Author Topic: GasMask giveaway (Reddit)  (Read 1456 times)
Offline GenKaan
  • Mer caps, mindre käbbel
« on: Tue, 24 March 2015, 04:48:31 »
My second giveaway and this time its key chains and a yellow GasMask on the line.
Rules and information is found here
I will take winners from Reddit posts. If you dont have a Reddit user just make a new one and write or link your GeekHack user in the comments :)
Good Luck
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
