Author Topic: [IC] 60% Acrylic case  (Read 29669 times)
Offline bdtbinh
  • In Geek I trust
Re: [IC] 60% Acrylic case
« Reply #50 on: Mon, 11 May 2015, 13:09:57 »
Sr guy. We still testing our new CNC.
Will update asap ;)
Offline ideus
  • Björkö.
« Reply #51 on: Mon, 11 May 2015, 13:16:17 »
It is too expensive.
Offline lolpes
« Reply #52 on: Mon, 11 May 2015, 13:21:39 »
For a piece of a acrylic this size, no, you are basically paying the materials, try and do this yourself and you will see ;)
Offline micr0n
« Reply #53 on: Fri, 22 May 2015, 21:35:51 »
any lower profile case in mind? i think this is kinda big in terms of heigth, a little smaller and would definitely be interested :)
I'm with this fellow.  I'm in if we can get this in a lower profile as well.
Offline jorgenslee
« Reply #54 on: Sat, 23 May 2015, 06:17:32 »
Have you checked the Tex low profile acrylic case? If you are looking for a low profile, I think that's what you need.
Offline micr0n
« Reply #55 on: Sat, 23 May 2015, 14:40:52 »
Yes, I have, but finding it seems kind of scarce at the moment.
Offline lolpes
« Reply #56 on: Sat, 23 May 2015, 14:46:58 »
Aliso this case in a lower profile and mantaining the angle, is quite diferente from the tex case ;)
Offline cwils0n
  • twiggletwaggle
« Reply #57 on: Thu, 28 May 2015, 07:43:37 »
If you contact Tex they should give you a quote for direct sales.  I asked about the low profile acrylic case a couple months ago and they said it would be $80 shipped to the US.
Offline okwchin
« Reply #58 on: Thu, 28 May 2015, 11:14:01 »
Ooh this is pretty.
Ive been waiting for a full profile case, and really like my acrylic TEX case for its 'chameleon' effect of blending with whichever surface I place my keyboard onto.
What I would like to see (if possible) is the most minimal of cases, very much like the original poker case, but in clear.
so
1) Minimal height and,
2) Minimal wall thickness (3mm?)
(which seems to be what a number of people have also requested?)
I'm certainly interested if this is possible. If its as tall as it is now, that would be a deal breaker for me  :(
« Last Edit: Sat, 30 May 2015, 21:21:29 by okwchin »
Offline micr0n
« Reply #59 on: Thu, 28 May 2015, 18:29:14 »
Thanks for the heads up.  I definitely will need to contact them on this.
Offline 01111000
« Reply #60 on: Wed, 17 June 2015, 13:00:20 »
Any updates?
Poker 2 w/ MX Clears | Ducky Shine 3 w/ MX Blues | CM Novatouch
Offline SixtyLife
« Reply #61 on: Sat, 04 July 2015, 17:53:56 »
would love this if the walls were thinner - ideally same thickness as a stock poker 2 case.
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline bdtbinh
  • In Geek I trust
« Reply #62 on: Tue, 03 May 2016, 13:11:43 »
Anyone still interest in this, im planning to open a GB  :thumb:
Offline Gengarfan
« Reply #63 on: Tue, 03 May 2016, 19:25:33 »
I would get in on this. Let us know when the buy happens!
« Reply #64 on: Tue, 03 May 2016, 19:56:53 »
Holy necro IC.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #65 on: Tue, 03 May 2016, 23:17:14 »
I'm not a fan of the clear but a solid block of black acrylic would sound amazing imo
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #66 on: Tue, 03 May 2016, 23:35:51 »
I still think the clear looks good, but I would much rather one of these in a greyish smoked acrylic.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #67 on: Tue, 03 May 2016, 23:42:46 »
So like smoked glass huh? That would look pretty cool with the LEDs
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #68 on: Tue, 03 May 2016, 23:45:02 »
Yeah.  Something kinda like this, but frosted.
WTB/WTS/WTT ---->
Offline Gengarfan
« Reply #69 on: Tue, 03 May 2016, 23:46:25 »
Just wanted to say that I love the one that was in the original post  :p
Offline LunarisDream
« Reply #70 on: Wed, 04 May 2016, 16:04:46 »
Are you sure? I can get a similarly-sized aluminum case for cheaper in China, and I'm pretty sure aluminum is more expensive than acrylic.
Not complaining about OP's price at all. I just don't believe the quoted statement is accurate.
Holy **** just noticed the date
« Last Edit: Sat, 07 May 2016, 14:49:55 by LunarisDream »
Offline lolpes
« Reply #71 on: Wed, 04 May 2016, 16:37:01 »
I think I may have explained myself wrong there, basically yes I am sure, and also no xD
I guess the biggest cost involved with these types of cases would be the machining and finishing of the product, the raw materials won't influence very much the price if bought in bulk which I think OP might be doing, or OPs manufacturer.
Having said this i wouldn't doubt you could find it for cheaper in China.
« Reply #72 on: Wed, 04 May 2016, 17:38:24 »
Ah right, machining costs do add up, especially depending on where you're at. China has the advantages of both bulk manufacturing and low pay to keep products relatively cheap.
Offline bdtbinh
  • In Geek I trust
« Reply #73 on: Sat, 07 May 2016, 07:38:07 »
If i can afford to product 1000 pieces, im sure the price would be much cheaper :D
I dont have the Taobao case here to compare, but i think that the choice of buying is depend on u
Offline bdtbinh
  • In Geek I trust
« Reply #74 on: Sat, 07 May 2016, 07:39:07 »
I am preparing for the GB, will post it soon  :thumb:
Offline jebbra
  • jebbra.net
« Reply #75 on: Sat, 07 May 2016, 12:15:10 »
If there's one for planck with solid colors, in for sure.
Offline DukeMugen
  • +1
« Reply #76 on: Tue, 10 May 2016, 21:17:53 »
Count me in!
let me check my wallet.
Offline bdtbinh
  • In Geek I trust
« Reply #77 on: Mon, 16 May 2016, 20:14:09 »
