015, 21:26:00 »
just to be clear, the LEDs are not underneath the insert, they are part of a LED strip that gets mounted sideways. The light will not point directly at you. As for engraving vs acrylic, it would likely drive down cost for engraving. I am still waiting for price quotes though.
Offline Alex92
« Reply #230 on: Sun, 29 March 2015, 21:43:51 »
Is the possibility of skipping the acrylic insert in favor of engraving being considered, because I happen to think that the acrylic insert is one of the aspects of keyboard that makes it unique. It would be disappointing to see it changed. I have no problem with being given the option of having the insert or an engraved logo when we order, though.
Offline Heliosphere
« Reply #231 on: Sun, 29 March 2015, 22:07:01 »
Big dilemma, I like all of these colors and I can't choose just one. Dark gray is my first choice, but blue or gold looks great too. I can't afford to buy two, but I might just have to.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #232 on: Sun, 29 March 2015, 22:40:18 »
I would probably end up choosing either a dark grey or bluish grey
Offline radio_killah
  • Chinchillin'
« Reply #233 on: Sun, 29 March 2015, 23:36:13 »
Have dr hubble or henry zeal said anything official about anodization colors or are they just posting random mock ups?
Offline Cottonsox
« Reply #234 on: Sun, 29 March 2015, 23:49:20 »
I don't think anything is set in stone until quotes are obtained from relevant places to see how many colors can be offered while keeping the buy affordable as possible
Offline exitfire401
  • The Force is Re/\l
« Reply #235 on: Sun, 29 March 2015, 23:54:51 »
Down for number 69 in lime green ;) (btw, I'll gladly pay for a custom anno color if it comes down to it)
Just for fun:
*note to self: don't render with a black background, the sides become grainy.
If this color is allowed, I'll be instabuying.
Offline cryptowillem
« Reply #236 on: Mon, 30 March 2015, 00:34:15 »
Best start saving my pennies! I really like the acrylic logo myself.
Got nothing for ya. Head back to camp.
Coolermaster Quickfire Rapid TK w Blues
WASD Code TKL w Greens
Offline Zeal
« Reply #237 on: Mon, 30 March 2015, 00:35:01 »
Metallic Red
4k, 300 passes :eek:
Offline pr0ximity
« Reply #238 on: Mon, 30 March 2015, 07:06:51 »
Premium CNC milled logo insert would be baller as hell.
Offline LXXXIX
« Reply #239 on: Mon, 30 March 2015, 07:39:49 »
I would actually prefer this compared to the acrylic and the engraving. It seems like a good middle ground for having something really unique and for the folks that don't want the clear acrylic.
The only question I have would be would it wiggle? Like would it be a good snug fit? :confused:
Offline njbair
    • nickbair.net
« Reply #240 on: Mon, 30 March 2015, 08:25:12 »
CNC milled out of what? A different kind of metal?
CNC machines are so precise and so repeatable that "wiggle" would be a non-issue. In fact, the acrylic insert is likely going to be CNC-machined to fit the cutout.
My boards:
Offline Zeal
« Reply #241 on: Mon, 30 March 2015, 12:27:58 »
Played around with some colour options last night.
Graphite/Dark Gray:
Mint or Cyan?
Attempt at replicating TA Mod colour (This one ran overnight for 500+ passes, some colour bleed on the plate as the original render turned out too dark, so I tried to fix it up in PS :( )
« Last Edit: Mon, 30 March 2015, 12:31:24 by Zeal »
Offline user 18
« Reply #242 on: Mon, 30 March 2015, 12:35:10 »
Love the mint/cyan colour
Avatar by ashdenej
« Reply #243 on: Mon, 30 March 2015, 12:52:22 »
I'm down
Offline njbair
    • nickbair.net
« Reply #244 on: Mon, 30 March 2015, 13:08:34 »
Graphite/Dark Gray:
Mint or Cyan?
Dat TA color doe. Hnng!
My boards:
Offline Heliosphere
« Reply #245 on: Mon, 30 March 2015, 13:10:14 »
Graphite/Dark Gray:
Mint or Cyan?
Love the graphite and TA color.
« Reply #246 on: Mon, 30 March 2015, 14:09:58 »
Dark purple anyone?
Offline strict
  • TKL Zealot
« Reply #247 on: Mon, 30 March 2015, 14:13:30 »
Holy **** ... graphite is where it's at! I know what color I will be ordering  :thumb:
Offline Zeroo
« Reply #248 on: Mon, 30 March 2015, 14:49:22 »
I like the Mint/Cyan colour, graphite looks pretty good too :D
Offline Blackehart
« Reply #249 on: Mon, 30 March 2015, 15:31:10 »
TAAAAAKE MY MONEEEEEEY!!!!!!!
